rv8a2001(at)yahoo.com Guest
Posted: Wed Jan 03, 2007 11:28 am Post subject: GPS Antenna Under Cowl |
Speaking of expensive GPS antennas, there was an article in Kit Planes a while back that had a roll your own antenna for about..........20 bucks? They had several different types and they worked just as well if not better than the expensive ones...........So if you do barbque the antenna find that article and make one for cheap!
Scott Bilinski
RV-8a
lors01(at)msn.com Guest
Posted: Wed Jan 03, 2007 12:14 pm Post subject: GPS Antenna Under Cowl |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> I've long since deleted the original message on this subject but it was my impression that the antenna in question was the Garmin GPS *XM* antenna which is a different animal than the actual GPS antenna. I could be wrong.
BTW, I just installed my 496 and it only takes one flight while looking at the weather around you in real time to get hooked. I'd feel naked without it now.
Why didn't the FAA just buy a satellite channel for weather instead of that silly, expensive, incomplete ground based system they decided on? Rhetorical question I guess. They love ground based systems for "turf reasons".
Tracy Crook
Rotary powered RV-4 & -8, 1600+ hrs.
jimteri1(at)earthlink.net Guest
Posted: Wed Jan 03, 2007 6:55 pm Post subject: GPS antenna under cowl |
Not sure about the fragility of your chosen antenna, but I installed the factory antenna puck from my Bendix-King KMD-150 about 1 inch under the cowling, center mounted, just behind the baffels, on a supported aluminum plate. No problems in 334 hours and I have lost signal only once in a heavy overcast. The GPS locks on after startup in about 40 seconds.
Don't even think about mounting it on top of the glare shield - you will get the reflection in the windshield. FWIW.
michele.delsol(at)microsi Guest
Posted: Thu Jan 04, 2007 2:06 am Post subject: GPS Antenna Under Cowl |
Dan,
Thanks for pointing us to the McMaster single use temperature systems. I am impressed by the choices – they can be a great help in establishing peak temperatures in various locations under varying conditions.
Michele
RV8 - Finishing
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of Dan Checkoway
Sent: mercredi 3 janvier 2007 16:35
To: rv-list(at)matronics.com
Subject: Re: GPS Antenna Under Cowl
Interesting. Still call me a skeptic, but I agree about measuring it. I'll get some nonreversible temperature strips from McMaster and see what it hits.
http://www.mcmaster.com/nav/enter.asp?pagenum=519 (middle of that page)
)_( Dan
jmsears(at)adelphia.net Guest
Posted: Thu Jan 04, 2007 2:20 am Post subject: GPS antenna under cowl |
| Quote: | Don't even think about mounting it on top of the
windshield. FWIW.
When I built Scooter, the norm was to install the antenna on the glare
shield, or on the fuse somewhere. My instructions said to not paint the
antenna; but, some did and found that the antenna still worked just fine.
Mine is still white and has not been a problem on the glare shield, at all.
In fact, I plan on installing the GPS antenna in the same location on my new
one. It works for me, even if some find it annoying.
I'd be somewhat concerned about having it under the cowl with all that heat;
but, I guess it's a strong little critter. I noticed some of you haves
several hundred hours on your installations with no problems.
Jim Sears in KY
RV-6A N198JS (Scooter)
EAA Tech Counselor
mike.stewart(at)us.ibm.co Guest
Posted: Thu Jan 04, 2007 3:48 am Post subject: GPS antenna under cowl |
<Snip>
<snip>
I disagree here. I have 4 of the small black hockey puck gps/xm antennas
up on my glare shield. No reflection what so ever. I would paint any
antennae black and stick it there. Easy to wire and service.
I did have slight signal degradation with several gps antennas right
next to each other affecting only my 430. So I put the white garmin
antennae under the cowl, aft of the rear baffle, mounted to the engine
mount and it has worked fine there for 200 hours. I had the same
location on my 6 under the cowl for 1500 hours.
Best,
Posted: Thu Jan 04, 2007 4:22 am Post subject: GPS antenna under cowl |
What about putting the antenna on the cockpit side of the firewall just
under a fibreglass covered cut-out which could be made into a trap? The only
problem I have with up front in the engine compartment is that I'd have to
plan for one more firewall pass through. I hate firewall pass throughs since
I plan to make each one as fireproof as possible.
Michele
RV8 - Finishing
jsflyrv(at)verizon.net Guest
Posted: Thu Jan 04, 2007 5:38 am Post subject: GPS antenna under cowl |
My 296 GPS antenna is on the glare shield and I do not notice it is
there. Of course my glare shield is painted black and my GPS antenna is
black.
Jerry
Jim Sears wrote:
> windshield. FWIW.
the antenna; but, some did and found that the antenna still worked
just fine. Mine is still white and has not been a problem on the glare
shield, at all. In fact, I plan on installing the GPS antenna in the
same location on my new one. It works for me, even if some find it
annoying.
heat; but, I guess it's a strong little critter. I noticed some of
you haves several hundred hours on your installations with no problems.
Jim Sears in KY
EAA Tech Counselor
Gary.A.Sobek
Posted: Thu Jan 04, 2007 6:43 am Post subject: GPS antenna under cowl |
Michele:
Do you mean link this as was done with an RV-7? :
http://www.rvproject.com/hidden_antennas.html
Gary A. Sobek
1,973 + Flying Hours So. CA, USA
----Original Message Follows----
From: Michèle Delsol <michele.delsol(at)microsigma.fr>
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: RE: GPS antenna under cowl
Date: Thu, 4 Jan 2007 13:24:45 +0100
Michele
RV8 - Finishing
Posted: Thu Jan 04, 2007 7:36 am Post subject: GPS antenna under cowl |
Yeah - that's the idea. Except that on an 8 half the front top skin is a
door into the forward baggage compartment. I plan to put the GPS antenna
under the other half and the brake fuel reservoir against the left side
(right side being the forward baggage well). The cut-out for the GPS antenna
should be rather large in order to minimize blanking. I figure that a 20°
mask is something that one can live with which means that the antenna would
have a 140° window instead of the 180° if it were to lay flat on the glare
shield. Since the GPS is looking at satellites only, no ground stations, I
would guess that this should be OK.
Michele
RV8 - Finishing
LessDragProd(at)aol.com Guest
Posted: Thu Jan 04, 2007 11:30 am Post subject: GPS Antenna Under Cowl |
Kind of makes the fiberglass window in my carbon fiber cowl seem very worthwhile.
2 GPS antenna's mounted forward of the firewall just under the cowl "window" in my "yet to be completed" modified RV-4.
1 GPS antenna mounted forward of the firewall in my RV-6A. 1 year and 100 hrs.
1 GPS antenna mounted forward of the firewall in my RV-3. 15+ years and 650 hours.
I seem to have established a pattern of placing the GPS antenna in the cool section of the cowl.
Jim Ayers
BTW, Just as a sensory reference, the temperature that can raise a blister on most people (touch temperature) is 140 degrees F.
In a message dated 01/04/2007 7:56:19 AM Pacific Standard Time, ktlkrn(at)cox.net writes:
| Quote: | Since I live in probably the hottest climate in the US I feel I have a little experience is this area. Let me relate a couple of things. One, in my law enforcement career I had the unfortunate opportunity to supervise the investigation of the death of a child that was accidentally left in a car in the summer time. In one case, we simulated the conditions the next day, same time, OAT was within a degree, humitidy level the same. The OAT was 112 degrees. The temperature inside the Chevy Tahoe was 166 degrees.
I guess temps above this are possible but not to likely. Vehicle type, color, roof type are all variables.
I believe the Sun itself is far more detrimental to the equipment than the heat. UV rays are present regardless of the temperature. In the Sun a Chrome finish can be hot to the touch in 70 degree heat. So, you mount your GPS antenna under the bubble somewhere, exposed to the sky, it is still getting the UV rays and the components are getting heat from the sun and collecting that heat.
Armed with this knowledge, I mounted my GPS and XM antennas on a plate just in front of the firewall and near the top of the cowl. Here, they never get direct sunlight and have constant air movement when the plane is in motion. When parked at an airshow or fly in I usually keep oil door unlatched for a few minutes after shutdown. Also when flying at altitude the air in the cowl is not very hot. Meanwhile the bubble mounted antenna has the Sun on it.
Unofficially, I spoke to a person who works in the customer support area of a large Avionics company. He said the under the cowl is probably one of the safest places to mount the antenna. There is it protected from the sun and moisture. He said it should never be mounted in the open as the moisture is the biggest killer of GPS antennas.
DArwin N. Barrie
Chandler AZ
RV7 N717EE
martin333(at)athenet.net Guest
Posted: Thu Jan 04, 2007 12:11 pm Post subject: GPS antenna under cowl |
I have one of my GPS antennae mounted as below, however when I first
installed it I did not realize that the metal fleck paint on my cowl would
impede the reception. The fix was to sand off a 3" x 3" space above the
antenna mount and repaint it with a grey paint without metal fleck in it.
No trouble since, 1400 hours .
Dick Martin
RV8 N233M
the fast one
| Quote: | Not sure about the fragility of your chosen antenna, but I installed the
Bill Schlatterer
Posted: Thu Jan 04, 2007 5:18 pm Post subject: GPS antenna under cowl |
Anybody have any experience with a cowl mount under fiberglass with a
metallic topcoat paint job. Someone noted before that this might be
trouble and that was exactly what I was planning to do! Anyone actually
tried it?
Bill S
7a engine
ronlee(at)pcisys.net Guest
Posted: Thu Jan 04, 2007 7:29 pm Post subject: GPS antenna under cowl |
| Quote: | Anybody have any experience with a cowl mount under fiberglass with a
tried it?
I just read a post about that today I think from Mr Martin (The slow one)
or Mr Ayers. Seems they had to remove some of it but check the web
archives.
There may be such a cowl at the airport that I can check in a day or so.
If so I will try a handheld receiver under it and report back.
Ron Lee
Posted: Fri Jan 05, 2007 3:35 am Post subject: GPS antenna under cowl |
Yes,
My RV8 has solid top coat metallic red. It's a 'pearl' coat, meaning the
metal flakes are fine and dense. No issues on the GPS under cowl for me.
Its 3 coats of this base coat paint.
Posted: Fri Jan 05, 2007 5:19 am Post subject: GPS antenna under cowl |
(long)
I believe the problem with satellite reception is that if the antenna is
inside an electrically conducting enclosure, then the radio waves do not
pass through. Correct me if I am wrong, electricians call such an enclosure
a Faraday cage. So, applying this reasoning, any surface which is
electrically conducting, such as aluminium, steel, copper, carbon fiber,
metallic paint and others will hinder reception.
As to temperatures inside the front baggage compartment on a very hot sunny
day, you have to consider two factors: direct sunlight on the surface -
color will be a determining factor, and the green house effect, ventilation
becomes the determining factor. If your front top skin is colored black and
you shut the canopy and not cover it than you have the worst possible
scenario.
Let me explain what the green house effect is and then it will be easy to
understand how to minimize it. I don't mean to be pompous but some of you
may not know the underlying principles. UV's will pass through glass and
will hit the inside of the airplane. That's energy going inside the cabin.
The surfaces heated by the UVs will radiate infrared light. It is the same
light as the UV except that the wavelength is a lot longer. The infrared
light will not pass through the canopy - it will bounce off and thus gets
trapped. The energy has consequently nowhere to go so things inside the
cabin wind up getting hot. Now, if you crack the canopy open hot air will
escape and will be replaced by cooler outside air, thus alleviating the
green house effect. Another solution is to cover the canopy with a
reflecting silver tarpaulin to prevent UVs from coming in. You can also put
a shiny reflecting surface inside the canopy so that the UVs should be
reflected outwards back through the canopy. The trick is to catch the UVs
and throw them back out before they get converted to infrared. You can
verify this with an experiment you can try now that it is winter. Go to your
fireplace, assuming that you have a good fire going. If there is nothing
between you and the flames, you will feel the heat. Now take a piece of
transparent glass such as is used for windows. Put it between the flames and
your hand. You won't feel the heat any more but you can see the flames
through the glass. Conclusion: low energy light which you can see does pass
through however high energy light, infrared, which feels hot but which you
cannot see, does not pass through. As a sideline, if you put a transparent
glass shield in front of your fire place, then you are throwing a lot of
heat out the chimney as very little will pass through the glass to heat up
your living room.
I enjoyed that - I hope I did not annoy anybody nor insult anyone's
intelligence with my technical meanderings.
Michele
RV8 - Finishing
GRWilliams2(at)bellhelico Guest
Posted: Fri Jan 05, 2007 5:25 am Post subject: GPS antenna under cowl |
Havent posted in awhile but here is my take on the matter if anyone really
cares. Just place the GPS antenna inside the canopy either on the glare
shield away from your view or behind you on the fuselage as the canopy will
slide right over it. This eliminates drag and it looks sexy too. Just my
opinion.
Glenn Williams A&P
davemader(at)bresnan.net Guest
Posted: Fri Jan 05, 2007 7:31 am Post subject: GPS antenna under cowl |
Same here, three coats of metallic blue. Heard the warnings but thought I
would try it just to see and its worked fine.
Dave Mader
dbris200(at)sbcglobal.net Guest
Posted: Tue Jan 09, 2007 4:24 pm Post subject: GPS antenna under cowl |
I think that most "metallic paint" today uses mylar for the flakes, not
metal so there should be no problem, But you may still find paint that
uses metal, so check before you use it.
Dave
PeterHunt1(at)aol.com wrote:
| Quote: | Bill S. asked if anyone had actually mounted a GPS antenna under the
engine cowl and then used metallic flake paint on the cowl. I did
just that and mine works great. I mounted my Garmin 530 GPS antenna
on a platform which I attached high and center on the engine side of
my firewall. The cowl and much of the rest of my airplane is painted
with a beautiful teal metal flake paint. I now have 200 hours on my
RV-6 and not the slightest problem with this GPS antenna
installation. I lock into a GPS signal quickly (within 30 seconds of
start up) and never had a problem losing it in flight. Further,
before I made this installation (during construction in 2004) I talked
with the Garmin people and they did not see any problems with my
installation. I do open my oil access door after flying, but that is
more to just help the whole engine compartment cool down.
Pete in Clearwater, FL
RV-6, Reserve Grand Champion - Kit, 2006 Sun n' Fun
LloydDR(at)wernerco.com Guest
Posted: Tue Jan 09, 2007 7:23 pm Post subject: GPS antenna under cowl |
Mylar is reflective for RF, we used Mylar balloons in the Navy for
targeting practice, and when it is coated its reflectivity can be
increased to create chaff clouds or blooms. The only real way to tell or
not is to paint a like surface with the type of paint you are going to
use, place the antenna under it and test for signal acquisition.
Dan
