Dual Elevator Cables
Goto page Previous  1, 2, 3
biglar
PostPosted: Sun Dec 03, 2006 1:56 pm    Post subject: Dual Elevator Cables Reply with quote
It's a fair hike from La Posada de Santa Fe to MV, (about 400 miles) but if you stop here en route, I'll scramble to play tour guide for you......and for any other Kolb'ers who may stop by at any time. I've got a few picture stories put together on my activities to and around Santa Fe, so anyone who's interested, let me know and I'll send 'em on to you.   Lar.   Do not Archive.
Larry Bourne
Santa Fe, NM
www.gogittum.com
Larry Bourne
Palm Springs, CA
Building Kolb Mk IIIC
"Vamoose"
pj.ladd(at)btinternet.com
PostPosted: Sun Dec 03, 2006 3:22 pm    Post subject: Dual Elevator Cables Reply with quote
Hi Ed,
sorry if I have inadverdently trodden on your toes..
I think maybe you came into this thread partway through as you seem to have missed the previous posts to which I was replying.
I was certainly not denigrating Kolbs. I have one, and I agree with you that it is well designed, except for the flap handle, and very strong. I shall NOT be fitting dual cables. I was merely continuing a discussion about the differing approaches to legislation in the US and the UK.
The comment about the length of time that was apparently going to be taken in investigating Daves sad accident did not suggest for a moment that we don`t have accidents in greater or lesser numbers than you but merely making the point that if an accident(any accident) occurs then the cause needs to be determined as quickly as possible. If the tail falls off a Rans at 1000 hours and I have 950 hours on mine I would like to know NOW if it is a generic flaw or if the pilot sawed through half the longerons to install an extra fuel tank. Not in six months time when someone has finally got round to it.
Another lister was applauding the fact that in the US you could `do pretty much as you liked`. In fact I think that his words were "you could carve a plane out of cheese and provided the C of G was in the right place it would pass". Apologies if I have misquoted but those were the general sentiments. I was merely commenting. If it is not true dont blame me.
I agree, (we seem to agree about everything Ed, whats the argument?) that regs don`t make an aircraft safe. Design does. But what except regs ensures that a builder follows the design? Also, would you be happy that any designer could market a plane without it being checked by an outside source.? You couldn`t do that here.
In the States you seem to be in the position that you can change much more in the design without permission than we are in the UK. Is that good or bad? I don`t know. I would like to be able to change a prop. or an engine or fiddle with the dihedral or extend the undercarriage legs without getting approval but I have no expertise and the fact that I am willig to take a chance on killing myself should not entitle me to hazard some innocent bystander. We are working slowly towards your approach and I suspect that in time we shall arrive at some middle point.
Incidentally I have had carb icing , twice. Each time it was cleared by opening the throttle. I didn`t just make up the idea. I read it in a book.
I am sorry if you find any of this an attack un the US or on Kolb. Put it down to cabin fever.
Cheers
Pat
PostPosted: Sun Dec 03, 2006 3:48 pm    Post subject: Dual Elevator Cables Reply with quote
Did over regulation, on your side of the pond, prevent further "bad
accidents"?>>
Good question John. I don`t know. On balance I think it probably did. It may
well have stultified some exciting new developments too. Thats the trade
off.
The main thing that happened was that the series of accidents put the whole
sport in jeopardy. Committees were formed etc., and we were lucky enough
that Anne Welch who had cut her teeth on the Gliding movement and was Sec of
the BGA for years took an interest and was able to lay down enough
guidelines that the government handed over regulation to the new committee
instead of running it directly themselves.
Therefore we enjoy pretty much the status of the Gliding Assoc, and
regulate, inspect, instruct etc., ourselves without too much outside
interference.
Cheers
Pat
d-m-hague(at)comcast.net
PostPosted: Sun Dec 03, 2006 5:13 pm    Post subject: Dual Elevator Cables Reply with quote
Pat, there are two sets of regs here. If it's two seats, or over 254 lbs, factory built you can't change much; homebuilt, you have to register it as experimental and go through inspections, test flying in a restricted area, etc. You can change pretty much anything when you build it but you still have to get it approved for flight.
If it's under 254 lbs and single seat (i.e. ultralight), you can do virtually anything... but the ultralight regs prohibit you from flying, at ANY altitude, over any congested area or open air assembly of persons. So our regs DO protect the innocent bystander either way, but you're free to kill yourself flying solo.
-Dana
For every new foolproof invention there is a new and improved fool. [quote][b]
PostPosted: Mon Dec 04, 2006 2:03 am    Post subject: Dual Elevator Cables Reply with quote
once they determine it was a legal ultralight, they leave it up to local law
enforcement to conduct any investigation>>
Hi Dana,
thats interesting. Here an ultralight, inside the ultralight legal spec. is
treated exactly like any other aircraft. No exemptions for low flying, 500
ft rule etc
There are no local laws which could be invoked, therefore all infringements
concern the CAA not the local police. The local coroner would probably hold
an inquest in the case of a fatality but after official identification it
would be adjourned pending the result of the CAA investigation. Any claim
against the pilot by someone who has been hurt would be pursued in the
civil, not the criminal court. Of course the result of the CAA investigation
would be crucial in such a case.
We do not have such a thing as an unregistered plane.
Cheers
Pat
PostPosted: Mon Dec 04, 2006 9:03 am    Post subject: Dual Elevator Cables Reply with quote
<<If it's two seats, or over 254 lbs,factory built you can't change much; homebuilt, you have to register it as experimental and go through inspections, test flying in a restricted area, etc. You can change pretty much anything when you build it but you still
If it's under 254 lbs and single seat (i.e. ultralight), you can do virtually anything... but the ultralight regs prohibit you from flying, at ANY altitude, over any congested area or open air assembly of persons.>>
Thanks Dana,
here both single seat and two seater are microlights (as we call them) There is no difference between kit and factory built. Spec is not more than 2 seats. max stall 35knots, Max All Up weight,300kg (662lbs) single seat. 450Kg (993 lbs) twin seat. Above those weights it becomes an `A` licence machine. We have Kolbs operating here as `A` category. But its a whole new ball game regarding maintenance, flying licence, medicals etc.,.
There is movement towards a deregulated class and the Kolb dealer Mike Moulai had an example (Firestar?) on show at our major aviation Exhibition over the weekend. With our background it is unlikely that `deregulated` will mean quite as much freedom as many here would like. We can hope. Nothing is set in stone yet.
Flying over congested area and crowds AT ANY HEIGHT applies here also. I always applied the rule `high enough to glide clear` until I was hauled over the coals by an instructor on a check flight.
Cheers
Pat
ceengland(at)bellsouth.ne
PostPosted: Mon Dec 04, 2006 5:53 pm    Post subject: Dual Elevator Cables Reply with quote
> some middle point.
-Dana
For Pat, just a little bit of extra clarification on the Experimental
Homebuilt vs. U. S. 'Part 103' (of the FAA regs) Ultralite regs:
Under 254 lbs, 1 seat, less than 5 gal fuel capacity, under 55kts top
speed, less than 24 kts stall speed can qualify as a Part 103 Ultralite
& there is no registration, training, reporting, maintenance/inspection
schedule etc required.
http://www.ccnow.com/cgi-local/sc_cart.cgi?2170208198401745
You can register one of these as an Experimental Homebuilt if it wasn't
built commercially (meaning 51% was built for personal education or
recreation) just like larger homebuilts, but I don't know why anyone would.
Experimental Homebuilts can be virtually any size/weight/speed/number of
seats but must meet the 51% rule above. These must be registered & get
registration numbers just like factory built planes. The rules say no
flight over densely populated areas 'except in the process of takeoff or
landing' but these days this is largely a political thing to keep the
masses from complaining. Air traffic control will often route you
directly over a major city if you ask to transistion their airspace
while on a cross-country, if it keeps you out of the way of traffic at
their airport. *Anyone* (even a dog or a chimp) can make *any* repair or
modification to an Experimental Homebuilt. If it's considered to be a
'major' modification, the owner must notify the FAA of the change & get
a test area approved for 5 hours of flight test time after the mod.
Details on the test proceedure after a mod vary slightly depending on
the rules in effect when the plane got its original Operating
Limitations, but you get the idea. Experimentals must be inspected once
a year by either someone with an airframe & powerplant ticket from the
FAA, or by the holder of the Repairman's Certificate for that particular
plane (meaning the builder). You've got to have the word 'Experimental'
in big letters in the cockpit so any passenger is expected to know he's
taking his life in his hands if he gets in the plane. In the USA, even
with 300 million people the odds of hitting anyone on the ground are
almost unmeasurably small. These are very good rules, just like the
provision in our constitution that guarantees us the right to 'keep and
bear arms', which was put in place to allow us to protect ourselves from
a corrupt government, even if it's our own.
Hope this helps...
Charlie
flying my 4th (purchased) homebuilt, building another
PostPosted: Tue Dec 05, 2006 6:45 am    Post subject: Dual Elevator Cables Reply with quote
the word 'Experimental' in big letters in the cockpit so any passenger is
expected to know he's taking his life in his hands if he gets in the
plane.>>
Hi Charlie,
we have a little piece of paper about twice as big as a postage stamp stuck
up somewhere in the cockpit with a note that `this plane is not built to
accepted aeronautical standards`.
Serves the same purpose I suppose. The first line of defence if some some
smart guy sues you.
Cheers
Pat
Page 3 of 3
