john(at)fureychrysler.com Guest
Posted: Thu Nov 30, 2006 9:13 am Post subject: Fuel vents |
I saw that someone had recommended keeping the fuel tank vent in the wing root by winding a couple turns of the tubing and exiting the lower intersection fairing thereby not having to enter the cockpit and do all that plumbing. Anyone with experience on this???
John Furey
RV7 QB
walter(at)tondu.com Guest
Posted: Thu Nov 30, 2006 9:47 am Post subject: Fuel vents |
I believe this is commonly done on Rockets. You might check that
list if you don't get info here.
Walter Tondu
http://www.rv7-a.com - Flying!
http://www.evorocket.com - Building
gilbey(at)earthlink.net Guest
Posted: Thu Nov 30, 2006 10:25 am Post subject: Fuel vents |
john.i did what you are talking about also a friend did the same in his 6,i have a 6a and he has the 6,we both used three turns or coils in the wing root,large coils,to just where they will fit inside the root with fairing covering them,ty them together with nyon tys and secure them to keep viberation down,drill a hole in the wing fairing and run the drain out the bottom, no problem with this so far with either of us,ymmv for whats its worth,
frank goggio rv6a
lhelming(at)sigecom.net Guest
Posted: Thu Nov 30, 2006 2:23 pm Post subject: Fuel vents |
In making a change in the design of the vent as described, I wonder if that would be an issue with insurance coverage or with a future buyer of the plane if it came to be a problem contributor and it wasn't disclosed beforehand? I just did not see the present design being a problem with installing it per the plans and the revision does not appear to improve the performance, so what is the purpose of changing Van's design?
Posted: Thu Nov 30, 2006 3:59 pm Post subject: Fuel vents |
Once the policy is written, you're covered as long as you didn't intentionally misrepresent your aircraft. There are variations from Van's standards on every aircraft, whether the variations are gross weight limits, an extra rivet here or there, or (heaven forbid) another solution to the fuel vent installation.
As far as liability goes, as the builder, you have the risk of being sued if the airplane ever crashes, regardless of whether the airplane was built exactly to plan or not.
As long as the system works, and it is up to the builder to determine if it works, the liability and insurance problems are no better or worse than with any other RV.
KB
n616tb(at)btsapps.com Guest
Posted: Thu Nov 30, 2006 6:42 pm Post subject: Fuel vents |
Well, if it works then it works. My question would be how to keep fuel out of the vent line. With the stock design, if you bank steep or do aerobatics will fuel enter the vent and then run back to the tank because of the height in the vent? With coils could you get fuel in the coil and have it not run back thereby blocking the vent? Just a question, but sounds like a reasonable thing to do. Fuel inside is almost unavoidable with the valve design.
From: owner-rv-list-server(at)matronics.com [mailto:owner-rv-list-server(at)matronics.com] On Behalf Of hangerq
Sent: Thursday, November 30, 2006 11:56 AM
To: rv-list(at)matronics.com
Subject: Re: Fuel vents
frank goggio rv6a
| Quote: | | www.aeroelectric.com | 0123456789012345
frank goggio
Joined: 10 Jan 2006 Posts: 5 Location: fayetteville N.C.
Posted: Thu Nov 30, 2006 7:42 pm Post subject: Fuel vents |
tim.all i can tell you on the coils for vents is that they work,i have a small bevel cut slanted to the front and the air pressure seems to keep excess fuel from leaking out,as far as aerobatics are concerned,the test pilot that did the test flight on mine,did all the positive stuff that he could think off,some on the first flight,and a lot on the second flight,never a problem,the only time i see fuel leaking out is when i leave it to full of fuel,i may be speaking out of turn,but i believe my friend spoke to someone at vans about this, and was told it was ok,unless i was dreaming this,sure was a lot easier to install then the plans drawing,works for me,
frank goggio rv6a
Dennis Glaeser
Joined: 10 Jan 2006 Posts: 53 Location: Rochester Hills, Michigan
Posted: Thu Nov 30, 2006 8:26 pm Post subject: Fuel vents |
Remember that the engine is (hopefully) constantly drawing fuel from the
tank, and the air to replace the fuel comes in through the vent. So as long
as the engine is running, there is a constant flow of air into the tank
through the vent.
Fuel doesn't flow out the vent from the unused tank even during maneuvers
because it is (again, hopefully) sealed and there is no air coming in to
allow the fuel to flow out the vent - similar to dipping a tube into liquid,
then holding your finger over the end and pulling it out.
Fuel can not 'block' the vent, it just flows in or out depending on the
relative pressure inside the tank vs. outside air pressure. The loops in
the Rocket style vent are there so that, under normal circumstances, there
is not enough fuel in the line to over-fill it, and spill fuel overboard.
Dennis Glaeser
RV-7A - wiring my panel, waiting for my Eggenfeller H6 - wings have the
Rocket style vents installed.
design.
rickgray(at)roadrunner.co Guest
Posted: Fri Dec 01, 2006 4:17 am Post subject: Fuel vents |
Yo' Crossfire,
This is the vent line you're talking about....Randy Planzer did this on his F1 Rocket....pic from his site:
http://tinyurl.com/yj3v5d
Rick in Ohio at the Buffalo Farm
http://rv6rick.tripod.com/ohiovalleyrvators/
tcervin(at)valkyrie.net Guest
Posted: Fri Dec 01, 2006 7:24 am Post subject: Fuel vents |
Rick, That looks like a great idea! I have had problems on hot days with the vents on my RV6-A spitting fuel. Wonder if the loops of line in the wing root area would allow more expansion before starting to spit....spit?
Tom in Ohio (10G)
Posted: Sat Dec 02, 2006 6:04 pm Post subject: Fuel vents |
I dunno but I'm planning on trying it!
Rick
