Vortex Generators on 601 HDS
RWILBERS(at)tampabay.rr.c
PostPosted: Sat Nov 11, 2006 6:54 pm    Post subject: Vortex Generators on 601 HDS Reply with quote
Dear List:
Has anyone installed Vortex Generators on the 601 HDS? I have met a guy from Niagara Aircraft, a Canadian Co., who says he can furnish VG's for the 601 HDS. This may be interesting if he is correct.
Richard in Florida
 Filesize:  5.54 KB
 Viewed:  5524 Time(s)
N601RT
PostPosted: Sat Nov 11, 2006 9:39 pm    Post subject: Re: Vortex Generators on 601 HDS Reply with quote
This has been discussed many times.
Search is your friend. Go to http://www.matronics.com/searching/ws_script_short.cgi , select Zenith for the archive and enter "vortex" for the search string. Using "vortex & HDS" for the search string limits the hits somewhat. Using "vortex & N601RT" will find my post on this subject.
Note from part of the search instructions: Using the Vertical Bar ( | ) for logical OR and the Ampersand ( & ) for logical AND
Roy
N601RT: CH601HDS, nose gear, Rotax 912ULS, All electric, IFR equipped,
653hrs, 760 landings
larry(at)macsmachine.com
PostPosted: Sun Nov 12, 2006 6:32 am    Post subject: Vortex Generators on 601 HDS Reply with quote
Hi Dick,
In the March/April issue of Zenith Newsletter #153, there was an article
on Vortex Generators that were added to an HDS. A few dimensions and
drawings showing how they can be made. I remember because the area of
the leading edge fuel tanks didn't have any. The claim was that the VGs
would reduce stall by 5 mph and to comply with performance of LS
aircraft might have been true even if the regulations as they stand
would not recognize such an adaption to that purpose. With a 912
engine, the 601HDS would fly in ground effect at 35 KTs, and fly at less
than 40 KTs at full gross. Said he could not get it to stall with these
installed. The aircraft is supposed to qualify for Sport Pilot with
these. If you're interested in the article, I can scan it and send it.
Larry McFarland - 601HDS at www.macsmachine.com
DICK WILBERS wrote:
Dear List:
Richard in Florida
skyguynca
PostPosted: Sun Nov 12, 2006 7:28 am    Post subject: Vortex Generators on 601 HDS Reply with quote
please send me a copy off list
David Mikesell
23597 N. Hwy 99
Acampo, CA 95220
209-609-8774
skyguynca(at)skyguynca.com
www.skyguynca.com
daveaustin2(at)can.rogers
PostPosted: Sun Nov 12, 2006 5:03 pm    Post subject: Vortex Generators on 601 HDS Reply with quote
Hey Larry,
If you do scan the newsletter would you send the item to me please.
daveaustin2(at)can.rogers.com
Dave Austin 601HDS - 912, Spitfire Mk VIII
PostPosted: Sun Nov 12, 2006 9:25 pm    Post subject: Vortex Generators on 601 HDS Reply with quote
Dick,
I have just installed the Stolspeed VGs from Australia, but have not been able to fly yet due to weather. I'm doing the "experimental" for him. Will post the results here as well.
I chose the Stolspeed because they are plastic and glue on. Will not cut fingers etc.
challgren(at)mac.com
PostPosted: Sat Nov 25, 2006 8:44 am    Post subject: Vortex Generators on 601 HDS Reply with quote
Dick:
We installed VG's on our 601 HDS and it reduced the stall speed 6 mph.  The biggest advantage was the increased stability during the landing phase and the added capability of aerodynamic braking after touchdown.
Stan
On Nov 11, 2006, at 7:55 PM, DICK WILBERS wrote:
Dear List:
Richard in Florida
