owl40188(at)yahoo.com Guest
Posted: Sat Oct 28, 2006 8:34 am Post subject: Baggage door seal |
I am looking for a recommendation on the Baggage door seal. Aircraft Spruce doesn't seem to have anything in the dimension Vans recommends.
Niko
40188
jesse(at)itecusa.org Guest
Posted: Sat Oct 28, 2006 8:49 am Post subject: Baggage door seal |
We have used this (05-01200 P-STRIP 17 FT ROLL) from Spruce.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nikolaos Napoli
Sent: Saturday, October 28, 2006 12:34 PM
To: Matronics
Subject: Baggage door seal
Do not archive.
Niko
40188
| Quote: | | http://www.matronics.com/Navigator?RV10-List | 01234567890123
-- Release Date: 10/27/2006
10/27/2006
Posted: Sat Oct 28, 2006 9:29 am Post subject: Baggage door seal |
Jesse,
It looks like its a bit larger (1/4"thick x 3/8" wide)than Vans suggests (1/8" thick by 1/4"wide). Did it work out well? Does it collapse to 1/8" thick? Is the door flush with the surrounding skin?
Thanks for the info
Niko
40188
Posted: Sat Oct 28, 2006 6:14 pm Post subject: Baggage door seal |
The nice thing about the P seal is that you can use the flat or the bubble, depending on how much clearance you have. It seems to work well. One important place to seal is along the hinge. I was in the back seat during a flight (to OSH this year, I think) and felt back there and there was a ton of air coming in through the top of the hinge. The P seal works great there because you need something thicker to seal that gap.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
Sent: Saturday, October 28, 2006 1:29 PM
Subject: Re: Baggage door seal
Jesse,
Thanks for the info
Niko
40188
----- Original Message ----
Sent: Saturday, October 28, 2006 12:48:50 PM
Subject: RE: Baggage door seal
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
To: Matronics
Do not archive.
Niko
40188
10/27/2006 | Quote: | | http://www.matronics=================== |
0123456789012345678
10/27/2006
Posted: Mon Oct 30, 2006 7:02 am Post subject: Baggage door seal |
Thanks again Jesse,
I am ordering it today.
Niko Napoli
coop85(at)bellsouth.net Guest
Posted: Mon Oct 30, 2006 4:44 pm Post subject: Baggage door seal |
I ended up using some plain old weather stripping from Lowes Aircraft Supply. It’s two beads about 5/8” wide, white and works great (so far).
Marcus
To: Matronics
Niko
40188
