AV8ORJWC
Posted: Mon Nov 06, 2006 6:36 pm Post subject: Night before the big election - Flutter Article |
Great article on Pages 98-101 of the September 2006, addition of Sport Aviation. One passage I found of value was “What some pilots and aircraft owners may not realize is that simply repainting can add sufficient weight to unbalance the ruddervators and make them susceptible to flutter”. We learned in school that all control surfaces ALWAYS get balanced after paint.
I continue to take exception to the position that VANS aircraft do not need to be balanced and ignoring that Part 147 advise is okay.
Worthy of consideration even if you guys aren’t posting any acknowledgment.
John Cox
#40600
Rick S.
Posted: Mon Nov 06, 2006 7:09 pm Post subject: Night before the big election - Flutter Article |
I agree with you John,
I was surprised to not see procedure for balancing in the plans. I would love to see a writeup to explain how it is supposed to be done. I have never and plan never to have it happen but I did have a 1/4 scale R/C model, a big biplane experience flutter on the first and last flight while in a dive. It happened so fast that I could not take any action before the top wing ailerons flew right off, taking the top wing covering with them, within seconds the bottom wing did the same thing. Only warning was what sounded like a big bumble bee followed by floating wing parts...and that awful thud as it hits the ground.
Rick S.
40185
_________________ Rick S.
RV-10
40185 |
Posted: Mon Nov 06, 2006 7:22 pm Post subject: Night before the big election - Flutter Article |
Thank you for the reminder even if your message was only found in the
beginning of your subject. Who could forget!
JOhn G.
| Quote: | From: "John W. Cox" <johnwcox(at)pacificnw.com>
Subject: Night before the big election - Flutter Article
Date: Mon, 6 Nov 2006 18:35:19 -0800
acknowledgment.
John Cox
#40600
AV8ORJWC
Posted: Mon Nov 06, 2006 7:36 pm Post subject: Night before the big election - Flutter Article |
I will post the standard procedure taught in school, after the dust
settles from tomorrow. The production jig (frame) is the only hard
part. The balancing is easy. It's as simple as balancing those main
wheels after remounting the low pressure tread and tubes which seam to
peal off the valve stems on landing.
Everyone knows what the orange dot on the side of the tire is for...
Right?
I will continue to wait for a reason other manufacturers makes and
models can do 200 kts but the RVs will suffer flutter at 181.0 knots
instead of 200.0 + knots. What do those Evo and Rocket guys know that
we are not discussing.
John
AV8ORJWC
Posted: Mon Nov 06, 2006 7:37 pm Post subject: Night before the big election - Flutter Article |
I'm sure trying.
JC
Posted: Mon Nov 06, 2006 8:17 pm Post subject: Night before the big election - Flutter Article |
Was this the Great Planes Pitts 1/4 scale ARF? They had to reset the
predrilled hole locations for mounting the top wing to the struts.
JOhn G.
| Quote: | From: Rick <ricksked(at)earthlink.net>
Subject: Re: Night before the big election - Flutter Article
Date: Mon, 6 Nov 2006 19:09:10 -0800 (GMT-08:00)
Rick S.
40185
Rick S.
Posted: Mon Nov 06, 2006 8:30 pm Post subject: Night before the big election - Flutter Article |
"Orange dot on the tire"....Where the valve stem exits the rim right?
Rick S.
40185
RV-10
40185 |
Rick S.
Close John!!
It was the Super Aeromaster....
Rick S.
40185
RV-10
40185 |
Deems Davis
Posted: Tue Nov 07, 2006 9:08 am Post subject: Night before the big election - Flutter Article |
Now that's a graphic reinforcement/reminder!
Deems Davis # 406
Finishing - ( A Misnomer ! )
http://deemsrv10.com/
Rick wrote:
Rick S.
40185
