gordod(at)ca.ibm.com Guest
Posted: Sun Jan 29, 2006 6:37 pm Post subject: matco brakes |
Hello all,
I have a few questions on 601hd brakes. I am installing matco wheels and
brakes.
1) I have looked at several pics and noticed the bleeder screws at the top
of the caliper on some planes and the bottom on others is one way correct ?
2) On the install Kit from ZAC you get 3x 90 degree elbows and 1x180
degree. I put the 180 on the right pilot pedal is this correct (I only have
the plans no assembly documentation)
3) What brake fluid should I use. Will Dot 5 silicon based be OK ?
Thank You
Gord O'Donnell
Gordod(at)ca.ibm.com
daveaustin2(at)sprint.ca Guest
Posted: Mon Jan 30, 2006 6:03 am Post subject: matco brakes |
Gord,
I put the bleeder at the bottom so that I could fill the system using the
"pump from the bottom" technique. Worked well and kept the bubbles out.
I also used Dot 5 with no problems for 12 years.
Dave Austin 601HDS - 912, Spitfire Mk VIII
Sigmo(at)aol.com Guest
Posted: Mon Jan 30, 2006 7:00 am Post subject: matco brakes |
You can move the bleeder screw to the bottom, it makes no difference which
side it's on. I was told to use 5606 hydraulic fluid and it works just fine.
Mike Sigman
N7092N 601XL
Larry McFarland
Joined: 10 Jan 2006 Posts: 36 Location: East Moline, Illinois
Posted: Mon Jan 30, 2006 7:54 am Post subject: matco brakes |
Gord,
The brakes are easiest to install in the orientation shown on this
link. Brake assembly shown inside, low and angled to the rear.
This puts your hose connection up and the bleeder down. Also makes axle
disassembly for inspection or tire repair much
easier for handling spacers, washers etc. Keeps the assembly inside
wheel fairings if you plan to use them.
http://www.macsmachine.com/images/gear/full/pantforkbracketrh.gif
Larry McFarland - 601HDS at www.macsmachine.com
Gord O'Donnell wrote:
Quote: |
Hello all,
brakes.
Thank You
Gord O'Donnell
_________________ Larry McFarland - 601HDS - Stratus |
Larry McFarland
Posted: Mon Jan 30, 2006 8:16 am Post subject: matco brakes |
Gord,
DOT 5 is what is recommended for Matco brakes. Bleeder screws are
better placed downward
to avoid putting the drained fluids on the brakes at disassembly. Also
you need to maintain the strength of the
fork, so angling the brake assembly back at 45 degrees will help with
that. I used 90s on the cylinders to
permit the hoses to curve thru 270 degrees while returning to the hard
lines at the center console.
In this manner, it works fine. See links below,
http://www.macsmachine.com/images/wheelfairings/full/fairingbrakefit.gif
http://www.macsmachine.com/images/controllinkages/full/fuelshutoff2.gif
http://www.macsmachine.com/images/controllinkages/full/arudder.gif
http://www.macsmachine.com/images/controllinkages/full/steer-rod-air-barrier.gif
Quote: |
Hello all,
brakes.
Thank You
Gord O'Donnell
