jhasbrouck(at)woh.rr.com Guest
Posted: Sat Dec 23, 2006 5:59 pm Post subject: Elevator rigging |
I have a question re: rigging of the elevators. I've used the neutral position jigs for the elevator bellcrank and the control sticks to set the pushtube lengths and come up with a situation where the control stick interconnect ( F1065 ) contacts the underlying structure before the elevator is at its full up travel. So I've adjusted the pushtubes to give full up elevator before any contact of the stick interconect. This leaves the elevator bellcrank at a different neutral angle than the jig but I can't see why it would matter. Unless, that is, if it interferes with the pitch servo of the TruTrak AP. No interference in the system now with full up or down elevator deflection. What say you all? On another topic, seems that my baggage door came out the same as everyone else. Top edge of it stood proud a bit but some massaging with my fingers and seamers it looks pretty good now. Thanks to everyone who contributes their help to this list. You've made my build experience go very smoothly. Merry Christmas and Happy New Year to all.
John Hasbrouck
#40264
Rick S.
Posted: Sat Dec 23, 2006 7:31 pm Post subject: Elevator rigging |
John,
I don't think you have an issue as long as you get full travel without interference while using the stick. Once you engage the aouto pilot the servo knows it's hold position is and will move the controls, a very minimal amount to maintain either altitude or if your lucky, a rate of climb or decent based on the input from the AP head. I doubt you will ever ask the AP servo to try and move the control surfaces from stop to stop...but as CJ says...I don't know nuthin!!!
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Posted: Sat Dec 23, 2006 8:48 pm Post subject: Elevator rigging |
Thanks Rick for the reply. I don't think there's an issue here either but
thought I'd ask around.
