danny shepherd
Joined: 27 Jan 2006 Posts: 117 Location: north Wales, United Kingdom
Posted: Sat Dec 09, 2006 5:45 am Post subject: avionics cut outs |
Hi All,
I'm just getting to the point of digging deep into the
proverbial pocket and order the avionics. I was thinking of fitting the
Becker 4201 and the Filser TRT 600. both these units require 2 1/4 in
cut outs in the avionics panel. I have the aluminum removable panel from
Europa. My question is, whats the best way of cutting the holes ? and
whats your opinion of these two units ? I know we don't have to fit mode
S yet, but I fear it's coming !!
Cheers Danny G-c.e.r.i
hagargs(at)earthlink.net Guest
Posted: Sat Dec 09, 2006 7:25 am Post subject: avionics cut outs |
Find someone with a numerically controlled water jet machine. I had both
my radio subpanel and instrument panel done for $70. With a water jet
there is not tool changing and no need to do any deburring, all edges are
smooth. The unlikely place I found a water jet was next to the cemetary
at the place that sold tombstones. The granite tombstones are engraved
with a waterjet. I was fortunate that I use Auto CAD at work so that is
where the majority of the work comes from. Once drawn up the file is
downloaded to the jet. The machine is turned on and you watch it do its
job. cutting all screw holes and shaping the panel.
Steve Hagar
A143
Mesa AZ
Steve Hagar
rparigor(at)suffolk.lib.n Guest
Posted: Sat Dec 09, 2006 1:27 pm Post subject: avionics cut outs |
Hello Danny
I have a Becker 4201 and TRT250. Also using a PS Engineering PMA-4000-IRS
audio panel.
Sorry but can't help out with using 4201, havn't yet fired it up.
I used a flycutter to cut holes, think I purchased it from Aircraft
Spruce.Be prepared to get dirty, I used a cutting fluid that was Lard, but
whatever you do keep it plenty wet.
You need a piece of alloy to practice on to get hole sized proper.
Anticipate which way loads will be on tool, and load the tool before
tightening. This will put in your favor chance of size change is minimal.
Cut it out on a piece of nice flat plywood, and clamp, have pilot hole
already drilled.
If you are having a problem getting proper size, I used a caliper to
measure from other side of guide drill to cutting tip. Go slow as you can
with cutter speed and keep the bit cutting, keep the cutter sharp, I used
stone and lard every half dozen cuts to keep razor sharp, this will limit
chatter.
A few other ideas, I installed a UMA light wedge to match the
electroluminescent on the rest of panel.
I also used countersunk hardware, gives a nice finish. I used either Torx
Safety, torx or allen stainless hardware purchased from www.mcmaster.com.
I fooled with sandblasting hardware heads and it looks nice, if i hate it,
could easily paint.
Another issue I had with my Instrument module is the polyester layup was
not very well bonded to the wood. When trying to cut out the wood for
insert clearance, the stuff easily delaminated. I found by installing
nutplates which use aluminium flush pop rivets, and adding flush rivets
between the nutplates it held things much more better in place!
Hope this helps.
Ron Parigoris
danny shepherd
Posted: Sun Dec 10, 2006 3:31 am Post subject: avionics cut outs |
Thanks, Steve,Peter, Ron and all.
Plenty of food for
thought there. The good thing about these aluminum panels is, if I do
c*ck it up, there reasonable cheep to replace !!!
Cheers Danny G-c.e.r.i.
topglock(at)cox.net Guest
Posted: Sun Dec 10, 2006 8:13 am Post subject: avionics cut outs |
Danny,
There are several ways to accomplish the task. Water cutting is the
most desirable, and is extremely accurate. Laser will also work, though
not usually as nice a cut. Pre-sized hole punches do a very nice job,
but are ususally pretty expensive, so if you're are not planning to do
several panels, or rent the tools out, you might not want to go that
route. Then there thers's the old standby, the hole saw, used in a
drill press. A bit more work, but satisfactory results can be had, if
you're careful. If like some of us, you end up changing your panel 2 or
3 times, adding this and that, you might want to give this a try. My
panel is built from .063 aluminum and I changed it up several times,
before I was happy with it. The hole saw did just fine after I learned
the secret of getting smooth cuts. If you go this route, just take your
time and make sure to plan your panel precisely. Good luck.
Jeff - Baby Blue
245 hours
danny(at)mcwalterscafe.co.uk wrote:
Quote: |
<danny(at)mcwalterscafe.co.uk>
Hi All,
the Becker 4201 and the Filser TRT 600. both these units require 2 1/4
in cut outs in the avionics panel. I have the aluminum removable panel
from Europa. My question is, whats the best way of cutting the holes ?
and whats your opinion of these two units ? I know we don't have to
fit mode S yet, but I fear it's coming !!
danny shepherd
Posted: Sun Dec 10, 2006 9:07 am Post subject: avionics cut outs |
Thanks for your reply Jeff. I think I might order a spare panel, er.....
just in case !!!
Danny
Rman wrote:
Quote: |
Danny,
though not usually as nice a cut. Pre-sized hole punches do a very
nice job, but are ususally pretty expensive, so if you're are not
planning to do several panels, or rent the tools out, you might not
want to go that route. Then there thers's the old standby, the hole
saw, used in a drill press. A bit more work, but satisfactory results
can be had, if you're careful. If like some of us, you end up
changing your panel 2 or 3 times, adding this and that, you might want
to give this a try. My panel is built from .063 aluminum and I
changed it up several times, before I was happy with it. The hole saw
did just fine after I learned the secret of getting smooth cuts. If
you go this route, just take your time and make sure to plan your
Jeff - Baby Blue
245 hours
> Hi All,
> 1/4 in cut outs in the avionics panel. I have the aluminum removable
> panel from Europa. My question is, whats the best way of cutting the
> holes ? and whats your opinion of these two units ? I know we don't
> have to fit mode S yet, but I fear it's coming !!
simon.miles(at)skynet.be Guest
Posted: Sun Dec 10, 2006 12:25 pm Post subject: avionics cut outs |
Er, when I needed to make the holes for my Filser transponder and radio
I just scribed the positions on the Europa supplied piece of Aluminium,
drilled out approximately around my scribe lines, and carefully filed
out until the units fitted. It took about 30 minutes for each. Have I
missed something?
Simon Miles
Europa 508.
g-iani(at)ntlworld.com Guest
Posted: Mon Dec 11, 2006 2:19 am Post subject: avionics cut outs |
All this talk of water jet and laser cutting is OK but you have to have
the service handy and it takes days by the time you have delivered and
collected. Drawing what you need in CAD first is a good idea and can
help spot the mistakes. If you have the CAD drawing, and the service
available then by all means use it.
I am surprised that so many people seem reluctant to hand cut metal.
The following works just as well:-
Protect the surface with masking tape. Mark the cut-out you need. Drill
one (or more) holes to allow jig saw blade through. With variable speed
jig saw, and the correct blade, you can carefully saw round the shape in
two minutes. Clean this up with a half round file (or drum sander) and
the job is done.
Does anyone have a use for a number of (just under) instrument size
aluminium disks?
Ian Rickard #505 G-IANI XS Trigear
Europa Club Mods Rep (Trigear)
e-mail mods(at)europaclub.org.uk
or direct g-iani(at)ntlworld.com
Posted: Mon Dec 11, 2006 10:19 am Post subject: avionics cut outs |
Hello Ian
I agree that traditional machining of panel is a viable means of
accomplishment. Once laid out, a flycutter works great. I takes just a bit
of diddling to get size correct, but once it is, do all those hole sizes.
If you are not doing all at once, flycutters are fair cheap, just buy 1
for each size and don't bother adjusting.
We got our panel cut first try on both, I tried to attach a pic.
We laid out entire panel with full sized copies of instruments to make
sure all fits as a first pass, then machined the trouble spots first which
dictated where the remainder will be placed.
"anyone have a use for a number of (just under) instrument size aluminium
disks?"
Yes a toy for kids of all ages, for younger kids blunt sharp edges and
glue string in center of hole, a good alternative for button / accordion
/spinner. You can polish to a high luster if you wish, or chuck up a #2
pencil and make some Spirit of Saint Lewis swirls with the eraser.
Good test pieces for a try at 3 BID Epoxy layup compared to a 1 BID Redux
with peel ply and 2 subsequent BID Epoxy
If you make a pyramid out of them all progressively smaller, you could
make the 3 pin game where you need to move entire stack to another pin
without ever putting a larger on a smaller. Secret is keep the smallest
always going either clockwise or counter clockwise, start with 3, then 4,
it begins to require a lot of moves.
Good test for bonding ability of Rapid epoxy compared to JB Weld long
Cure, and JB Kwik for those who can get it.
Vise protectors for small parts.
Shims for leveling when machining stuff.
Ron Parigoris
Description: |
Filesize: |
428.81 KB |
Viewed: |
154 Time(s) |
Posted: Mon Dec 11, 2006 6:52 pm Post subject: avionics cut outs |
Ron,
Good photograph of your panel. I see you have the Becker xpndr and radio.
That is what I put in my plane and have been nothing but happy with them.
I'm surprised more people aren't using them. they're compact and I am told
have a good reputation.
Steve Hagar
A143
Test flying 24 hrs.
Steve Hagar
