rice737(at)msn.com Guest
Posted: Tue Jan 02, 2007 7:41 am Post subject: Vision Microsystems |
To all
I purchased a VM1000C at Sun and Fun last year and have installed it into my
RV8 which I hope to be flying soon. Everything worked except the fuel level
area which remained dark. I called Vision Micro and was told to do a few
different tests. None made any changes. So they said to send it back,
which I did and they received Nov. 25. I just called them and they still
have not touch it and said it would be another month to get it on the bench
because they are working on a new software update. I guess if my plane was
flying I'd be waiting on them to enjoy my work.
So to all that might be looking a purchasing an engine monitor, all I can
say is stay away from VISION MICRO and anybody that is involved with them.
Now I'm sorry I just didn't put in a couple a steam guages.
Anybody else had a problem with them?
Paul Rice,
RV8, almost finsished
Posted: Tue Jan 02, 2007 9:11 am Post subject: Vision Microsystems |
Not till JPI bought them.......
I've sent them a couple of requests for info on their VM1000C - and have been ignored....
n616tb(at)btsapps.com Guest
Posted: Tue Jan 02, 2007 3:00 pm Post subject: Vision Microsystems |
Yes! I have an original VM1000 and the oil transducer is no good. I have
done everything to get it replaced so far with no luck. I just got off the
phone with Auto and was told the same thing. They have no test bench yet to
check it. I requested that in order to maintain a good customer support
with me they needed to just replace it and check it out later. He agreed to
try to do that. The action is yet to be seen.
I would not buy a VM anything at this point. There are sooooo many good
options out there and I was particularly impressed with Electronics
International at the Bend, Oregon airport. They took me in and gave me a
tour and showed me how all there stuff works knowing I already had a VM1000
and obviously weren't going to change it. Their stuff is awesome and the
customer orientation is great. Maybe I need to build a -10 so I can have
the EI stuff.
[quote] --
rv8striker(at)hotmail.com Guest
Posted: Tue Jan 02, 2007 8:07 pm Post subject: Vision Microsystems |
Well I guess I'm in the minority on this one.
I had a few "growing pains" getting my VM1000 up and running, but the folks
at Vision Microsystems were excellent in helping me find the answers or
provide the fix. I had an oil pressure problem that ended up being a cold
solder joint. With their help I was able to trouble shoot it and make it
right. I also had a fuel flow transducer issue that ended up being the
wrong one for my engine/fuel system. That was my screw up when I ordered it,
not theirs, but they quickly made it right.
If I were to become a "repeat offender" and build another RV, I would not
hesitate to go with VM again. It has worked flawlessly after resolving the
initial problems mentioned.
Just my two cents worth.
Steve Struyk
RV-8, 75 hours
St. Charles, MO
dan.beadle(at)inclinesoft Guest
Posted: Tue Jan 02, 2007 8:29 pm Post subject: Vision Microsystems |
Paul,
Have you calibrated the fuel level system? You have to do a few things to
get it set up. First, you have to set the range limits. That tells the
system if you have one tank or two. (Almost everyone has two, but that's
the way it works). From there, you set the max fuel per tank. Then you
have to calibrate the senders by adding fuel.
Let me know off-list if you are still having trouble
Dan Beadle
Posted: Tue Jan 02, 2007 8:30 pm Post subject: Vision Microsystems |
I suspect this was before the change in ownership. Things have changed, and
maybe they will get sorted out again. Lets hope.
[quote] --
