Deems Davis
Posted: Sat Dec 23, 2006 6:39 am Post subject: Firewall Penetrations - Additional? |
Prior to hanging my engine I would like to ensure I've planned/accounted
for all of the holes that need to be made/placed in the firewall. So for
those of you who have already crossed this bridge......
1. What ADDITIONAL holes did you provide beyond those already called out
for in the plans?
2. What advice/suggestions do you have for the placement/location of
those holes?
3. Did you fireprotect those additional holes? How?
(I'm installing a full engine monitoring system and know I need to
provide thru holes for CHT/EGT)
THANKS for any help
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
GenGrumpy(at)aol.com Guest
Posted: Sat Dec 23, 2006 6:54 am Post subject: Firewall Penetrations - Additional? |
Deems,
Think you have to do this one yourself based on what you are putting in your bird. I'd sit down with a clean sheet of paper and start listing everything that will have to break the firewall.
Some things you can run thru same hole (like the engine monitor wires, fuel flow, fuel pressure, oil pressure, etc).
Then there are others like the battery cables, cables for throttle, etc.
After all was said and done, I ended up having to drill yet another one for the cable I installed to fix the tunnel heat problem......
I'd start that list, then sit on it for a while while you think through all of your connections.
grumpy
40404
DO NOT ATRCHIVE
In a message dated 12/23/2006 8:48:09 AM Central Standard Time, deemsdavis(at)cox.net writes:
| Quote: | Prior to hanging my engine I would like to ensure I've planned/accounted
for in the plans?
those holes?
THANKS for any help
Deems Davis # 406
http://deemsrv10.com/ |
wvu(at)ameritel.net Guest
Posted: Sat Dec 23, 2006 6:57 am Post subject: Firewall Penetrations - Additional? |
Deems,
I have two extra holes for all wiring using fire-proof 36-pin (I think)
plugs installed near the hole for the MAP hose. I can't recommend to buy
the plugs where I bought mine with good conscience but I'm sure they are
available elsewhere.
Anh
LarryRosen
Posted: Sat Dec 23, 2006 1:30 pm Post subject: Firewall Penetrations - Additional? |
Below is a list of what I think is going to go through my firewall. The
list is probably incomplete and with some questions so any guidance from
the list would be helpful.
Engine sensors will all go through a 1" stainless steel firewall
penetration from EPM.AV corp <http://www.epm-avcorp.com/tubeseal.html>.
Most seem to be putting this penetration in the upper right corner (like
Tim). I would like to mount it just to the right of center. Any
concerns with this location?
The wires through this penetration would be
EGT
CHT
oil pressure
oil temp
fuel pressure
rpm
manifiol pressure
Electrical power
Main power feed Super 2 CCA fatwire
<http://www.periheliondesign.com/fatwires.htm> will go through the
firewall per vans location mid left
Starter contactor per vans location
Current limiter and loadmeter shunt located on oil cooler housing
electric to the main bus and e bus penetration near the starter contactor
Magneto wires, not sure where they will penetrate. Not sure what can be
combined with these wires. Any guidance?
Cable penetrations through Stainless Steel eye balls.
Prop
Throttle
mixture
Fuel purge valve (airflow performance FM-200 fuel injection)
Alternate air - How does the alternate air actuate? Is it included with
the FWF kit?
4 penetrations can be arranged where vans has the bushings located in a
diamond shaped arrangement. Scott has some photos on his site. Not
sure where I would locate the 5th if there is even a 5th.
Anything missing?
Larry Rosen
#356
Deems Davis wrote:
planned/accounted for all of the holes that need to be made/placed in
the firewall. So for those of you who have already crossed this
bridge......
out for in the plans?
those holes?
THANKS for any help
Deems Davis # 406
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
jwt(at)roadmapscoaching.c Guest
Posted: Sat Dec 23, 2006 7:29 pm Post subject: Firewall Penetrations - Additional? |
To add to this question - For those who have completed the engine wiring,
would you recommend having all of the engine monitor wiring go through one
hole (if so where is the best location?) or have a left side and a right
side penetration?
John Testement
jwt(at)roadmapscoaching.com
40321
Richmond, VA
FWF, wiring, engine
