Dale Ensing
Posted: Fri Oct 27, 2006 1:46 pm Post subject: tires and tubes |
It is time to rotate the Aero Trainer tires on the 6A. Left main is about smooth on the outside edge. Have been considering replacing the tires and tubes instead of rotating. If rotated, how much more time (or landings) in relation to the original mounting should I get out of the tires?
When I do replace the tires, I think I will 'bite the bullet' and go with the the Michelin Airstop tubes. Should I go with the Airstop tubes even if I rotate?
Would like comments/experience on which brand/model tire has given the best service on the trike tapered rod landing gear mains, please.
Dale Ensing
RV-6A N118DE
| | - The Matronics RVSouthEast-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RVSouthEast-List |
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Steve Glasgow
Posted: Fri Oct 27, 2006 2:49 pm Post subject: tires and tubes |
I did. I also use the Michelin tires.
Cappy
_________________ Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG |
Dale Ensing
Posted: Fri Oct 27, 2006 2:59 pm Post subject: tires and tubes |
Where did you buy them Cappy?
RV-6A
Aero Plantation
Weddington NC |
Steve Glasgow
Posted: Fri Oct 27, 2006 3:44 pm Post subject: tires and tubes |
Spruce
Cappy's Toy
RV-8 N123SG |
flyguy
Posted: Fri Oct 27, 2006 4:13 pm Post subject: tires and tubes |
I got same # of ldgs. on rotated tires, about 6 mos. (at)
side. Since wear is on inside, it hasn't hurt to run
til tread on inside is low. Reno
--- Dale Ensing <densing(at)carolina.rr.com> wrote:
| Quote: | It is time to rotate the Aero Trainer tires on the
rotate?
Dale Ensing
RV-6A N118DE
Access over 1 million songs - Yahoo! Music Unlimited
(http://music.yahoo.com/unlimited)
flyguy
Posted: Fri Oct 27, 2006 4:14 pm Post subject: tires and tubes |
Desser has always had best pxs. during the 11 yrs. I
had the -4. RR
[quote] Where did you buy them Cappy?
Larry Bowen
Posted: Fri Oct 27, 2006 4:34 pm Post subject: tires and tubes |
I have retreads & Michelin tubes both from Dresser, slated to go on the 8 during my conditional inspection, which is in progress....
Larry Bowen, RV-8 240 hrs, RV-7 rudder.....
Larry(at)BowenAero.com
http://BowenAero.com
[quote] From: Dale Ensing [mailto:densing(at)carolina.rr.com]
Sent: Friday, October 27, 2006 7:00 PM
To: rvsoutheast-list(at)matronics.com
Subject: Re: tires and tubes
_________________ Larry Bowen
RV-8 SOLD,
RV-7QB in progress... |
Ron Schreck
Joined: 10 Jan 2006 Posts: 94 Location: Gold Hill, NC
Posted: Fri Oct 27, 2006 6:09 pm Post subject: tires and tubes |
Who is Dresser?
Smokey
Larry Bowen
Posted: Fri Oct 27, 2006 7:37 pm Post subject: tires and tubes |
http://www.desser.com/
Larry Bowen
[quote] From: Ron Schreck [mailto:ronschreck(at)alltel.net]
Sent: Friday, October 27, 2006 9:57 PM
Subject: RE: tires and tubes
Who is Dresser?
Smokey
RV-8 SOLD,
flyguy
Posted: Sat Oct 28, 2006 4:45 am Post subject: tires and tubes |
Desser Tire, they are in Trade a plane...
--- Ron Schreck <ronschreck(at)alltel.net> wrote:
[quote] Who is Dresser?
Smokey
Dale Ensing
Posted: Sun Oct 29, 2006 10:29 am Post subject: tires and tubes |
Yesterday, I proceeded with rotating my tires since I did not have the new tubes and tires on hand and had to do something now or wait a month or so.
Found something that is baffling me. On the inboard side of each wheel, I found two spots of something between the bead of the tire and the wheel. It appeared to be waxy on the surface but was hard and tenaciously stock to the wheel. Upon removal I found that it had pitted the rim of both aluminum wheels. Does not appeared to have affected the tire .
Could this be brake fluid that got into the bead area when I did the brake fluid fill? Can not think of what else it could be. Don't remember what I used to lubricate the tire and tube when I installed the tires several years ago.
Any thoughts??
Dale Ensing
| Quote: | | Quote: | Subject: tires and tubes
| Quote: | | Quote: | It is time to rotate the Aero Trainer tires on the 6A. Left main is about smooth on the outside edge. Have been considering replacing the tires and tubes instead of rotating. If rotated, how much more time (or landings) in relation to the original mounting should I get out of the tires?
Dale Ensing
RV-6A N118DE
RV-6A
Aero Plantation
Weddington NC |
Steve Glasgow
Posted: Sun Oct 29, 2006 12:06 pm Post subject: tires and tubes |
Could be paint coming off the wheel. Mine do that. Cappy
Cappy's Toy
RV-8 N123SG |
Mike Munn
Posted: Mon Oct 30, 2006 5:15 am Post subject: tires and tubes |
I have always bought my tires from Desser. I just purchased (2) 500x5
Goodyear Flite custom II's from Desser for $59 ea.
Mike
"Dale Ensing"
Sent by: To
owner-rvsoutheast-list-server(at)m <rvsoutheast-list(at)matronics.com>
atronics.com cc
10/27/2006 06:59 PM
Please respond to Subject
rvsoutheast-list Re: tires and tubes
Dale Ensing
Posted: Tue Oct 31, 2006 7:29 am Post subject: tires and tubes |
Mike,
Have you used the Goodyear Flite Custom IIs before? I remember reading that
one of the upgrade tires had more "shoulder" rubber where the RVs tend to
wear more. Do the Flite Custom II have the extra thickness?
Dale
RV-6A
Aero Plantation
Weddington NC |
Mike Munn
Posted: Tue Oct 31, 2006 7:50 am Post subject: tires and tubes |
Dale,
As I recall, I had used them on the 170 a few years ago, and do not recall
any premature wearing. The price difference makes up for any premature
wear ($59 vs $113). I do not know if there is any additional shoulder
thickness (probably not since they are discontinued).
Mike
"Dale Ensing"
Sent by: To
atronics.com cc
10/31/2006 10:29 AM
Mike,
Dale
Dale Ensing
Posted: Tue Oct 31, 2006 11:00 am Post subject: tires and tubes |
Thanks Mike.
Didn't realize from your first post that $59/tire was a big discount. Placed
order today for two Flite Custom II and Airstop tubes
Dale
RV-6A
Aero Plantation
Weddington NC |
robbie(at)atlanticpkg.com Guest
Posted: Tue Oct 31, 2006 11:29 am Post subject: tires and tubes |
just fyi,
I did get my N-number reservation in the mail yesterday, so I guessed
N781RW correctly! Now I've just got to decide between the 7 & 8...
Next time anyone's going to be in Wilmington or nearby and doesn't
mind letting me clamber in for a couple of minutes that would help. I
know I'll fit in an 8 (thanks Len!) but Greta is beginning to show
some interest in the 7, so I'd like to try that on for size...
literally!
Talked to my developer today and they're 3-weeks AHEAD of schedule,
so I may have a garage to get started in by the early summer if
things keep going as planned.
Robbie
Thanks Mike.
discount. Placed order today for two Flite Custom II and Airstop tubes
Dale
Larry Bowen
Posted: Tue Oct 31, 2006 3:25 pm Post subject: tires and tubes |
The retreads I just installed on plane last night are FCII's. They seem
to be plenty thick. Stiffer sidewall too. I haven't tried to get the
wheel pants back on yet, but I think I'm going to like them.
Larry Bowen
Mike,
that
Dale
RV-8 SOLD,
sportav8r(at)gmail.com Guest
Posted: Tue Oct 31, 2006 7:12 pm Post subject: tires and tubes |
Plenty thick, huh?
Check the wheel pant clearance _really carefully_ before you blast off
for a fly-in after fitting new tires of a different brand. Otherwise
you might discover a smoke system you didn't know you had.
I don't know what made me think of that. Leggs, help me out here
-Stormy
On 10/31/06, Larry Bowen <Larry(at)bowenaero.com> wrote:
Larry Bowen
dbreda(at)earthlink.net Guest
Posted: Wed Nov 01, 2006 5:24 am Post subject: tires and tubes |
The first time I replaced the tires on my -6, I had to rebuild the wheel
pants... went from Van's tires to Condor's (Michelin), which I still
use. They're cheap from Desser and seem to last. Got the leak-guard
tubes, too, and they work well.
Dana
Bill Boyd wrote:
Plenty thick, huh?
-Stormy
> <Larry(at)BowenAero.com>
> Larry Bowen
