Eggenfellner
Goto page Previous  1, 2, 3, 4, 5  Next
LloydDR(at)wernerco.com
PostPosted: Tue Dec 05, 2006 7:19 am    Post subject: Eggenfellner Reply with quote
Kelly
Exactly what you are discussing has started to be experimented with on
the Eggenfellner package. They have a wide band O2 sensor that they are
using to change fuel pressure settings to get the best performance to
fuel burn. You are correct that it can vary widely with very little
performance gain, but it is in the works, giving the pilot the ability
to control closed loop versus open loop on the stock ECM. But Jan has
now contracted to get a custom built ECM for the package that will take
advantage of the fuel mappings that are being tested. So the best power
to fuel burn will be able to be set and modified as needed. Much like
GAMI, but without the need to change injectors, instead the timing
pulses on the EFI will be modified.
Robert Paisley can talk more about this, as he is the one doing the
testing and development on it.
Dan
PostPosted: Tue Dec 05, 2006 7:22 am    Post subject: Eggenfellner Reply with quote
Just to stir the discussion and make it boil over.....Do not spend the
extra money to get Sirius built in the portables are cheaper, and XM is
better anyway. Most of us will be using a portable Garmin and can get
the XM included in the plan, and use the aux Jack to get the music over
to the intercom.
Hey, we have not had a primer war in awhile, so lets start an XM versus
Siruis discussion...
Dan
PostPosted: Tue Dec 05, 2006 7:25 am    Post subject: Eggenfellner Reply with quote
No you are right, getting in a crew car and driving down to the auto
parts store, that in major cities are open 24x7, buying the parts and
fixing the engine yourself would be just too easy right? Most FBO's do
not stock the parts you are likely to need in the event of a major
failure, but most auto parts stores have just about every part you need
to fix a Subaru engine.
Just stirring the pot some more...
Dan
jesse(at)itecusa.org
PostPosted: Tue Dec 05, 2006 7:49 am    Post subject: Eggenfellner Reply with quote
We have not had a primer war in a while? I think this engine thing is
bigger than primer ever was. I think we should start calling the primer
discussion an Engine War.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
deej(at)deej.net
PostPosted: Tue Dec 05, 2006 7:50 am    Post subject: Eggenfellner Reply with quote
Tim Olson wrote:
> You see, it's this exact type of inquiry that completely confuses
> me. If someone is looking at it where safety is their #1 concern,
> then the engine choice is much much more obvious than the guy
> who wants to experiment. The "old" engines, when run properly,
> with well built planes, have an extremely, EXTREMELY reliable
> track record.
The interesting thing is that one of the reasons I am considering a
Subaru is that safety is one of my major concerns. I keep reading on
various mailing lists about the "reliability" of Lycoming and related
engines, but nearly every time I stop by my local FBO maintenance shop
there is one there having some sort of top end work done on it. I've
personally had to have cylinders replaced on a Continental O200, and
valves worked on a Lyc O320, and I don't have all that much flying
time. Somewhere there is a disconnect between the perceived
"reliability" of Lycomings and what I have seen personally in the Real
World. Granted, my data set is small, but I cannot imagine that my shop
is the only one in the world that is getting all the "unreliable"
Lycoming engines to work on.
We don't yet have tons of air time on the Subaru packages, but what
time we do have tends towards showing that the Subaru is a very reliable
airplane package. There are hundreds of thousands (maybe millions?) of
hours of Subaru engines in automobiles, SUVs, and racing applications,
and to me at least (my opinion) the core engine is not in question in
the slightest - it is tough, reliable, and extremely well designed.
The only question I have left is whether the PSRU (gear reduction
unit) will be as reliable as the engine, but so far from the hours
already flown, the Egg PSRU seems to be a very good and reliable
performer. Time will tell if this continues to hold true.
-Dj
indigoonlatigo(at)msn.com
PostPosted: Tue Dec 05, 2006 7:59 am    Post subject: Eggenfellner Reply with quote
Daniel,
You are like the last pillar standing and I am at the foundation helping to
hold you up. Interestingly enough, the others don't know it, but you are
doing it for everyone(Let us remember that). I hope it works out for you, I
am right behind you.
Call me cheap, but the most expensive vehicle I own, aside from my glider is
my F-250 four door diesel purchased in 2001 at $36K. That comes with an
engine, body, upholstery, the works. More importantly I drove it home the
day I bought it.
These aircraft engines, way over $40K brand new, without the special
ignition, (I think)without alternator, without Gami. This is nuts IMO! I
just can't get over it. I really like spending money on fine items like
handcrafted all molded RC gliders, things that are high quality, fine
tolerances, last forever type stuff, so I don't think it is called cheap,
just some kind of hurdle I can't seem to clear.
I think Eggenfellners are too expensive also, but when you look at the
amount of work he has done putting everything together, he deserves to make
a living too.
John G.
Absolutely no DIG to anyone, my own issue, verbalized.
Do NOt Archive
[quote]From: "Lloyd, Daniel R." <LloydDR(at)wernerco.com>
Subject: RE: Eggenfellner
Date: Tue, 5 Dec 2006 10:25:07 -0500
Dan
Jack.Phillips(at)cardinal
PostPosted: Tue Dec 05, 2006 8:02 am    Post subject: Eggenfellner Reply with quote
Yeah, since I've got a Lycoming O-540 sitting in a crate in my basement,
if an email comes with the title "RV10 List: Eggenfellner", I just hit
"Delete"
Jack Phillips
#40610
Elevators
mike(at)learningplanet.co
PostPosted: Tue Dec 05, 2006 8:05 am    Post subject: Eggenfellner Reply with quote
I have to say that this was one of the most civil and grown up "wars" that I've ever seen on the lists. I commend those of you who provided your opinions without resorting to the typical flame tactics. It was a very informative discussion.
Mike Schipper
RV-10 #40576 - Wings
http://www.rvten.com
Do not archive. [b]
Rhonda(at)bpaengines.com
PostPosted: Tue Dec 05, 2006 8:08 am    Post subject: Eggenfellner Reply with quote
DJ:
The main reason that most engines need top end work done is from getting
the engine too hot and glazing the cylinders, not really from a design
or manufacturing defect. Another common problem is corrosion of the
cam/tappets due to lack of flight time. The best way to keep your
engine in tip-top shape and eliminate those problems is to fly the heck
out of it, avoid long run-ups on the ground and change the oil.
Rhonda
pitts_pilot(at)bellsouth.
PostPosted: Tue Dec 05, 2006 8:23 am    Post subject: Eggenfellner Reply with quote
Aw c'mon .... you can't be Sirius!!! Oh, that is what you said!!! Very Happy
Linn
Lloyd, Daniel R. wrote:
[quote] [quote]--> RV10-List message posted by: "Lloyd, Daniel R." <LloydDR(at)wernerco.com> (LloydDR(at)wernerco.com) Just to stir the discussion and make it boil over.....Do not spend the extra money to get Sirius built in the portables are cheaper, and XM is better anyway. Most of us will be using a portable Garmin and can get the XM included in the plan, and use the aux Jack to get the music over to the intercom. Hey, we have not had a primer war in awhile, so lets start an XM versus Siruis discussion... Dan --
deej(at)deej.net
PostPosted: Tue Dec 05, 2006 8:25 am    Post subject: Eggenfellner Reply with quote
Rhonda Bewley wrote:
DJ:
Rhonda
Hi Rhonda,
No real argument as to why the problems happen, I just find it
interesting (and somewhat amusing) that one of the strong arguments that
people use for choosing a Lycoming is the claimed "reliability", but yet
there are all these problems that seem to be occuring which indicates to
a neophyte like myself that they really aren't all that reliable after
all.
If the Subaru engine is treated the same way as the Lyc, I'm not
convinced that we will see any more problems with it than the Lyc has,
but that is just my own opinion with no actual data to back it up. The
more brave souls that gather the Subaru data for us, the better to make
my decision down the road... Smile
-Dj
PostPosted: Tue Dec 05, 2006 8:30 am    Post subject: Eggenfellner Reply with quote
--> RV10-List message posted by: "Rhonda Bewley" <Rhonda(at)BPAENGINES.com> (Rhonda(at)BPAENGINES.com)
DJ:
I don't think that's entirely true. I think most of the wear is due to rusting of the cylinders because the A/C wasn't being flown often enough nor hard enough.
Another common problem is corrosion of the cam/tappets due to lack of flight time.
This is true! Directly related to the comment above!
Amen! This is the best advice I've seen on this thread!!!
Linn
[quote] [quote] Rhonda --
PostPosted: Tue Dec 05, 2006 8:35 am    Post subject: Eggenfellner Reply with quote
It is called "evolution" of the enlightened individual.
Some day our goverments might learn to do the same. We need to send the old
guys who make policy to fight the wars. "I looked deep into his eyes, but
them he hit me"
Sorry, I couldn't resist. It stil lis a very complex world. No denying that.
From: Michael Schipper <mike(at)learningplanet.com>
Subject: Re: Eggenfellner
Date: Tue, 5 Dec 2006 10:04:19 -0600
Mike Schipper
>Do not archive.
PostPosted: Tue Dec 05, 2006 8:38 am    Post subject: Eggenfellner Reply with quote
Would it not be safe to say that if you drive by a Subaru dealership (or any
repair shop, for that matter) that they won't have most of their bays filled
with cars getting some kind of work done on them. In my experience they
seem to be fairly full. Does that mean that car's aren't reliable? I think
that means that engines eventually need to be fixed. Some new ones have
problems, more old ones have problems. Check out an early 80's
just-about-anything and it probably has been in the shop a number of times.
The engine is N256H has been to right around 4,000 hours before major TWICE
before we got it. New cylinders, new cam and a few new gears and we now
have 300 trouble-free hours on it. As Rhonda pointed out, the first two
times they ran the snot out of it on a flight school Aztec. Now we are sort
of running the snot out of it with 300hrs in less than a year and a half.
This is all not a dog on the Subie, of course, just seeing a few holes in
the logic. Because shops have work to do doesn't mean that they only work
on junk. Just the fact that 50-year-old engines are still flying means that
they are NOT junk IMHO (ie. How many Yugo's do you see driving around
still?).
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
bhughes(at)qnsi.net
PostPosted: Tue Dec 05, 2006 8:45 am    Post subject: Eggenfellner Reply with quote
Linn,
Tracy (Rotary Aviation) is now making a EFI controller for the Lyc. If
it is like the ones for the rotary it can be manually leaned and is a
dual unit.
Bobby
40116
(Rotary with custom everything)
http://www.rotaryaviation.com/eficont.html
rvbuilder(at)sausen.net
PostPosted: Tue Dec 05, 2006 8:58 am    Post subject: Eggenfellner Reply with quote
Keep in mind that there are vastly more Lycomings out there that are
fairly old compared to new or reman'd so it's not unexpected to have
experiences like this. Stop by your local Subie dealer and I bet you
find Subie engines being worked on without a single Lycoming in site.
Smile
I honestly don't expect you would find a huge spread in reliability
statistics when you compare "new" Subie packages to "new" Lycoming
packages. As far as the crank issues everyone loves to point to
recently, this is not a design flaw. 10's of thousands of cranks are
out there without these problems. Some bean counter probably pushed
someone to save some $$ and they made a bad decision to change the
metallurgical recipe of the cranks. Bad decision not related to the
overall design. I personally think it sucks and Lycoming should stop
passing the costs to their customers, but we have no leverage without
alternative engine options whether its from Egg, Eci, Mistral, or
whoever. But let's get one thing straight, the automotive industry is
far from exempt when it comes to making bad decisions to save $$. As a
matter of fact, I think they lead the way in that dept also.
Michael
Tim(at)MyRV10.com
PostPosted: Tue Dec 05, 2006 9:49 am    Post subject: Eggenfellner Reply with quote
Be forewarned, this is in a HUMOROUS tone....
I guess by that rationality, the Subies have an extrordinary safety
record in flight in the RV-10 installations. I've never once
heard of someone having an off-airport landing in their Subie
powered RV-10 before.
"all these problems" just seems so strange to hear. When you count
how many engines are out there, "all these" seems to be similar
to saying "tons of U.S. Airline passenger deaths in the past 2 years"...
just another sensationalist term. As a percentage of engines
out there, it's actually amazing that if you eliminate pilot error,
esp. due to fuel mismanagement, that you're left with an incredibly
small pool of accidents to analyze.
Dj Merrill wrote:
Hi Rhonda,
all.
-Dj
Rick S.
PostPosted: Tue Dec 05, 2006 10:15 am    Post subject: Eggenfellner Reply with quote
I can see the headlines now....
RV-10 Matronics list members charged today in an incident where they severely beat to death an already dead horse...... Wink
I'll bet this topic would not have gone on so long if you had to type "Eggenfellner" each time you replyed!!
How bout them Broncos!!!!
Rick S.
40185
PS-Barrett's XIO-540 due to arrive around the first of March
Rick S.
RV-10
40185
wcurtis(at)core.com
[quote]Yeah, since I've got a Lycoming O-540 sitting in a crate >in my basement, if an email comes with the title "RV10 > List: Eggenfellner", I just hit "Delete" I'm in the same boat and tempted to do the same but I've found this discussion interesting and not a total waste of bandwidth. While I've made my choice, I see the need and rationale for others going the Eggenfellner route. Because if we are to condemn them for following that path then it should follow that those that fly certified ships should also condemn us for the "experimentals" that we fly. That's the nice thing about this endeavour, you can experiment and innovate as much or as little as you are comfortable with. Where would we be if the Wrights had listened to the conventional wisdom of the day when the most esteemed physicist espoused that "heavier than air flight was an impossibility?" I too wish a more modern, less expensive alternative power plant was available. I just paid the equivalent of what I paid for a brand new 2002 MB ML-320 for an TMX IO-540 with one electronic ignition. Without discussions such as this we are doomed to this obscene economic model and there will NEVER be a viable alternative power-plant if we deter those who choose to explore the possibilities in this area. William Curtis http://wcurtis.nerv10.com/ [quote][b]
apilot2(at)gmail.com
PostPosted: Tue Dec 05, 2006 10:27 am    Post subject: Eggenfellner Reply with quote
Why would I have any interest in a do-it-yourself ECU? What I
described is how car manufacturer/EPA approved ECUs work. Building a
plane isn't enough? You want to design code to run the engine most
efficiently for all regimes? Do you have any idea the staff and
resources car companies put into ECU development? Do you think it
really is as easy as MegaSquirt ads claim? Designing one for racing is
a lot simpler..just maximize power output at desired rpm and you are
done. So far, only TCM has a certified FADEC, and quite frankly I
wouldn't want to fly with it. I can operate the engine more
efficiently with manual controls than it will in FADEC mode, because I
can go fast ROP, or go economy LOP and keep the temps where I want
them. If you don't use closed loop O2 feedback, your only other option
for mixture control is EGT, which has much greater lag in response
time, by comparison. Unless you will be certain of always being able
to get unleaded mogas at airports you land at, your O2 sensor will die
on the first load of 100LL. Why would you want electronic injectors
that can fail both electrically or by the usual dirt/varnish plugging?
GAMIs may or may not be needed depending on your luck with Lyc. QC. My
Lyc runs fine with stock injectors LOP. Others won't.
Spark control you can already get the equivalent of automotive in
either the experimental category or the Unison Lasar certified system.
So far the improvements don't appear to be worth the money.
The Lycs and Continentals are extremely reliable when operated
frequently, according to manual...since you asked for an A&P
opinion...I'm only A&P/IA. Or ask the major engine shops what kind of
failure rate they see, what their warranty rate is. If they had the
kind of record you allege, they would be spending huge amounts on
warranty claims and wouldn't stay in business long.
Oh, wait, Rhonda already gave her opinion, which I agree with
entirely. I've owned an aircraft for 31 years. I've done two
overhauls, zero cylinder work, zero top overhauls, in climate from
Alaska to Arizona. Monitor your temps, keep temps conservative and fly
frequently.
Page 4 of 5
