Open canopy
cfrhoads(at)YAHOO.COM
PostPosted: Tue Nov 28, 2006 11:39 am    Post subject: Open canopy Reply with quote
__________________________________________________________
50/50 Fifty feet in the air and 50 feet of runway left, OK; however, not good when the canopy comes open.
Thanksgiving day was beautiful and I had not been home for 2 weeks so I decided to go flying.  The temperature was the coldest that I had flown my plane, 40's in the hanger. The door/canopy did not close quite normal which I attribute to the temp change. After two touch & goes all looked great until the door came open. First I thought that I was a "has been", but I noticed that the plane was still controllable and that the canopy was still intact. After reminding myself several times FLY THE PLANE, I was able to use my left hand to hold the canopy shut. About that time I remembered that there was a 20-30 story Holiday Inn just ahead of me now that I was off course, so stress got to be a little high. Downwind went fairly normally; however, the landing became interesting because I had never used my right hand on the controls and thus there was no easy to control throttle, trim, etc. The landing actually turned out to be pretty good, that may be relative because I have had many that were not pretty.
On another note, my Geo Metro engine is working great and the engine computer greatly simplifies the engine management. In cases like that above simplicity can contribute to safety.
Chuck Rhoads A100
N246CR Trike
&nb="http://pa.yahoo.com/*http://us.rd.yahoo.com/evt=36035/*http://music.y[quote][b]
jeff(at)rmmm.net
PostPosted: Tue Nov 28, 2006 12:22 pm    Post subject: Open canopy Reply with quote
Congratulations on getting her home Chuck! You are to be commended for
handling the situation as you did. What made the door open? Keep us
informed of the situation.
Jeff
N128LJ Gold Rush
pretty.
Chuck Rhoads  A100
N246CR  Trike
music.y
Dave Miller
PostPosted: Tue Nov 28, 2006 1:09 pm    Post subject: Open canopy Reply with quote
Chuck,
Thanks given that you and the plane are OK.
It's possible for the rear shoot bolt to miss the guide, giving the doors a push when latched will show if anything is amiss.
How about updating the list on the engine capacity, fuel burn and cruise perfomance of the Geo engine ?
Dave C-FBZI.
Only 35 hours, but finally all the paperwork OK'd by transport Canada, so I can go places next year.
Now bringing it into a heated hangar with a list of things to fix or improve ! [quote][b]
wdaniell(at)etb.net.co
PostPosted: Fri Dec 01, 2006 2:19 pm    Post subject: Open canopy Reply with quote
Add my thanks too – there but for the grace of god go we all.
Likewise interested knowing more about the GEO option
Will
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Dave_Miller(at)avivacanada.com
Sent: Tuesday, November 28, 2006 16:07
Subject: Re: Open canopy
Chuck,
Dave C-FBZI.
www.aeroelectric.com
ward.t(at)xtra.co.nz
PostPosted: Fri Dec 01, 2006 3:58 pm    Post subject: Open canopy Reply with quote
Interesting discussion on the risk of the canopy opening.
One thing I do when I have a young passenger on board is put a rubberband around the door lever and the protective combing.
Reason is just in case we hit some turbulence and the instinctive reaction of a young person generally is to grab something to hold.
The rubberband prevents it from moving up and can be broken in an emergency.
The other thing I have done is to place some stainless steel protectors on the door combing where the bolts enter to not only protect the composite from doors closing with the bolts still protruding but also to assist with a better secure bolts lock when closed. These are screwed into place with stainless steel self taping screws.
Cheers,
Monowheel Classic #292 103 hours ZK-TIM
Tim Ward
12 Waiwetu Street,
Fendalton,
Christchurch, 8052
New Zealand
Ph +64 3 3515166
Mobile 021 0640221
ward.t(at)xtra.co.nz (ward.t(at)xtra.co.nz)
[quote] [b]
