f.miles.tcp.833(at)clearw Guest
Posted: Fri Oct 27, 2006 6:06 pm Post subject: Kitfox history |
I have seen several, so called, histories of the Kitfox posted in different places and they all seem to be pretty much the same however I wonder why no mention is made of Dan Denny’s prior relationship with the Avid Flyer Co. (He did not just appear in Southern Idaho with a new plane) and the genesis of the Kitfox. That Dean Wilson was the designer of the Avid which the Kitfox was copied after. Anyone know or care to comment. (let’s be nice!)
Frank
aeromer(at)ix.netcom.com Guest
Posted: Fri Oct 27, 2006 7:14 pm Post subject: Kitfox history |
I attended several Kitfox Fly-Ins in Caldwell (both Kitfox and Avid were located there at the time) in the early 1990's. What I remember is that Dean Wilson designed both. Denny sold out to Skystar but was still located at the same location with his Thunder Mustang project! If you can get a copy of How to "Fly a Kitfox" there is a brief history in that booklet. AeroMer
gary-n-dorothy(at)bhwi.ne Guest
Posted: Sat Oct 28, 2006 11:38 am Post subject: Kitfox history |
Didn't Denny have something to do with the Montana Coyote? , developing or promoting it for/or with "Doc" out of Helena Montana?
I visited the production facility once while it was being set up, and the airplane was basically a scaled up version of a kitfox.
Malcolmbru(at)AOL.COM Guest
Posted: Sat Oct 28, 2006 5:46 pm Post subject: Kitfox history |
also anyone care to talk about the avid catalina I herd thear was still jiges around ? malcolm
wliles(at)bayou.com Guest
Posted: Sat Oct 28, 2006 7:34 pm Post subject: Kitfox history |
I wanted the Avid Amphib. My shop was too short so I built a MK IV
instead. I still like the idea of the Catalina and sometimes wish I
could find an unbuilt kit. Perfect for wet Louisiana. The jigs still
existed when Avid moved to Montana. I have no idea if they still
exist. The good people at Airdale might know.
Jerry Liles
Malcolmbru(at)aol.com wrote:
Quote: | also anyone care to talk about the avid catalina I herd thear was
MichaelGibbs(at)cox.net Guest
Posted: Sun Oct 29, 2006 1:27 pm Post subject: Kitfox history |
Frank sez:
Quote: | ...I wonder why no mention is made of Dan Denny's prior relationship
with the Avid Flyer Co....That Dean Wilson was the designer of the
The Kitfox was not copied from the Avid Flyer, the original "Avid
Flyer" is the ancestor of both aircraft lines. Denny and Wilson
produced the airplane but later went their separate ways. What we
know today as the Avid Flyer and the Kitfox line are both direct
descendents of that very first "Avid Flyer" (which, by the way, was a
nose-wheeled airplane that did not have a round cowling .
Mike G.
N728KF
Malcolmbru(at)aol.com Guest
Posted: Sun Oct 29, 2006 6:04 pm Post subject: Kitfox history |
this catalina could be had for a lot less than a builder would have in to one do you get the seaplain matronics list malcolm
av8rps(at)tznet.com Guest
Posted: Mon Oct 30, 2006 10:24 am Post subject: Kitfox history |
Mike,
While I agree that the Kitfox is a derivative design of the original Avid
Flyer, the initial Kitfox design was pretty much a direct copy of the Avid
Flyer. Reportedly the first Kitfox was created from an Avid Flyer kit
(Denney obtained in the lawsuit when he and Wilson parted ways) by
modifying
the shape of the rudder, adding drooped wing tips, changing the lower
longerons, and installing a 503 inside a slightly reshaped smooth cowl (the
round cowl didn't come until some time later when Denney was fitting the
ill
fated Pong Dragon radial engine work in the Kitfox). Note that even the
door opening style was the same as the first Avids, because the tubing was
all the same around the cabin area.
And yes, the first Avid was a tri gear. But that was the only one that was
a tri gear only. After that they were either tri or tailwheel convertible.
Only a few were made as special ordered taildragger-only versions (to save
weight).
Rather ironic that modern day Kitfox is also a tailwheel or trigear
convertible with a smooth cowl, isn't it? (history repeating itself?)
A little more historical info; Did any of you know that current Kitfox
company owner John McBeans father was involved in the test flying of the
Avid Prototype N99AF?
And for any of you that have never seen the first Kitfox, here's a picture
of it...(prior to being recowled, repainted, etc.)
Paul Seehafer
Description: |
Filesize: |
106.17 KB |
Viewed: |
293 Time(s) |
Posted: Tue Oct 31, 2006 9:33 am Post subject: Kitfox history |
How does that saying go? Something like: "A rose by any other name is still
a rose".
