bo124rs(at)hotmail.com Guest
Posted: Sat Oct 28, 2006 10:04 am Post subject: 0-360 kit $11,500 |
One last run at providing the RV crowd with an engine alternative....and
time to send Doug some money. My profession is going to dictate a lot more
work in the office the next two months, then nose to the grindstone until
April 15th. I was able to buy some additional parts, when I accumulated
parts for the previous kit, so here is a good one:
You can see all the at:
http://rvflying.tripod.com/id36.html (sitting on my living room floor)
CRANK (hollow)-YELLOW TAGGED
CASE-RECONDITIONED, CURRENTLY AT DIVCO
CASE THROUGH BOLTS-NEW
RODS-RE-CONDITIONED BALANCED WITHIN 2 GRAMS WITH NEW NUTS
ROCKER ARMS- RE-BUSHED
CAM-TAGGED
CRANK GEAR AND BOLT-NEW
IDLER/TIMING GEARS
LIFTER BODIES-NEW
HYD & SOCKETS-NEW
IMPULSE MAG -NEW
NON IMPULSE HAG - NEW
WIRING HARNESS - NEW
SPARK PLUGS- NEW
MAG GEARS BOTH IMPULSE & NON IMPULSE-NEW
CYLINDERS/PISTONS/PINS/RINGS-CERTIFIED WITH NEW PARTS. PISTONS 9:5:1
CYLINDER HOLD DOWN NUTS-NEW
SUMP & PIPES
ACC. COVER
OIL PUMP HOUSING AND GEARS-NEW
PUSH TUBES-NEW
PUSH RODS-NEW
STARTER-NEW
ALTERNATOR-NEW
FLYWHEEL-NEW
TACH SHAFT-NEW
CARB-CORE
HARDWARE BOLT KIT-NEW
Dana Overall
Richmond, KY i39
RV-7 slider, Imron black, "Black Magic"
O 360 A1A, C/S C2YK-1BF/F7666A4
http://rvflying.tripod.com/id30.html
Try the next generation of search with Windows Live Search today!
