brucebell74(at)sbcglobal. Guest
Posted: Wed Dec 13, 2006 2:26 pm Post subject: Chutes in the RV-4 |
RV-4 Drivers
Anyone of you used a parachute doing the stall series in your bird? If so
what brand/type did you use? Also what type canopy holder did you have?
Happy Holidays to All!
Bruce Bell
Lubbock, Texas
RV-4 15+ hours
n223rv(at)wolflakeairport Guest
Posted: Wed Dec 13, 2006 5:32 pm Post subject: Chutes in the RV-4 |
I have a mini-softie parachute in my RV-4. I would not recommend it
because it pushes me too far forward, even with the seat back cushion
removed. I think it would work better on the -8 or -7, but not ideal
for the -4.
It is manageable, but not recommended. I'd look at the seat bottom type
chutes (like the seatback softie) if creature comfort in the cockpit is
important. The quality of the chute seems to be real good, but of
course I have not pulled the little handle on it yet to test it 100%
(and that is a good thing!!)
Do not archive.
Lukasczyk(at)gmx.net Guest
Posted: Wed Dec 13, 2006 11:56 pm Post subject: Chutes in the RV-4 |
Hi Bruce
There are only a few parachutes that fit into the RV-4.
The problem is (as always) the limited cockpit-space.
Most of the parachutes available will push you too far forward and the ones with the seat-cushions are usually to big to fit between the seat and the spar. There is a chute that has been especially designed for the RV-4, though.
here is the link
http://www.strongparachutes.com/Pages/paracushion_304.htm
I got it an I do highly recommend it
Happy landings
http://www.rv-4.de/
Thomas, RV-4
Der GMX SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
Ideal für Modem und ISDN: http://www.gmx.net/de/go/smartsurfer
Posted: Thu Dec 14, 2006 4:35 am Post subject: Chutes in the RV-4 |
Hi Bruce-
| Quote: | If so what brand/type did you use? Also what type canopy holder did you
have?
I don't have a -4, but I do still have connections to the skydiving world,
including a friend who had to bail at close to 200'. He's fine, even
though the canopy didn't have a chance to open much. He was using a softie
from Para-Phernalia based upon the recommendation of another friend who was
a long time jumper and still is a rigger. Guess what kind of rigs we have
now? Especially since they do custom work, and I'm 6' 5". Also, aside
from being a very satisfied customer, I have no interest in their business.
Check them out, give them a call. Ask for Dan Tarasievich, and tell him I
sent you. (We chat at OSH each year...)
http://www.softieparachutes.com
Para-Phernalia, Inc.
Toll Free: 800-877-9584
International: 360-435-7220
Fax: 360-435-7272
e-mail: info(at)softieparachutes.com
Mailing Address
P.O. Box 3468
Arlington, WA 98223-3468
Street Address
19018 59th Dr. NE, Unit # 2
Arlington, WA 98223
glen matejcek
aerobubba(at)earthlink.net
n616tb(at)btsapps.com Guest
Posted: Thu Dec 14, 2006 4:59 am Post subject: Chutes in the RV-4 |
It is really hard for me to imagine getting out of my plane while it is not
just sitting on the ground. Then add the possible motion that causes you to
need to get out. Has anybody done this in an RV series of anything?
[quote] --
panamared5(at)brier.net Guest
Posted: Thu Dec 14, 2006 6:21 am Post subject: Chutes in the RV-4 |
| Quote: | It is really hard for me to imagine getting out of my plane while it is not
I fly an RV6 with a slider, and I have tried to open the canopy in flight
and was unable to do so. I mentioned this to another pilot, that if I had
to bail out I wasn't sure I could get out.
His response was pretty simple: "It all depends on how motivated you are!"
As I recall a pilot flying home from the EAA Arlington Flyin had a cockpit
fire and he jumped out, but without a parachute. I may have my facts
wrong, some one on the list who knows for sure should be able to confirm or
correct me.
Bob
wjoke(at)shaw.ca Guest
Posted: Thu Dec 14, 2006 6:53 am Post subject: Chutes in the RV-4 |
I wore a Security 150 parachute during the early testing stages of my
RV-3 - as much for simple seating comfort as anything because I didn't
have the seat cushion arrangements fully completed. The -3 has a similar
cockpit to the -4 in terms of size, space, control stick positioning, etc.
The Security 150 is no longer available (as far as I know) so some
similar alternative will have to be found. Check at your local glider
flying airfields and you may be able to simply borrow something suitable
for a few flights as the chutes used in modern sailplanes tend to be
contour shaped thin packs. Have a look at
<http://wingsandwheels.com/page39.htm> for instance.
(My own Security 150 is more usually used when I am flying my ASW-20
sailplane - another quite elegant flying creation.)
Jim Oke
Wpg MB
RV-3 C-FIZM
ASW-20 C-GPON
Bruce Bell wrote:
RV-4 Drivers
have?
Bruce Bell
Lubbock, Texas
RV-4 15+ hours
LessDragProd(at)aol.com Guest
Posted: Thu Dec 14, 2006 6:57 am Post subject: Chutes in the RV-4 |
Hi All,
How disappointing to hear about the limited cockpit space in the RV-4. I was looking forward to the extra room when I get my RV-4 is finished.
Jim Ayers
RV-3 with long softy parachute
RV-4 structural completed - 90% to go
In a message dated 12/13/2006 11:58:53 PM Pacific Standard Time, Lukasczyk(at)gmx.net writes:
| Quote: | --> RV-List message posted by: "Thomas Lukasczyk" <Lukasczyk(at)gmx.net>
Hi Bruce
here is the link
Happy landings
http://www.rv-4.de/
Thomas, RV-4
Posted: Thu Dec 14, 2006 7:04 am Post subject: Chutes in the RV-4 |
I believe you are addressing an RV-4 incident.
I understand that the RV-4 side hinged canopy wants to open by itself. And it is designed to separate from the airframe when opened.
Jim Ayers
In a message dated 12/14/2006 6:25:45 AM Pacific Standard Time, panamared5(at)brier.net writes:
| Quote: | --> RV-List message posted by: Bob <panamared5(at)brier.net>
correct me.
Bob
Posted: Thu Dec 14, 2006 7:24 am Post subject: Chutes in the RV-4 |
Jim,
Don’t take this out of context. I was only referring to exiting when the plane is in motion. I get in and out of my -6 just fine, and feel totally comfortable in there. If I need to turn around to set my oxygen or anything while flying the plane is all over the place. I was trying to imagine trying to exit the plane with it flying out of control and the wind coming in (no canopy). This would have to be a crazy moment. Of course it already was if I am trying to get out while airborne.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of LessDragProd(at)aol.com
Sent: Thursday, December 14, 2006 8:57 AM
To: rv-list(at)matronics.com
Subject: Re: RE: Chutes in the RV-4
Hi All,
Jim Ayers
Hi Bruce
here is the link
Happy landings
http://www.rv-4.de/
Thomas, RV-4 |
| Quote: | | www.aeroelectric.com | 0123456789012345
skylor4(at)yahoo.com Guest
Posted: Thu Dec 14, 2006 8:48 am Post subject: Chutes in the RV-4 |
This was actually an RV-8. Von Alexander.
Here's the NTSB link:
http://www.ntsb.gov/ntsb/brief.asp?ev_id 001212X19358&key=1
Skylor
--- LessDragProd(at)aol.com wrote:
opened.
Jim Ayers
Standard Time,
series of anything?
may have my facts
correct me.
Bob
Cheap talk?
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Thu Dec 14, 2006 10:08 am Post subject: Chutes in the RV-4 |
No, he had it right. It was an RV-8 that had just won a craftsmanship award at Arlington. He did make it out of the airplane. It’s not completely clear, but I think he had installed quick-release pins at the front canopy track rollers. He had asked about and discussed getting out of his RV-8 in flight on this list while bulding. That the week we lost two RV list members at or going home from Arlington. The other was the take-off accident and fire that killed a new RV-6A owner.
Terry
Sent: Thursday, December 14, 2006 7:03 AM
Jim Ayers
correct me.
Bob |
ronlee(at)pcisys.net Guest
Posted: Thu Dec 14, 2006 11:50 am Post subject: Chutes in the RV-4 |
At 11:05 AM 12/14/2006, you wrote:
| Quote: | No, he had it right. It was an RV-8 that had just won a craftsmanship award at Arlington. He did make it out of the airplane. It’s not completely clear, but I think he had installed quick-release pins at the front canopy track rollers. He had asked about and discussed getting out of his RV-8 in flight on this list while bulding. That the week we lost two RV list members at or going home from Arlington. The other was the take-off accident and fire that killed a new RV-6A owner.
Terry
Was the 6A accident a first flight or a new owner who had no time
in a 6A? There is no excuse for not getting time in an RV before you
fly your own.
Ron Lee
aerokinetic(at)sbcglobal. Guest
Posted: Thu Dec 14, 2006 12:46 pm Post subject: Chutes in the RV-4 |
>>>>>>http://www.rv-4.de/
Thomas, RV-4
Great Site Thomas! Really enjoyed looking through it. Videos are great!
Scott
RV-4 N4ZW
Terry Watson
Posted: Thu Dec 14, 2006 1:11 pm Post subject: Chutes in the RV-4 |
No, it wasn’t his first flight. Don Corbit (I hope I spelled his name right) had bought the plane maybe a week or two earlier and had flown it all over the state in that time. He was scheduled for transition training the weekend after Arlington. I recall that he was hurrying to get off the airport before the runway closed for the air show. There was some speculation that he hadn’t made sure the stick was free during a rushed preflight, since he entered a very steep climb right after takeoff. Others on the list, most likely Jerry Springer, might have more first-hand knowledge of the circumstances.
Don was a very bright and capable guy. At 38, he was a retired Microsoft millionaire and had four little kids. I met him and rode with him a few weeks earlier when he rented a Cessna 182 and made his first instrument flight after getting his ticket, flying from Seattle’s Boeing Field to the fly-in at Scappoose, Oregon, where he got his first RV ride. My photo of Don with his huge RV grin was likely one of the last taken of him.
The whole sad story is in the RV list archives. We lost more than most realize when we lost Don. He spent most of his time at Scappoose talking to RV pilots about what they would want in electronic instrumentation in their airplanes. Don was a software guy and I think his wife was (is) an electrical engineer. They had ideas and the money and brainpower – and the ambition to make them work.
Terry
<snip>
fly your own.
Ron Lee [quote] [b]
John.Morrissey(at)csiro.a Guest
Posted: Thu Dec 14, 2006 5:47 pm Post subject: Chutes in the RV-4 |
Hi Guys,
With the exchange rate the way it is maybe you might like to look at an
Australian product, I spent many hours siting on one of these in L13
Blaniks so I know their comfortable.
http://www.parachutesaustralia.com/s2/prod_emer_thnbk.php
Cheers
John Morrissey
RV-4
