n616tb(at)btsapps.com Guest
Posted: Sat Dec 02, 2006 3:20 pm Post subject: plugging hole at rear of cylinders |
Hi Listers,
I have mentioned about my high CHT's and got lots of replies. I am working
on the front area around the inlets and upper ramps based on those replies.
However, I found something else to be addressed. At the back side of
cylinder #3 right next to the case where the back baffle is. There is a
hole that goes straight down not where the fins are but where the #3
cylinder is bolted to the case. It looks like there is a tab on the bottom
of the rear baffle metal that was to be bent up. I can't bend this now
because it contacts the case and much work to remove the whole thing for
trimming.
There is another hole on the other side next to cylinder #2. It looks like
it might be too big to just use silicone in there, what are other options?
What have others done in this area?
Tim Bryan
RV-6
0-360 A1A
Posted: Sat Dec 02, 2006 8:34 pm Post subject: plugging hole at rear of cylinders |
Tim Bryan wrote:
Hi Listers,
trimming.
Tim Bryan
RV-6
0-360 A1A
Can you cut an oversize 'doubler' that will extend far enough to fill
the gap? Pop rivet to the existing baffle material.
walter(at)tondu.com Guest
Posted: Sun Dec 03, 2006 7:36 am Post subject: plugging hole at rear of cylinders |
Fill all those gaps with red RTV.
Walter Tondu
http://www.rv7-a.com - Flying!
http://www.evorocket.com - Building
Posted: Sun Dec 03, 2006 7:40 am Post subject: plugging hole at rear of cylinders |
Hi Charlie,
It is almost impossible to get to this spot without removing stuff. I
suspect it would have been difficult to do when building the baffles in the
first place, but would have been possible. I would like to just squirt some
silicone in there, but I think the opening is too big for it to stay put.
Possibly I could get some duct tape on the bottom of it, fill it with
silicone and removing the tape after it sets up.
I was wondering if it made sense to stuff something in there to close it up
but feel it is a little too hokey for me. Surely I am not alone on this.
Maybe this hole is insignificant with regards to cooling, but it is the
biggest hole in my upper pressure area. With cylinder head temps well above
400 degrees in the winter, I need to find something to change.
[quote] --
lhelming(at)sigecom.net Guest
Posted: Sun Dec 03, 2006 10:34 am Post subject: plugging hole at rear of cylinders |
Dear Tim: Sorry I don't have an answer for an easier fix. The correct long
term fix -- as painful and time consuming as it may seem to be -- is to
remove the baffling, make the bend(s) to eliminate the hole so you can get
good cooling and put it back together. Probably a day's or two task at
most. Filling a large hole with RTV or some other non metal material will
be subject to deterioration over time with the heat and vibration going on
in the engine area.
Best wishes. Indiana Larry.
rv9jim(at)juno.com Guest
Posted: Sun Dec 03, 2006 1:44 pm Post subject: Plugging hole at rear of cylinders |
Hey Walter
There is a new high temp RTV from Permatex. Its Grey in color
and matches my primer on my baffles. It has the same high temp rating of
the red stuff. This way it doesn't look bad when you apply it around the
gaps. It blends in nicely. Check your auto supply store as they have a
grey and a black and I believe they both are now high temp. The "Ultra
Grey" (p/n 82194 or 599BR) is rated for 625 deg F.
I found the gap on my #3 cyl. before I RTV'd it in place. I
tried to look around every nook and cranny to fine out where air could
bypass. I also found out the spacer / bolt that holds the rear baffle on
the #4 cyl side also had to be RTV'd. I however had it done when I found
that area. So I got our a long stemmed flat screw driver and put little
dabs of RTV on it and placed it down in the area to fill it up and stop
as much gap as I could.
Jim Nelson
RV9-A FWF
Posted: Sun Dec 03, 2006 1:46 pm Post subject: Plugging hole at rear of cylinders |
Tim,
Also don't forget to close off the area under the "upper" fiber
glass inserts that we glass in on the upper cowl. Air can bypass from
the pressure area over into the low pressure area of the cowl.
Jim Nelson
ronlee(at)pcisys.net Guest
Posted: Sun Dec 03, 2006 3:01 pm Post subject: Plugging hole at rear of cylinders |
I checked this on mine (RV-6A, O-360)and see no way that air can move from
the high
pressure to low pressure side.
Ron Lee
Terry Watson
Joined: 09 Jan 2006 Posts: 290 Location: Seattle, WA USA
Posted: Sun Dec 03, 2006 4:20 pm Post subject: Plugging hole at rear of cylinders |
I think this depends on exactly how you do the baffle seals at the front of
the engine. With mine it was obvious that it was going to be a huge leak of
pressure, so I glassed off one end of the inserts. I then looked at a
friends very similar setup, but he did the seals differently and sealing the
ends of the insert wasn't necessary.
Terry
RV-8A Aerosport Power O-360-B1B 180 hp
