rhdudley1(at)bellsouth.ne Guest
Posted: Wed Nov 08, 2006 6:07 pm Post subject: Compression Test |
Listers,
I read in some descriptions of the differential compression test that
for engines with displacement under 1000 cubic inches the orifice of the
tester should be .040" and above 1000 ci the orifice should be.060".
Some catalogs distinguish between <5" bore and > 5" bore rather than
displacement. My O-320 is 5.125" bore and 320 cubic inches. I want to
purchase the appropriate tester.
I would appreciate your advice.
Thanks in advance.
Richard Dudley
-6A flying
Kellym
Posted: Wed Nov 08, 2006 6:58 pm Post subject: Compression Test |
The FAA guidance in AC43-13-1b was changed, to the under/over 5"
designator by someone that doesn't have a clue about engines, as every
Lyc bigger than an O-290 has greater than 5" bore and has been tested by
the standard tester for eternity. The high volume tester is for radial
engines.
Just get the regular .040 orifice model.
Richard Dudley wrote:
Listers,
the tester should be .040" and above 1000 ci the orifice should
be.060". Some catalogs distinguish between <5" bore and > 5" bore
rather than displacement. My O-320 is 5.125" bore and 320 cubic
inches. I want to purchase the appropriate tester.
Thanks in advance.
Richard Dudley
-6A flying
KCHD |
