jpkarnes2000(at)msn.com Guest
Posted: Thu Jan 26, 2006 11:24 am Post subject: ignition module wiring |
Listers:
I am electrically challenged and would like a "how-to" guide to correctly
wire my TP-45 ignition module. I have the pick-up wires and the wires
leading to the coil. Which wires go where? Thanks!
John Karnes
601 HDS
Bremerton, WA
| - The Matronics Stratus-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Stratus-List |
frank.hinde(at)hp.com Guest
Posted: Thu Jan 26, 2006 11:32 am Post subject: ignition module wiring |
I can fax you the wiring diagram ...I can even fax it to your email if
you adobe acrobat installed.
Frank
Billvt
Posted: Fri Jan 27, 2006 4:32 pm Post subject: ignition module wiring |
Mag Pickup + (usually a red wire) goes to TP45 G
Mag Pickup - (usually a white wire) goes to TP45 W
Coil + goes to TP45 B
Coil - goes to TP45 C
Bill
Posted: Mon Jan 30, 2006 7:28 am Post subject: ignition module wiring |
Yes I had to wire mine up the way Bill said...even though the original
instructions showed the W & G wires reversed...It didn't work this way.
One thing missing from the instructions below is the ground needed for
the stud...This HAS to be a very good ground, I uses a separate wire
back to the engine block just to make sure.
Frank
