owl40188(at)yahoo.com Guest
Posted: Fri Nov 17, 2006 10:39 am Post subject: Aeroquip Fuel Hoses / Andair Valve |
I am installing the Andair valve instead of the standard one Vans provides. I moved the mounting bracket about 1 or 2 inches down and got a straight extension for the Andair valve and the 90 fittings that Andair sells. So far it looks like it will work well . I would like to replace the aluminum tube fuel line with the Aeroquip stuff. It appears that Vans and Aircaft Spruce sell the Aeroquip 701 hose. I am wondering if this is the proper hose to use. I know Tim used the performance racing hoses also with a steel braid and it appears to be about half the price of the 701 stuff. The racing angled fittings appear to be a lot less expensive also. Any thoughts on this?
thanks
Niko
millstees(at)ameritech.ne Guest
Posted: Fri Nov 17, 2006 11:03 am Post subject: Aeroquip Fuel Hoses / Andair Valve |
If you look at the specifications, the Aeroquip braided hose that Summit Racing sells, is exactly the same as the hose Van's sells, except about half the price. (www.summitracing.com) I bought my hose fittings from Aircraft Spruce, because they are about the same price, and selected for aircraft. Aircarft Spruce's price is about the same as Van's for the hose. I am going to use the racing hose for the brake lines also...probably overkill; however, I don't want any future problems with the plastic hose.
I am also using an Adnair fuel valve, and the fuel hose is the braided Aeroquip racing hose, and I am using one continuous piece from the 90 deg fitting on the fuel valve to the fuel tank. I tried to use 90 deg aeroquip fittings off the fuel valve, and discovered that they are too wide.
Steve Mills
RV-10 40486 Slow-build
Naperville, Illinois
finishing fuselage
[quote] --
Posted: Fri Nov 17, 2006 12:19 pm Post subject: Aeroquip Fuel Hoses / Andair Valve |
Thanks for the info Steve.
Are you using the straight fittings at both ends of the hose? Do you have the Andair 90 deg fitting on the valve?
thanks
Niko
40188
Posted: Fri Nov 17, 2006 12:29 pm Post subject: Aeroquip Fuel Hoses / Andair Valve |
Niko:
I am using the banjo fitting from Andair, with 816-6D fittings from Aircraft Spruce.
Steve Mills
finishing fuselage
[quote] --
AndrewTR30
Posted: Fri Nov 17, 2006 2:26 pm Post subject: Re: Aeroquip Fuel Hoses / Andair Valve |
Niko, I had teflon lined hoses made for me with Earls Racing components. I put some red heat shrink tubing put over them for a little extra protection. If I remember correctly they are 37 1/2"
I decided not to use them and ended up using the aluminum tubing. If you are interested in them, I can send you some pictures. They might suit your application really well. Feel free to contact me off the list.
Andrewtr30 (at) yahoo (dot) com
_________________ Andrew Rayhill
RV-10 40078
Phoenix |
Tim(at)MyRV10.com Guest
Posted: Fri Nov 17, 2006 2:37 pm Post subject: Aeroquip Fuel Hoses / Andair Valve |
You can buy Aeroquip (and other brands) of fittings from race supply
too. I would (and apparently have) bet my life on the quality
of some of them, like Aeroquip. In fact, other than the part number,
I would bet the Aeroquip fittings used on Van's hoses are the same
exact part you buy at race supply places. (I did use some other
brands of fittings and they're very nice too) The best part is
that the race supply shops have a better selection, even if the price
isn't always tons lower. Yeah, we may be fanatical about safety
of our hoses, which is great....but remember that these high
performance racing buffs are just as fanatic about their hoses,
and their rides. I'd definitely look at the fittings as you get them
and if you have any doubts about their quality then do the right
thing and exchange them for another brand, but if you stick with
Aeroquip, you can't go too wrong. I think I have some XRP or something
like that too. Side by side, they look identical, even down to the
welding/brazing qualities. Your best bet if you can do it is to
visit a local racing supply shop where you can look at them firsthand.
millstees(at)ameritech.net wrote:
| Quote: | If you look at the specifications, the Aeroquip braided hose that Summit
half the price. (www.summitracing.com <http://www.summitracing.com>) I
Steve Mills
finishing fuselage
Posted: Fri Nov 17, 2006 2:50 pm Post subject: Aeroquip Fuel Hoses / Andair Valve |
Question Andrew.....did you use the conductive teflon hose?
I'm under the understanding that for fuel you would want
the conductive versions of the hose for obvious reasons. I just
wanted to see if you found this stuff easy to obtain. Had I been
able to get conductive teflon hoses locally, made to length,
I would have done that. As it was, the easiest way to
do it yourself without knowing the total overall length exactly,
was to buy rubber and cut and fit the ends. I seem to remember
the hoses being either 39 or 41" long myself, but it's getting
fuzzy.
Also, for those thinking of hoses, I don't know if people saw
my braided hoses on my tire and break write-up, but I got
braided teflon so I don't have to worry about fatigue cracks on
the hose around the axle. Ed Hayden took it one step further and
went with braided all the way from fuselage to brake, which
is what I really wanted to do. I didn't know the measurement
at the time. Some day though, I'll swap mine out when I'm
doing some major maintenance. I think his are 44" end to end
from fuselage bulkhead fitting to the brake. Slick setup,
and his will probably last forever, being teflon.
AndrewTR30 wrote:
little extra protection. If I remember correctly they are 37 1/2" I
list.
-------- Andrew Rayhill RV-10 40078 Phoenix
http://forums.matronics.com/viewtopic.php?p=75331#75331
AndrewTR30
Posted: Fri Nov 17, 2006 4:08 pm Post subject: Re: Aeroquip Fuel Hoses / Andair Valve |
Tim,
Yes my hoses are carbon lined for static dissipation. they are -6 size. Here's a link:
http://www.holley.com/620002ERL.asp
The fittings are Earls Swivel-seal.
http://www.holley.com/types/Swivel-Seal.asp
I could not find a good source locally, So I ordered them from:
http://www.anplumbing.com/shop/
My Andair valve is mounted high in the tunnel, actually above the standard Vans location and didn't like the bend coming throught the tunnel, so that's why I switched back to the aluminum.
RV-10 40078
Phoenix |
