		graham(at)gflight.f9.co.u Guest
				 Posted: Thu Jan 26, 2006 4:19 pm    Post subject: oil thermostats |
				 	  | Quote: | 	 		  > But to look at the logic I'm not aware of oil
 > circulation being used to cool an engine so in most
 > applications ...
 This, Bob, is complete rubbish. IMNSHO.
 All engines with no water cooling always have an oil
 cooler.
 Because it is taking heat out of the engine !
 I hope your statement was a typo !
 Richard
 Richard,
 you are absolutely right. The only way to keep tyhe pistons cool is to sqirt or splash oil at them.
 Graham
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		william(at)wrmills.plus.c Guest
				 Posted: Thu Jan 26, 2006 9:45 pm    Post subject: oil thermostats |
				I partly agree, Richard and Graham, but not many of the older generation of
 motorcycles had an oil cooler.
 B w,
 William
		hurstkr(at)growzone.com.a Guest
				 Posted: Fri Jan 27, 2006 12:29 am    Post subject: oil thermostats |
				 	  | Quote: | 	 		   All engines with no water cooling always have an oil
 cooler.
 May I respectfully suggest the word "Some" be substituted in place of
 "All" in the above and delete "always".
 Just a couple of cases in point.
 Years ago, I flew a Cessna 172F in my job for 12 years.  It had a
 Continental O300 engine and NO oil cooler much to my disgust flying in a
 hot climate.  However, to make the gauge read a lower temp, Cessna in
 their wisdom directed a blast of cold air directly onto the temperature
 sensor bulb. . . .  but of course, this was a CERTIFIED aircraft.  No
 self respecting home builder would contemplate such a devious device.
 Also, what about two stroke motor mowers?  I haven't seen an oil cooler
 on one of them yet.  Haven't seen a water cooled one either come to
 think of it !
 Ok, I know we are probably referring only to aircraft engines but my
 point is, "NEVER say NEVER"
 Regs
 Kingsley
				 Posted: Fri Jan 27, 2006 1:18 am    Post subject: oil thermostats |
 B w,
 William
 /William
 that's why they used to blow holes in the pistons. My Vincent Black Prince did, so did a friend's Bonneville
 Graham/
				 Posted: Fri Jan 27, 2006 4:44 am    Post subject: oil thermostats |
				Hi! Graham
 Don't rub it in !
 Hopefully you saw my retraction and explanation leading to my
 misconception?
 Just out of interest ...on reading the item about shock cooling the guy
 made a statement that oil contributes to only 8% of the cooling on an
 air cooled engine and 12% from the cooling fins with 44% from the
 exhaust pipe.
 However he does point out that the 8% is nearly as much as the 12% too.
 I guess the remaining 36% goes in general crank case cooling etc.
 Bob Harrison G-PTAG Europa MKI/Jabiru 3300
 Do not archive.
