Posted: Fri Dec 29, 2006 11:30 am Post subject: ELT? |
A quick question for those in the know.
Is there electrical wiring that goes to the ELT to maintain a charge on the
ELT's battery or is there simply the internal battery in the unit which it
runs off off in mishap?
John G.
kearney(at)shaw.ca Guest
Posted: Fri Dec 29, 2006 12:14 pm Post subject: ELT? |
John
My ELT (in my Cherokee) has an internal battery that is replaced on a
scheduled basis. The ELT is also recertified every year. There is no
external power source to it.
Cheers
Les Kearney
RV10 # 40643 - Lost in the empennage
Rick S.
Posted: Fri Dec 29, 2006 12:37 pm Post subject: ELT? |
John,
My 450 only has "D" batteries and basically a "phone cord" that runs from the ELT to the panel mounted switch. Only other connector is the antenna lead.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
LarryRosen
Posted: Fri Dec 29, 2006 12:52 pm Post subject: ELT? |
I am using the AmeriKing ELT (AK-450). It requires no power wiring. It
is powered by the D size alkaline batteries. It does require a coax
cable to the antenna (that I will mount in under the far rear tail
fairing) and a RJ11 wire (phone wire and jacks) that goes from the ELT
(mounted near the battery) to the remote display (mounted in the
panel). Here is a link to the installation manual
<http://www.ameri-king.com/pdf/9.1.22.pdf>
Larry Rosen
#356
on the ELT's battery or is there simply the internal battery in the
unit which it runs off off in mishap?
John G.
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Posted: Fri Dec 29, 2006 1:14 pm Post subject: ELT? |
Thanks Guys, I throw in some line to pull the cable through later.
Appreciate it.
John
Quote: | From: Larry Rosen <LarryRosen(at)comcast.net>
Subject: Re: ELT?
Date: Fri, 29 Dec 2006 15:53:56 -0500
I am using the AmeriKing ELT (AK-450). It requires no power wiring. It is
powered by the D size alkaline batteries. It does require a coax cable to
the antenna (that I will mount in under the far rear tail fairing) and a
RJ11 wire (phone wire and jacks) that goes from the ELT (mounted near the
battery) to the remote display (mounted in the panel). Here is a link to
the installation manual <http://www.ameri-king.com/pdf/9.1.22.pdf>
Larry Rosen
#356
>the ELT's battery or is there simply the internal battery in the unit
>Thanks,
>John G.
rv10builder(at)bellsouth. Guest
Posted: Fri Dec 29, 2006 7:39 pm Post subject: ELT? |
While we're on the subject, is there any real compelling reason to
install a 406Mhz ELT (other than the obvious COSPAS-SARSAT discontinued
service in 02/09?). I don't recall ever hearing of a GA aircraft being
located with the assistance of satellites, and I'm not clear if this is
a mandate. One other question...is one mfg. of ELT considered "trash"
whereas another as "treasure"?
Brian
#40308
John G.
