n713ml(at)yahoo.com Guest
Posted: Wed Nov 15, 2006 7:21 am Post subject: Hall Effect/Ammeter/query |
Folks,
As others have said, placement of devices to measure health of your electrical system is like decisions on primers! So my goal, rightly or wrongly: One Hall Effect feeding my ACS 2005 eng monitor on my main alt B-lead to read as loadmeter. When I switch to my SD8 backup alt, all wired per Z13-8, I want to keep it very simple and switch to a second sensor reading charge or discharge. The ACS is monitoring volts, of course, and is wired through the endurance bus. I After looking at archives, I still remain unclear as to my questions(s) here: a) where to place this second sensor and which way constitutes "alternator" and "battery" sides in that placement, and b) will it read properly whether or not one has selected "Alternate Ebus Feed".
Thanks in advance,
Len
RV7A nearing completion
Sponsored Link
Mortgage rates near 39yr lows. $420,000 Mortgage for $1,399/mo - Calculate new house payment [quote][b]
nuckollsr(at)cox.net Guest
Posted: Wed Nov 15, 2006 7:55 am Post subject: Hall Effect/Ammeter/query |
At 07:20 AM 11/15/2006 -0800, you wrote:
| Quote: | Folks,
Suggest you fit your system with a low voltage warning
light fed from the e-bus. Run BOTH alternator feed wires
through the same hall-effect sensor. The instrument will
read output from either or both alternators on one sensor.
If you're down to the SD-8, reduce loads on the e-bus until
the loadmeter is at 8A or less . . . or until the lv light
stops flashing.
No selector switches. Simple and consistent interpretation
of ammeter readings.
< with experiment. >
< --Lawrence M. Krauss >
