l-fussell(at)comcast.net Guest
Posted: Thu Jan 04, 2007 4:11 pm Post subject: Shop Ideas |
Randy,
My Cherokee 180 had a small scoop in a position similar to the rv's that
mated to a 1 inch scat tube which blew across the AV stack. It bothered me
so much flying in the rain that I eventually installed a fan and capped the
intake. Ok, it never caused a problem but the Idea of rain being blown
across my AV stack was more than I could stand. Something about Volts and
H2O.
Larry
RV-7A
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
bill(at)repucci.com Guest
Posted: Thu Jan 04, 2007 4:47 pm Post subject: Shop Ideas |
Two other thoughts...
Put in some type of sound system and a beer fridge.
I found that without some type of background music, I tend to spend less
time in the shop.
The beer fridge is so it will be easy to talk your "friends" over to
help from time to time. Oh, and keep a lock on it until after the task
at hand is finished.
Bill
David Lee
Posted: Thu Jan 04, 2007 5:36 pm Post subject: Re: Shop Ideas |
Plenty of light and the compressor(belt driven --oil filled) away from your work area. I put mind on the other side of a wall in a small storage shed attached to the garage. Plumbed with PVC pipe--480 PSI-- across the garage ceiling down to a distribution center where the filter and oiler are located. ran two lines with quick releases from here. You want one before the oiler and one after. Oil and paint don't mix very well!.
Negotiate with your wife on utilizing the whole two car garage or build a separate shop area. You will need the space. I am restricted to 1/2 of a two car and will be out space when the wings and fuselage arrive next week. Hope to have relief come spring or summer. Must get creative on the space tho!
Good luck,
David Lee
billsettle(at)bellsouth.n Guest
Posted: Thu Jan 04, 2007 6:48 pm Post subject: Shop Ideas |
Congrats! It only took me about 5 hours to inventory and organize my wing kit.... I'm within a couple of miles of you... I live just off Hickory Tree Road in Merrifield, .7 mi from 150. You're welcome anytime.
Bill.
Date: 2007/01/04 Thu PM 06:32:22 EST
To: rvsoutheast-list(at)matronics.com
Subject: Re: Shop Ideas
Bill-
where are you building your RV-8 wings (I see WS by your signature line)
ABF is delivering my RV-8 wings tomorrow! I'm also in WS (off ebert near
clemmonsville Rd)
I'd love to see your shop set up and progress.
Carter Wright
RV-8 ... Wings!
Winston Salem
The MSN Entertainment Guide to Golden Globes is here. Get all the scoop.
http://tv.msn.com/tv/globes2007/?icid=nctagline2
robbie(at)atlanticpkg.com Guest
Posted: Fri Jan 05, 2007 1:59 pm Post subject: Shop Ideas |
Wow... remind me never to ask you think "long and deeply" on any
subject!! <grin>
That's a lot of really excellent recommendations. Thanks Lee!
Robbie
On Jan 5, 2007, at 2:33 PM, lee.logan(at)gulfstream.com wrote:
Here's my list for what it's worth:
1. Compressor:
- Enclose if outside, make sure it has top cover
- Easy access to the water drain (install on 4x4s so you can
reach under
it)
- Oil bath compressor
- Water filter
- Separate runs for air tools and paint guns
- Manifold so you can run more than one air tool at a time
2. Lights/electricity:
- Figure out how many lights you need and then double that (no
kidding)
- Flourescent, not incandescent
- Lots of electrical plugs and a couple of multi-plugs (screw gun
charger, sound system, drill bit sharpener, small refrigerator, drop
lights, vacuum cleaner, etc.)
- A couple of long extension cords
- One work area with several plugs for band saw, belt grinder, drill
press, other power tools
3. Benches/Tables:
- You will need more work benches and worktables than you think
- Build out of solid core doors, find throwaways is you can. They
are
very sturdy and importantly, they are very flat
- Solid core doors over cheap kitchen drawer cabinets are great work
benches, use simple 2x4s and solid core doors to make a worktable
or two
4. Storage:
- You will need a place for safe storage of parts before you
build, for
finished parts as you build. Pegs on the wall, or:
- PVC pipe can be used to make a "forest" for vertical storage of
ailerons, flaps. fin, h/s, etc
5. Jigs/supports
- Might want to consider having your builders build the jigs you
will
require (this will depend upon which RV you are building and
whether you're
doing a "quick build" or not, but with all their power tools they
can build
a jig in half an hour that would take you all day. Also, theirs is
likely
to be square where yours may not be.
- Same for a wing cradle (mine is a rollaround and it's great).
Gets the
wings to wherever I need them including out of the way.
- Saw horses: Have your builder make you at least 2-3 sets.
6. Air hoses: I really like the cheap black rubber hoses they have at
Harbor Freight. The coiled types and the colorful blue and yellow
(vinyl??) ones get all balled up and catch on everything. This is
a case
of cheaper is better...they lie flat on the floor, don't coil up
badly and
roll up easily on a wall roller (which I also recommend installing)
- Air hose connectors: Be careful when you buy these (Harbor
Freight)
and get all the same type. There are several styles with very small
differences between them but they aren't interchangeable. Some of
your
tools will require male and some female, adaptors. Heads up.
7. Painting: Even if you don't paint your airplane yourself, you will
still need a place to grey prime/zinc chromate small parts. Even
if it's
only a phone booth sized, plastic enclosed booth, a paint area that
will
help keep from getting overspray on everything else in your shop
would be
useful.
8. Cleanup: You should consider provision(s) for occasional major
shop
clean up. Grinding, drilling, shaping, bandsawing, deburring, and
fiberglass work, etc, makes more dust than you can imagine.
Getting as
much of your gear off the floor as possible will be a great help with
sweeping up/blowing out your shop. Having a place to hang your
creeper(s),
rollaround seats, to roll up your airhoses and extension cords, for
hanging
your major parts on the wall, etc. will greatly facilitate a full
blown
clean up.
All I can think of for now!
Lee...
Lee Logan
Government Programs and Sales Support
Gulfstream Aerospace Corporation
Savannah, Georgia
This e-mail message, including all attachments, is for the sole use
of the
intended recipient(s) and may contain legally privileged and
confidential
information. If you are not an intended recipient, you are hereby
notified
that you have either received this message in error or through
interception, and that any review, use, distribution, copying or
disclosure
of this message or its attachments is strictly prohibited and is
subject to
criminal and civil penalties. All personal messages express solely
the
sender's views and not those of Gulfstream Aerospace Corporation.
If you
received this message in error, please contact the sender by reply
e-mail
and destroy all copies of the original message.
