Mark Phillips in TN
Joined: 10 Jan 2006 Posts: 431 Location: Columbia, TN
Posted: Fri Dec 08, 2006 8:50 am Post subject: New Topic! Wire label-making machines |
In a message dated 12/07/2006 10:37:52 PM Central Standard Time, stein(at)steinair.com writes:
| Quote: | | I'm really confused and boggled |
Stein- what do you guys use to label your wires? I've used Brady lablemaker pro (dot matrix through ribbon) but machine is T-up and looking for replacement, preferably one that prints shrink tube. One RV-lister recommended the Dymo Rhino Pro 5000. Any other recommendations out there from actual users of one of these type machines?
And no, I'm not printing & cutting out itty bitty labels and slipping them into little pieces of clear shrink tube- I need a one-shot machine to get this done and move on...
Mark
_________________ From The PossumWorks... |
rvbuilder(at)sausen.net Guest
Posted: Fri Dec 08, 2006 10:18 am Post subject: New Topic! Wire label-making machines |
Mark,
I have the Dymo. Works good, lasts long time. J Prints on a shrink tube also.
Michael Sausen
-10 #352 Fuselage
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Fiveonepw(at)aol.com
Sent: Friday, December 08, 2006 10:50 AM
Subject: New Topic! Wire label-making machines
Mark
| Quote: | | www.aeroelectric.com | 0123456789012345
Posted: Fri Dec 08, 2006 10:56 am Post subject: New Topic! Wire label-making machines |
Michael,
Which one, where'd you get it, how much....yada yada?
Ralph
Most of my wiring's done - little pieces of laser printed paper stuffed into shrink tubes......
Mark Phillips in TN
Posted: Fri Dec 08, 2006 12:05 pm Post subject: New Topic! Wire label-making machines |
In a message dated 12/08/2006 12:59:19 PM Central Standard Time, recapen(at)earthlink.net writes:
| Quote: | | Which one, where'd you get it, how much....yada yada? |
Hi Ralph- Mark here. I'm leaning toward the 3000, since I can't see anything very useful on the 5000 that the cheaper one doesn't do. Look at:
http://www.pricegrabber.com/search_getprod.php//masterid=15433815
Looks like a pretty decent product/prices. One thing I don't like about them is that they seem to print the label only once on one side of the tube- Brady labels I've used before would print 3 or 4 times across the width of the label (sticker, not tube), then it would wrap around the wire, making the number visible from all sides- pretty handy. Still looking...
Mark do not archive
Posted: Fri Dec 08, 2006 1:30 pm Post subject: New Topic! Wire label-making machines |
Thanks - I'll check it out too!
dsvs(at)ca.rr.com Guest
Posted: Fri Dec 08, 2006 6:37 pm Post subject: New Topic! Wire label-making machines |
Try the K-Son #2011xlb available from www.magesupply.com it is a little expensive at $319 but I have the one it replaces and I would not give it up. You can get tubes for any size wire you use in an airplane. Don
[quote] --
aadamson(at)highrf.com Guest
Posted: Fri Dec 08, 2006 6:55 pm Post subject: New Topic! Wire label-making machines |
Probably that link needs to be www.imagesupply.com and the model needs to be the 2012xlb (don't think the 2011 support tube tape at least not from the imagesupply website anyway...
FWIW,
Alan
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of Don Vs
Sent: Friday, December 08, 2006 9:37 PM
Subject: RE: New Topic! Wire label-making machines
[quote] --
I believe you can do that with the 5000 and regular labels. It’s at my shop still packed up or I would check for sure.
Michael
Sent: Friday, December 08, 2006 2:00 PM
Subject: Re: New Topic! Wire label-making machines
Mark do not archive
Posted: Fri Dec 08, 2006 7:12 pm Post subject: New Topic! Wire label-making machines |
Right on both counts, sorry about that. Don
[quote] --
flyboy494
Posted: Fri Dec 08, 2006 7:33 pm Post subject: New Topic! Wire label-making machines |
Brady makes excellent equipment for wire marking among other things. Check out this website.
http://www.bradyid.com/
Kent
---- Don Vs <dsvs(at)ca.rr.com> wrote:
[quote] Right on both counts, sorry about that. Don
sarg314(at)comcast.net Guest
Posted: Sat Dec 09, 2006 2:14 pm Post subject: New Topic! Wire label-making machines |
This outfit has the rhinopro 3000 for $65. Says it prints on heat shrink.
| Quote: | http://www.provantage.com/dymo-15605~7DYMO02H.htm
