finn.lassen(at)verizon.ne Guest
Posted: Thu Nov 09, 2006 11:17 am Post subject: Removing white plastic covering from aluminum |
After spedning a couple of hours trying to remove the white plastic
(with black backing/glue) from the rear wing spar channel of my old RV-4
kit, I'm beginning to question the wisdom of removing it at all.
Yes, I checked the archive and the hairdryer/hetgun helps, but the
material is so old or fragile that it beaks. I can remove maybe an inch
before it breaks, then have to start again with a plastic spartula to
get an edge to hold onto to pull, etc.
Anybody see any liability in leaving it on?
Finn
vft(at)AOL.COM Guest
Posted: Thu Nov 09, 2006 11:51 am Post subject: Removing white plastic covering from aluminum |
Cover the affected area with old towels and soak them with mineral spirits. You may need to soak them for a few hours but this worked very well on my F1 project.
Danny Melnik
F1 #25
Melbourne (FL) Rocket Factory
chuck515tigger(at)yahoo.c Guest
Posted: Thu Nov 09, 2006 12:39 pm Post subject: Removing white plastic covering from aluminum |
Posted: Fri Nov 10, 2006 7:31 am Post subject: Removing white plastic covering from aluminum |
Thank you Danny. This is one for the archives!
It works!
I left a miniral spirits soaked rag on part of the plastic overnight and it now peels right of (or some more stubborn sections scape off easily with a plastic spatula without marring the aluminum).
Finn
vft(at)aol.com (vft(at)aol.com) wrote:
[quote] Cover the affected area with old towels and soak them with mineral spirits. You may need to soak them for a few hours but this worked very well on my F1 project.
Danny Melnik
F1 #25
.AOLPlainTextBody { margin: 0px; font-family: Tahoma, Verdana, Arial, Sans-Serif; font-size: 12px; color: #000; background-color: #fff; } .AOLPlainTextBody pre { font-size: 9pt; } .AOLInlineAttachment { margin: 10px; } .AOLAttachmentHeader { font: 11px arial; border: 1px solid #7DA8D4; background: #F9F9F9; } .AOLAttachmentHeader .Title { font: 11px arial; background: #B5DDFA; padding: 3px 3px 3px 3px; } .AOLAttachmentHeader .FieldLabel { font: 11px arial; color: #000000; padding: 1px 10px 1px 9px; background: #F9F9F9; } .AOLAttachmentHeader .FieldValue { font: 11px arial; color: #000000; background: #F9F9F9; } .AOLAttachmentHeader a, .AOLImage a { color: #2864B4; text-decoration: none; } .AOLAttachmentHeader a:hover, .AOLImage a:hover { color: #2864B4; text-decoration: underline; } body { background-color: white; font-family: "Verdana"; font-size: 10pt; border: 0px; } p { margin: 0px; padding: 0px; } img.managedImg { width: 0px; height: 0px; } img.placeholder { width: 275px; height: 206px; background: #F4F4F4 center center no-repeat; border: 1px solid #DADAD6 !important; } --> RV-List message posted by: Finn Lassen <finn.lassen(at)verizon.net ([email]finn.lassen%40verizon.net[/email])>
After spedning a couple of hours trying to remove the white plastic (with black backing/glue) from the rear wing spar channel of my old RV-4 kit, I'm beginning to question the wisdom of removing it at all.
Yes, I checked the archive and the hairdryer/hetgun helps, but the material is so old or fragile that it beaks. I can remove maybe an inch before it breaks, then have to start again with a plastic spartula to get an edge to hold onto to pull, etc.
Finn
vft(at)aol.com Guest
Posted: Fri Nov 10, 2006 10:57 am Post subject: Removing white plastic covering from aluminum |
Cool! I've been mostly lurking on this this for almost 6 years. Glad I was finally able to contribute.
Danny Melnik
F1 #25
jhstarn(at)verizon.net Guest
Posted: Fri Nov 10, 2006 1:22 pm Post subject: Removing white plastic covering from aluminum |
Just another hint. Left that duct tape on too long, or it got baked in the sun. Many years ago we had that problem, the tape came off but the glue residue remained on the raw unpainted skin. Someone on line suggested coating the glue with mayonnaise (kinda heavy) & covering with a cloth, let stand overnight. The next day 90% came right off, reapplied and removed the rest the next day. I have no idea why it worked but it did. Final cleanup with acetone.
KABONG HRII N561FS Do Not Archive, it's in there., somewhere.
Danny Melnik
F1 #25
Posted: Fri Nov 10, 2006 2:11 pm Post subject: Removing white plastic covering from aluminum |
JOHN STARN wrote:
| Quote: | Just another hint. Left that duct tape on too long, or it got baked in the sun. Many years ago we had that problem, the tape came off but the glue residue remained on the raw unpainted skin. Someone on line suggested coating the glue with mayonnaise (kinda heavy) & covering with a cloth, let stand overnight. The next day 90% came right off, reapplied and removed the rest the next day. I have no idea why it worked but it did.
| Mayonaise is oil mixed with eggs. The oil was the solvent, and the eggs made it thick so it didn't just run off. Almost any petroleum product will work though!
Linn
[quote] Final cleanup with acetone.
Danny Melnik
F1 #25
| [b]
Posted: Fri Nov 10, 2006 3:51 pm Post subject: Removing white plastic covering from aluminum |
Ahh Yes. Guess the mayo would also not evaporate over night like most "petroleum products" would. It would remain and soften the glue sloowllly. This would allow it to be removed without scrubbing it with scotchbrite. KABONG Do Not Archive 8*)
[quote] Subject: Re: Removing white plastic covering from aluminum
| Quote: | Someone on line suggested coating the glue with mayonnaise (kinda heavy) & covering with a cloth, let stand overnight. The next day 90% came right off, reapplied and removed the rest the next day. I have no idea why it worked but it did.
Linn
cjensen(at)dts9000.com Guest
Posted: Sat Nov 11, 2006 5:18 am Post subject: Removing white plastic covering from aluminum |
The mayo is a great idea. Even if its wrong, it's not so bad when you have to eat your mistakes.
Chuck Jensen
3edcft6(at)cox.net Guest
Posted: Sat Nov 11, 2006 10:57 pm Post subject: Removing white plastic covering from aluminum |
Chuck Jensen wrote:
| Quote: | The mayo is a great idea. Even if its wrong, it's not so bad when you
With that comment, I think we need to learn a little bit more about "The
History of Mayonnaise".
Most people don't know that back in 1912, Hellmann's Mayonnaise was
manufactured in England. In fact, the Titanic was carrying 12,000 jars
of the condiment scheduled for delivery in Vera Cruz, Mexico, which was
to be the next port of call for the great ship after its stop in New
York. This would have been the largest single shipment of mayonnaise
ever delivered to Mexico.
But as we know, the great ship did not make it to New York. The ship
hit an iceberg and sank, and the cargo was forever lost.
The people of Mexico, who were crazy about mayonnaise, and were
eagerly awaiting its delivery, were disconsolate at the loss. Their
anguish was so great, that they declared a National Day of Mourning,
which they still observe to this day.
The National Day of Mourning is known, of course, as
