piavis(at)comcast.net Guest
Posted: Sat Oct 28, 2006 7:41 am Post subject: GTX327 Tray (Do I have the right tray?) |
For those that know the ins and outs of avionics, I have a good question. Last week I posted a question about my GTX 327 to Matronics, as the transponder wouldn’t slide completely into the tray and lock. The lower edge of the tray was in contact with the aft lower face of the unit. Along the back lower face of the bezel, there appears to be two slots where the tray tongs would slide in. That’s fine and that’s what it looks like in the GTX 327 install manual.
The manual calls out Garmin p/n 115-00285-00 as referenced in the install manual (figure B2). The problem is that I have p/n 115-00431-00 (as stamped on the tray) and doesn’t look like the referenced illustration. Are these trays supposed to be interchangable? I did find a reference to that p/n on the web through Avionics Now which indicated that the 004341 unit was good for 320A/ 327, but even the tray they show does not look like what I have.
This link http://adap.com/rv7/images/P3110032.JPG (lower right in the pic) shows the bottom of my tray and seems to be a bit different than the install manual.
Jim
George McNutt
Posted: Sat Oct 28, 2006 10:30 am Post subject: GTX327 Tray (Do I have the right tray?) |
Hi Jim
Not sure if this is relevant, but I was watching a buddy re-install his
GTX 327 and having a hard time getting it to seat. He had to loosen the
connector screws at back of box and let the connector reposition itself
before unit would slide in. Took several tries.
George in Langley BC
6A flying 7A finishing
PIAVIS wrote:
the install manual.
Jim
charlieray(at)optonline.n Guest
Posted: Sat Oct 28, 2006 11:10 pm Post subject: GTX327 Tray (Do I have the right tray?) |
If the case is the right size overall, it is completely normal for the black bezel to hit the lower lip edge of the case. this will leave about .100" of space or gap that you can see between the rest of the case and the bezel, you have to set the case in the avionics rack spaced with the lip edge flush with the front face of your panel stock. To be absolutly sure, i would put power and ground in the 4 pins shown in the manual attach the backshell and connector to the rack, then seat you unit in the rack and make sure it seats far anough into the connector and powers up just fine. Wiggle everything pretty good to make sure there are no intermittants.
Good luck
Charles
Doug Gray
Joined: 10 Jan 2006 Posts: 112 Location: Sydney, Australia
Posted: Sun Oct 29, 2006 3:44 am Post subject: GTX327 Tray (Do I have the right tray?) |
115-00285-00 is punched into my tray and the unit fits fine including
the connector engagement.
The manual (Rev L June 2006) is not error free errors, the tray drawings
may also be problematic. I will just fit the tray I have as best I can.
The GTX-327 tray is 0.05" wider and look nothing like the SL-40 tray.
Doug Gray
On Sat, 2006-10-28 at 08:39 -0700, PIAVIS wrote:
| Quote: | For those that know the ins and outs of avionics, I have a good
the install manual.
Jim
