flysrv10(at)gmail.com Guest
Posted: Sat Dec 16, 2006 3:22 am Post subject: Garmin 496 -Antenna |
I started the subject of 430 vs 480 and wanted to thank everyone for taking the time to express their opinion. I have to admit that the comments have not made the decision easier. It seems that you get used to the unit and work around what might be regarded as essential by others.
Kelly, what is the offset used for? I have a GNC 250 in my RV6 with the same feature and have never found a need for it. Of course, I live in Florida and have to work REALLY hard to find IFR days to practice.
Rob Kermanj
On Dec 15, 2006, at 9:14 PM, Kelly McMullen wrote:
[quote]--> RV10-List message posted by: "Kelly McMullen" <apilot2(at)gmail.com (apilot2(at)gmail.com)>
ou may be used to the 430, obviously you don't know the 480. Fact
remains that you can't enter more than one segment of an airway at a
time on the 430. If you get a reroute, you will be doing a lot of
heads down time, or just entering one or two fixes ahead at a time.
The 480 can do everything the 430 does in spades and more, whether VFR
or IFR.
Also kind of hard to fly an offset to an airway when you don't have
it, piece of cake for the 480. Flying in the Northeast means
relatively short flights. Maybe the 430 is right for you. I routinely
fly coast to coast and having airways mapped is extremely useful.
See Doug Preston's comments as one who has owned both units.
Not to mention it is available now. What do you suppose the delivery
on a 430W is, given there is a 6 month or more backlog for upgrades?
Not to mention that the 430 is a considerably older design, and much
of it will remain older even with the upgrade. It looks like from
various on-line vendors you are within $500 of each other right now,
although most listings are for the 430, not the 430W, appearing
discounted about $2000 from the 430W. Not hard at all to find the 480
advertised for $9000, probably less on unadvertised price.
On 12/15/06, W. Curtis <wcurtis(at)core.com (wcurtis(at)core.com)> wrote:
| Quote: | >The 430 is designed to go direct and fly an approach. If you fly where
>that is real world it will be great.
Huh? How do you come up with a statement like that?
I fly a 430 IFR in the busy Northeast where you NEVER (at least I've never)
get to fly direct. "It doesn't have airways" only means that you can't enter
an airway in the flight planning section and they are not displayed on the
map. In practicality this only means that on the 430, you can't put in MIV
V1 JAX and have it determine all 12 intermediate points. With proper flight
planning you should have all these points anyway and not have to let a
navigator determine them for you. Otherwise, the flight planning section in
the 430 is pretty good. Get to know it and see for yourself. So I guess I
don't understand you statement about the 430 designed only "to go direct"
and "a VFR tool." If this is the way you are using a 430 then you are not
using it to even a small amount of its potential.
I think a truer statement is that a 430 is a effective VFR AND and IFR
tool, while a 480 in ONLY a IFR tool.
>Not to mention the 480 is now cheaper than the 430W and has a bigger
screen.
Let's see, the 430W will list for $10,750, the 530W $16,495. The 480 used
to lists for $12,000. ????
The economies of scale will make the 430W MUCH less expensive than the 480.
I've had my 430 since '99 and there are over 40,000 now in service and
continue to sell. Anyone care to wager on the 480 being available new in 5
years?
William Curtis
http://wcurtis.nerv10.com/
-- Please Support Your Lists This Month --
(And Get Some AWESOME FREE Gifts!)
November is the Annual List Fund Raiser. Click on
the Contribution link below to find out more about
this year's Terrific Free Incentive Gifts provided
by:
* AeroElectric www.aeroelectric.com
* The Builder's Bookstore www.buildersbooks.com
* Aeroware Enterprises www.kitlog.com
* HomebuiltHELP www.homebuilthelp.com
List Contribution Web Site
--> http://www.matronics.com/contribution
Thank you for your generous support!
-Matt Dralle, List Admin.
- The RV10-List Email Forum -
--> http://www.matronics.com/Navigator?RV10-List
Posted: Sat Dec 16, 2006 3:35 am Post subject: Garmin 496 -Antenna |
Kelly, searched for Doug's comments on the RV10 list and got nothing! can you point me to it?
Do not archive.
Rob Kermanj
or IFR.
screen.
years?
William Curtis
by:
wcurtis(at)core.com Guest
Posted: Sat Dec 16, 2006 4:01 am Post subject: Garmin 496 -Antenna |
[quote]Fact remains that you can't enter more than one segment of an >airway at a time on the 430. If you get a reroute, you will be >doing a lot of heads down time, or just entering one or two fixes >ahead at a time. Kelly, Help me understand this-what do you mean by "more than one segment of an airway?" Three fixes constitute two segments. Are you telling folks they can't enter more than 2 fixes with a 430? This is at best misinformed, at worst disingenious. I mentioned getting to know the flight planning section of the 430, it seems all you know about is the Direct-To button. >The 480 can do everything the 430 does in spades and more, >whether VFR or IFR. It has WAAS and airways over the 430, only airways over the 430W-- is this your definition of "spades and more?" >Also kind of hard to fly an offset to an airway when you don't have >it, piece of cake for the 480. >Flying in the Northeast means relatively short flights. >Maybe the 430 is right for you. I routinely fly coast to coast >and having airways mapped is extremely useful. If by short you mean NJ to Charlotte or NJ to Jacksonville, then yes that's short compared to coast to coast. What's the range of an RV-10 again? --that of any typical high performance single? Now tell me what "relatively short flight" have to do with the navigator you use? >It looks like from various on-line vendors you are within $500 of each >other right now, although most listings are for the 430, not the 430W, >appearing discounted about $2000 from the 430W. Not hard at all to find >the 480 advertised for $9000, probably less on unadvertised price. Like your air navigation I don't understand you economics. Previously I posted list prices, so let's look at street prices. The best you can get a 480 for is about $9,000. You can get better from Stark, but from Van's you can get a 430 for $6,760. Add $1,500 for WAAS and you are still almost $1,000 less than a 480. What am I missing? I too have flown both units but admittedly I'm biased towards the 430. After factoring in what the 480 offers, the user interface and the cost, I determined that the 430 was still better for me and the type of flying I do. I DO NOT regularly fly "coast to coast", I more routinely fly 4-600 mile legs. I can't say what is best for Jet A burning coast to coast flyer's only what is best for me and my typically mission. I always use the flight plan and only use the Direct-To when ATC clears me to some fix ahead already in the flight plan. This is what typically happens in the real world and this is MUCH easier on the 430. William Curtis http://wcurtis.nerv10.com/ [quote][b]
Tim(at)MyRV10.com Guest
Posted: Sat Dec 16, 2006 4:17 am Post subject: Garmin 496 -Antenna |
To give you a picture of the routing capabilities, when I flew
around the rockies enroute to Albuquerque, I played with the
flight planning on my 480. I was flying airways to ensure
terrain clearance and make it easier on me and everyone else.
I went to load a flight plan and on the 480 when you start
with a fix and then choose an airway, you can automatically
scroll through many optional routes, and it has them drawn
on the screen. Then when you select one, it loads that path,
but you only see the major segments until you expand it when
you want ultimate detail. It then shows all of your time to
fixes and everything else. And you hardly had to even add
any points to the route, to have even a 20 point route entered.
I would probably have to actually read the manual and practice
with it for 20 minutes to get good at it. I find the Chelton
flight planning to be top notch, so it's hard to get motivated
on the 480, but I'm really screwing myself if I don't....so
that's a New Year's resolution for me. The 480 does lots
of things that I haven't even yet touched.
Rob Kermanj wrote:
| Quote: | I started the subject of 430 vs 480 and wanted to thank everyone for
Rob Kermanj
> <mailto:apilot2(at)gmail.com>>
> or IFR.
> On 12/15/06, W. Curtis <wcurtis(at)core.com <mailto:wcurtis(at)core.com>> wrote:
>> never)
>> can't enter
>> on the
>> in MIV
>> flight
>> section in
>> screen.
>> used
>> the 480.
>> in 5
>> years?
>> William Curtis
> * AeroElectric www.aeroelectric.com <http://www.aeroelectric.com>
> www.kitlog.com
Posted: Sat Dec 16, 2006 4:22 am Post subject: Garmin 496 -Antenna |
While some may look down on their statement and see it as a big pitfall,
I see it as proof of how ultimately exacting some of these things
are viewed...and when a manufacturer isn't willing to stick their
neck out into the grey area for you, it just shows you want to
exercise caution. This from all points, including antenna mounting
locations, and such. You want and need great performance out of
these things. I did not find GPS issues with either AHRS system,
and I don't yet have a freeflight GPS. I may actually add on a
freeflight at some point, but it's more for it's value on paper
in my case. I find the built-in GPS does a fantastic job, but
having a 480 next to it just seals it up for me.
Larry Rosen wrote:
Well sort of.
The Chelton system (SV-Sport) is not certified. Built into the Pinpoint
GADAHRS is a GPS. The optional FreeFlight 1101 WAAS GPS has full
integrity monitoring. The Chelton SV-Sport is "based" on their
certified system. The FreeFlight 1101 GPS according to Chelton is the
same as the certified 1201 but without the TSO sticker. So, it is not
certified. I believe it meets the standard, but you can decide for your
self. The closest Chelton will come to saying if you can legally fly
IFR with there system is this, "As an option, add to your SV-10 the
FreeFlight WAAS GPS with full integrity monitoring, and your SV-10 can
be used for stand-alone IFR GPS navigation.
Larry Rosen
#356
Bill Schlatterer wrote:
> <billschlatterer(at)sbcglobal.net>
> Does the Chelton Freeflight have certified a GPS built in? If so back up
> with the 496 is gold, if not it's just two x non-certified.
> Maybe some AIM scholar will weigh in
> Just my .02
> Bill S
> 7a engine
Posted: Sat Dec 16, 2006 4:29 am Post subject: Garmin 496 -Antenna |
thanks.
Rob Kermanj
Here you go Rob.
---------- Forwarded message ----------
From: DOUGPFLYRV(at)aol.com (DOUGPFLYRV(at)aol.com) <DOUGPFLYRV(at)aol.com (DOUGPFLYRV(at)aol.com)>
Date: Dec 15, 2006 4:17 PM
Subject: Re: Garmin 496 -Antenna
I HAVE USED THE 430 IN THE LAST 3 RV'S. NOW HAVE THE 480 AND U R
CORRECT....IT IS MORE COMPLEX, BUT, THE MORE I USE IT AND LEARN IT,
THE BETTER I LIKE IT. IT IS MORE LIKE THE FMS WE USE IN THE CORPORATE
JETS. I AM ALSO GOING TO USE THE 480 IN MY RV10.
GOOD LUCK
DO NOT ARCHIVE
DOUG PRESTON
RV-7A
N196VA
by:
Posted: Sat Dec 16, 2006 4:36 am Post subject: Garmin 496 -Antenna |
One part not often thought about is what you will do after you've filed
/G and the weather got worse than expected. On my trip home from
ElPaso, I was supposed to have 1200' ceilings at my fuel stop in the
middle of the country. What I ended up with was finding that the AWOS
at my planned stop was inop, but local airports that ATC could read off
were showing ceilings varying from 300-1200', and it was solid overcast
up to 6000'. So there was not going to be ANY getting down easy.
I continued on, flying a full approach, figuring that sometimes it's
best to stick with a plan, and be prepared to change it than just
go throwing wrenches into the system right away. I was IMC for
at least 85 miles over the course of the approach. Popped out around
400' ceilings, right at minimums. Had it been worse, I'd now be
looking at a missed and rerouting to another airport for a different
approach. Most 100% certainly not something that you would want
to face even on an emergency approach with a handheld GPS, or
not "made for the job" system software. You certainly don't have
time to run all of the approach fixes into your unit individually.
Now, people could say that I could have made it easier by changing
destinations to the 1200' ceilings. Sure, but now I'd be digging
up the necessary info to do that approach safely, and have to
mentally re-work all of that...unnecessarily. And what would it
have got me....the last 30 seconds of the approach might
have been a little easier. Fact is, even at 1200' ceilings,
there wasn't a way that someone with a handheld was going to
get in safely to that 1200' ceiling airport, without calling
an emergency and trying to do some wacky modified vectored straight
in approach with lots of help from ATC. And then where would your
pilot certificate be once you talked to them on the ground?
You really don't want to file /G unless you're prepared for
the worst with it, because it may have to be proven some day.
I had an interesting situation develop over Atlanta years ago
where I did just this. To my benefit, the handheld did allow
me to navigate direct to a fix, and they didn't bust me even
though I admitted up front it was a VFR ONLY gps (handheld).
I fessed up right away because the weather situation was
pretty bad. No sense leading them on, because that can only
lead to worse things. Once I told them I could go to a
intersection fix, they gave me a list of a couple fixes to
fly. Good thing they only gave me a couple, because it's
not fun to be heads-down in the clouds punching in 5-letter
fixes that you're not familiar with. It all worked out,
but convinced me that if you file /G with a handheld,
some day someone's going to call your bluff.
Be careful out there.
Dan, maybe the local FDSO knows something but it goes deeper than that with
the 396/496. Questions on filing /g with a non-certified unit assume that
it is used only on the enroute phase(not sure it's legal but some do
anyway). I may be wrong on this point, but when you file /g you are telling
ATC that you have equipment on board capable of flying a full GPS approach
and not just the enroute leg. The AIM says that /g means "GPS with enroute
AND terminal capability". Since the 396 and 496 don't show anything other
than the FAF segment, it doesn't appear that you have the "terminal"
capability required to fly the full approach. Until Garmin adds the full
approach procedures to the 396/496 all the other questions would seem moot.
Of course, it is a chicken and the egg thing so maybe if the FDSO loosened
up some, Garmin might add them.
Just my .02
Bill S
7a engine
Posted: Sat Dec 16, 2006 4:47 am Post subject: Garmin 496 -Antenna |
Thanks for the info. Any time someone mentions Chelton, I kick myself!
Do not archive.
Rob Kermanj
On Dec 16, 2006, at 7:17 AM, Tim Olson wrote:
[quote]--> RV10-List message posted by: Tim Olson <Tim(at)MyRV10.com (Tim(at)MyRV10.com)>
Rob Kermanj wrote:
| Quote: | I started the subject of 430 vs 480 and wanted to thank everyone for taking the time to express their opinion. I have to admit that the comments have not made the decision easier. It seems that you get used to the unit and work around what might be regarded as essential by others.
Rob Kermanj
| Quote: | --> RV10-List message posted by: "Kelly McMullen" <apilot2(at)gmail.com <mailto:apilot2(at)gmail.com (apilot2(at)gmail.com)>>
or IFR.
On 12/15/06, W. Curtis <wcurtis(at)core.com <mailto:wcurtis(at)core.com (wcurtis(at)core.com)>> wrote:
screen.
years?
William Curtis
www.kitlog.com
by:
Posted: Sat Dec 16, 2006 4:50 am Post subject: Garmin 496 -Antenna |
What Kelly means is that you enter where you start,
where you're going, and which airway you want,
and often the entire list of segments can be filled
automatically. Or when you're progressively entering
airways, some of which can be hundreds of miles long,
you aren't forced to enter the intermediate fixes...they
are already there, as part of that airway. So you
may be able to enter a couple dozen fixes as one
entry. I see you bouncing back to Kelly that he must
not know the 430 very well. I would say that it looks
like from your end of the discussion that the alternate
is true.
I myself have not spoken much of the 430's limitations and
spent my time trying to turn people away from it. This is
because I haven't got the experience flying behind one enough
to really comment on it at all. Notice I'm limiting my commentary
usually on the 480 to things I've actually punched in and made
work in flight. I'm thinking that if you really don't want to
come across as completely one sided, you either have to be
willing to be open-minded in the discussion, or you have to go
out and spend the due diligence to fly the other system enough
to make yourself qualified to speak on it. Even from my minimal
knowledge of the 480, the below segmenting questions would be
blatantly obvious if you had some good time behind it.
Sorry, but it just irks me when someone with a completely one
sided viewpoint keeps hammering on with a closed mind, when they
don't have experience on the other end. Talk to the points
you know, tell the good about the items you know about, and
any well-known flaws of the other...then leave it at that. The
products need to survive on their merits. It's why you don't
see me bashing the other EFIS systems, but instead just pointing
out the capabilities of what I myself know. If I had spent 10
or 20 hours behind a BMA / GRT / Dynon / AFS / G1000 / Avidyne,
then perhaps I could throw some stones. At this point I'm not
qualified to do so. So honestly, other than your extreme
dissatisfaction with anything that costs $1000 more than the
next thing, exactly why do you like throwing stones and talking
people away from a product that you don't understand the
capabilities of?
W. Curtis wrote:
| Quote: | >Fact remains that you can't enter more than one segment of an
>ahead at a time.
Kelly,
Posted: Sat Dec 16, 2006 5:26 am Post subject: Garmin 496 -Antenna |
[quote]Sorry, but it just irks me when someone with a completely one >sided viewpoint keeps hammering on with a closed mind, when they >don't have experience on the other end. Tim, I understand what you are saying but what you have said is the EXACT thing that got me on this "rant." Which is more on sided and/or inaccurate; any of the things I've stated about the 480 or the below comments about the 430? Comments such as: >>The 430 is designed to go direct and fly an approach. If you fly where >>that is real world it will be great. >>Not to mention the 480 is now cheaper than the 430W and has a bigger >>screen. >>An IFR tool vs a VFR tool. My responses were to show why the above comments were inaccurate. Tell me why you think mine are one sided and closed minded? William Curtis http://wcurtis.nerv10.com/ [quote][b]
Posted: Sat Dec 16, 2006 5:44 am Post subject: Garmin 496 -Antenna |
[quote]Sorry, but it just irks me when someone with a completely one >sided viewpoint keeps hammering on with a closed mind, when they >don't have experience on the other end. Talk to the points >you know, tell the good about the items you know about, and >any well-known flaws of the other...then leave it at that Tim, Please point out to me ANY negative (opinionated or il-informed) comments I've made about the 480? If you look back through my posts you will notice I've only addressed inaccurate statements made about the 430 which I know well. I have never made any of the pointed comments that others have made about a product of which I admittedly know very little. All I've done is attempt to correct misstatements and to you that constitutes "closed minded hammering?" Help me understand this? Do not archive. William Curtis http://wcurtis.nerv10.com/ [quote][b]
apilot2(at)gmail.com Guest
Posted: Sat Dec 16, 2006 6:22 am Post subject: Garmin 496 -Antenna |
On 12/16/06, W. Curtis <wcurtis(at)core.com> wrote:
| Quote: | >Sorry, but it just irks me when someone with a completely one
Tim,
Comments such as:
You haven't refuted the fact that you have to enter each segment,
begining and ending waypoints, same as a VFR direct to handheld.
| Quote: | >>Not to mention the 480 is now cheaper than the 430W and has a bigger
>>screen.
I had seen cheaper prices quoted earlier, Tim confirms the 480 is
available at under $9000, is available with STC, which for TC aircraft
means no local FSDO approval needed, unlike the 430, which reduces
cost for those aircraft, and it is a fact the screen is bigger than
the 430. Lets see what the real price of a 430W becomes. Garmin has
gone back on their $1500 upgrade price at least once, to their credit
they seem to have come back to it, but you still have the hassle of
getting the upgrade separately on somebody else's schedule, not your
build schedule, not your flying schedule. Market prices and relative
prices fluctate every day for many reasons.
The fact the two units are as close as they are in price is surprising.
| Quote: | >>An IFR tool vs a VFR tool.
Airways are the fact of life in most parts of the country for IFR ATC
operations. Being able to call those up on screen is the difference
between having to constantly divide your attention to a paper chart
and not. Just my opinon, obviously not yours. I fly a lot in
mountainous areas where off airway direct often isn't feasible without
going above 15K. Where doglegs in airways are very common, just like
the one around Indiantown Gap in your area, just different purpose.
So pricing has changed on me...the rest of what I said is more
accurate than not, and supported by what others have said, here and
elsewhere.
Posted: Sat Dec 16, 2006 7:04 am Post subject: Garmin 496 -Antenna |
Kelly, Thank you for you comments. I guess the only thing we can conclude is that you like the 480 and I like the 430. What we think is largely irrelevant as the market will ultimately decide. Does this mean you will take the wager:-)? Do not archive William Curtis http://wcurtis.nerv10.com/ [quote][b]
LloydDR(at)wernerco.com Guest
Posted: Sat Dec 16, 2006 7:08 am Post subject: Garmin 496 -Antenna |
The Chelton has two different ones to choose from one with the TSO and
one without.
As for the Portable Garmins, they do have the information, and the
capability to do it, they have just been disabled through software
programming. IE the FAA says do not enable it, and to comply and not
allow the functionality Garmin disabled it from displaying it. The two
things that need to be resolved to using a handheld is consistent power
and antenna placement. Once there is a way to force that then the
software can be enabled, do I think it will happen? No, but we can
always hope. The 496 is definitely a faster processor and screen refresh
rates are great in comparison, they have WAAS, just need the software.
My .02
Dan
Bill Schlatterer
Posted: Sat Dec 16, 2006 7:25 am Post subject: Garmin 496 -Antenna |
Tim, I missed something here! Are you saying the 480 will let you enter an
airway just like you would enter a fix and then give you the closest entry
point. That would be pretty helpful from time to time. I fly a 430 and
have to pull out the chart and find a fix to enter to get to the airway.
Maybe I missed something in the 430 manual as well Realistically, in
the south central states, it seems to be very unusual for ATC to move you
off direct and put on an airway but it does happen. IME
Bill S
dlm46007(at)cox.net Guest
Posted: Sat Dec 16, 2006 7:49 am Post subject: Garmin 496 -Antenna |
The market decides If and only If the products are marketed by different companies. Hence after Garmin bought the only WAAS approved system, competition is eliminated. Garmin marketing will decide which one survives by pricing , development dollars, etc.
rtitsworth
Posted: Sat Dec 16, 2006 7:57 am Post subject: Garmin 496 -Antenna |
William,
Is that the “only” think you can conclude? What about the objective facts? For example, I also concluded that there are functional differences such as “you can’t enter an airway into the 430”. A fact - correct? Why, after all the diatribe, do you brush away all the facts and revert to subjective personal opinion? Worse yet, you revert to public opinion/market economics rather than sound science/engineering? Perhaps a proven political move – but very bad science/engineering!
There was a time when (most) everyone thought the world was flat and/or that heavier than air flight was impossible (oops). Personally, I expect more from the members of this group.
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of W. Curtis
Kelly,
[quote] [b]
rene(at)felker.com Guest
Posted: Sat Dec 16, 2006 8:15 am Post subject: Garmin 496 -Antenna |
My solution to this is simple. I file what the C-182 is equipped with i.e.
/u and them once in route ask for vectors direct and inform the controller
that I have a VFR GPS. Worked great from Jackson Hole to Ogden Utah.
Standard departure, once turned on course given direct to Ogden, then
vectored to the ILS once in the area. No fibbing required. With an MEA of
15,000 feet, the 10 minutes saved leaves me more O2 reserve.
Rene'
801-721-6080
rtitsworth
Posted: Sat Dec 16, 2006 8:21 am Post subject: Garmin 496 -Antenna |
Daniel said: "The two things that need to be resolved to using a handheld is
consistent power and antenna placement"
What about predictive RAIM? I do not know of any handheld with that
required functionality and annunciation (perhaps I am uninformed)?
What about the CDI? To view that on most portables, you need to leave the
map display mode. Seems that the advantages of map based situational
awareness are lost when you do that (i.e. why not then just use a Nav radio
and CDI). Furthermore, the scale of the CDI needs to automatically adjust
based on your position within the approach. I do not know of any handheld
with the capability to do that (perhaps I am uninformed)?
What about approaches with outbound procedure turns and course reversals?
What about DME arcs?
Perhaps my investigation into handhelds has missed something. But it seems
that most handheld inquiries do not comprehend the full functionality suite
of a certified IFR GPS.
rtitsworth
Posted: Sat Dec 16, 2006 8:33 am Post subject: Garmin 496 -Antenna |
More importantly, it will allow you to enter an airway that has turns along
it without needing to enter each intermediate fix (turn). Very nice in
areas where snaking airways are needed to provide terrain and/or airspace
avoidance.
