Posted: Mon Dec 11, 2006 9:19 am Post subject: Shielded wire. |
Is it important to not only shield headphone jack and mic jack wire, but to
also use a shielded wire for the strobe wire run...perhaps to keep the
energy inside the wire????????
Having truoble getting through all the reading material while building. Only
so much time in a 24 hr, seven day week.
JOhn G.
Rick S.
Posted: Mon Dec 11, 2006 10:33 am Post subject: Shielded wire. |
John,
The strobe wires are sheilded, 4 wire stuff with a foil sheild and one bare, one white, one clear, one red and one black. The wire came with my strobe package from Creative Air.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
bob.kaufmann(at)cox.net Guest
Posted: Mon Dec 11, 2006 9:40 pm Post subject: Shielded wire. |
Well there you have it, John you have not bought the week stretcher. You
can get it from either Stein, Avery or Cleveland and the price is only $450
for the economy version. It gives you a 27 hour day and an 8 day week.
Rick Sked bought one a year ago and has had great success with it.
Bob K
To thrifty to buy a week stretcher. Still working the 168 hour week. Do
not archive.
LarryRosen
Posted: Tue Dec 12, 2006 5:38 am Post subject: Shielded wire. |
The special 4 wire shielded wire is for the runs to the strobe heads.
How about the power and grounds to the strobe power supply?
Just Tefzel wire?
Local ground or run a wire back to the ground block on the fire wall?
Larry
#356
Rick wrote:
John,
Rick S.
40185
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
Rick S.
Posted: Tue Dec 12, 2006 6:33 am Post subject: Shielded wire. |
I used good o'l Tezfel like all the other parts but can't vouch that there is not an issue because I haven't flown it yet but I did carry the ground forward to the common single point on the firewall. The high volts are only carried out to the actual strobe, depending on your setup the power supply uses either 12 or 24 volts input. I have connected all my grounds to a single point up front except for the no noise resistance operated items like standard filament lights, pitot heat, stick grip warmer, seat warmers and rear window deicers
Rick S.
40185
RV-10
40185 |
Posted: Tue Dec 12, 2006 9:42 am Post subject: Shielded wire. |
Sometimes when I start feeling overwhelmed and that I was crazy to start
this project, I think about the other six hundred other crazy souls out
there all connected by this email group, and it makes me feel a little
better.
Kind of like when I was in the middle of my four years in dental school with
finals week and thirteen finals and four practical to take in one week. I
think we only had sevety nine in our class. It is a little better with this
insanity.
I think this would be a really fun project if I could just work on the
plane.
John G.
[quote]From: "bob.kaufmann" <bob.kaufmann(at)cox.net>
Subject: RE: Shielded wire.
Date: Mon, 11 Dec 2006 21:39:22 -0800
Bob K
not archive.
