rdewees(at)mindspring.com Guest
Posted: Sun Nov 26, 2006 7:40 pm Post subject: Terra TXN 920 pin out |
Hi guys, I'm trying to wire up a small com radio for my plane to
compare to my Microair 760 that seems to have distorted audio. I have
been loaned a Terra TXN 920 Nav Com unit. It looks like I could split
the Com and use it by itself as a small Com radio since it's in a
separate chassis from the Nav side of the radio. Does anyone have the
pin out for the Com side? I would like to wire it up and take it flying
to see if I have unusual ignition noise or a radio problem in the
Microair.
Ron in Atlanta.
| | - The Matronics Avionics-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Avionics-List |
james(at)berkut13.com Guest
Posted: Sun Nov 26, 2006 8:49 pm Post subject: Terra TXN 920 pin out |
It's not likely noise from your ignition...
Distorted audio is a common problem with the Microair 760 radios - mine
included. Send it in (yep, back to Aussie-land) for repair to have it fixed
with a later reversion. They USED to post their revision issues on their
website, but not any longer - at least that I can find. Garbled audio was
one of the first issues listed. I seem to remember that it stemmed from a
capacitor that was originally installed backward - but I might have that
mixed with another issue.
Honestly, I used to be a big Microair believer...but from what I have
experienced, seen and heard of in the last year...I would not recommend
those products any longer.
Before you get too far down the rabbit hole, you might want to get that
radio checked out or refitted.
Good luck,
James Redmon
Berkut #013 N97TX
http://www.berkut13.com
