nuckollsr(at)cox.net Guest
Posted: Tue Nov 28, 2006 5:18 am Post subject: 28v diesel engine |
| Quote: | Comments/Questions: Bob,
I am installing a DeltaHawk diesel engine in my homebuilt and they have
decided to go with a 28 VDC starter and alternator. I have already
purchased most of my avionics in 14 VDC. I can buy a step-down
transformer from Aircraft Spruce, but is there a good way to run parallel
14 V batteries for power and still use the 28 V alternator for
charging? Seems like I'm between a rock and a hard place.
Yup, your sure are! There's no graceful way to
do this. The best solution is to use 2 batteries
in series for cranking, change to parallel for
operating and running a 14v alternator.
bob . . .
oldbob(at)BeechOwners.com Guest
Posted: Tue Nov 28, 2006 6:27 am Post subject: 28v diesel engine |
Good Morning 'Lectric Bob and Mr. Delta Hawk User,
Just as a 'For What It Is Worth', such an arrangement
has been used in at least one certificated aircraft.
La Belle Caravelle used a relatively high DC voltage
to crank the Rolls Royce turbine engines with which it
was equipped.
There was a lever just to the left of the pilot seat
which changed a bank of NiCads from twenty-eight volt
parallel operation to something like one hundred and
fifty volts DC in a series arrangement.
I have forgotten the precise voltage used, (It has
been almost thirty years since I last flew a
Caravelle) but the arrangement worked as long as the
NiCads didn't blow up!
Since almost all mechanical systems on the Caravelle
were identical to the DeHaviland Comet, I would not be
at all surprised to find that the same setup was used
for it.
Worked great.
DO NOT ARCHIVE
Happy Skies,
Old Bob
AKA
Bob Siegfried
Ancient Aviator
Stearman N3977A
Brookeridge Air Park LL22
Downers Grove, IL 60516
630 985-8503
--- "Robert L. Nuckolls, III" <nuckollsr(at)cox.net>
wrote:
I have already
a step-down
alternator for
place.
bob . . .
Click on
about
provided
www.buildersbooks.com
Admin.
browse
Subscriptions page,
FAQ,
George W Braly
Posted: Wed Nov 29, 2006 6:14 am Post subject: 28v diesel engine |
The fuel injection control system on the diesel engine may require 28
volts for operation.
Regards, George
Posted: Wed Nov 29, 2006 7:06 am Post subject: 28v diesel engine |
At 08:12 AM 11/29/2006 -0600, you wrote:
Regards, George
Hmmm . . . so those guys are going electronic too . . .
I guess it comes down to a $time$/weights/parts-count
issue.
Depending on how much current the engine needs, it
might be better to use a small 28v battery and step-up
inverter as opposed to a 14 volt battery and step
down inverter to support already purchased avioncs.
To craft decision right may take as much engineering
$time$ as the delta-dollars to sell the 14-volt
goodies and buy 28-volt versions.
Life can get complicated sometimes!
I had a weird phone call yesterday from a guy
building a Seawind who was planning to install a
PT-6 engine. He started out asking where to buy
100A fuses and I steered him onto the usual suppliers.
The conversation expanded to wire sizing and system
architecture for engines with starter-generators and
it was obvious that he had little knowledge and no
experience with the issues. Yet as I attempted to
steer him in the right direction, he insisted on
arguing with my suggestions. I kept telling him that
I wasn't going to argue with him and that our
conversation was taking time from my work for a paying
customer.
He kept asking questions and then arm-wrestling
with the answers. I finally suggested that he hire
a professional to craft a wirebook for his airplane
and offered by services at $150/hour. He replied,
"For that kind of money I'll do it myself" whereupon
I opined, "Then I guess you don't need me" and hung up.
That's the first time I've ever had to forcibly
terminate a conversation with a builder. I do
wish the fellow well but I'm not optimistic!
Some of life's complications are truly intractable.
gcomfo(at)tc3net.com Guest
Posted: Wed Nov 29, 2006 12:27 pm Post subject: 28v diesel engine |
Posted: Wed Nov 29, 2006 6:51 pm Post subject: 28v diesel engine |
George W Braly
Posted: Thu Nov 30, 2006 7:02 am Post subject: 28v diesel engine |
I sympathize with your conversation on the Seawind.
We get those phone calls around here on engine issues.
Usually they are all good. But sometimes - - somebody who is way behind
the power curve wants to engage in protracted debates over well settled
issues.
Regards, George
William.P.Dube(at)noaa.go Guest
