owl40188(at)yahoo.com Guest
Posted: Tue Oct 24, 2006 7:37 am Post subject: Fuselage Conduit Support |
I have ran a wire conduit under the passenger and baggage flooring. This is the black stuff that Vans sells. The conduit is only supported at the frame locations (total of 3) so there is no support between the baggage floor frames which is a relatively long length.
I am wondering if this is acceptaple and if anyone else has done this. My option is to drill out the baggage floor rivets and put in some more supports for the conduit. This conduit will be carrying my battery cable. Anyone know what the acceptable unsupported conduit length is?
thanks
Niko
40188
LarryRosen
Posted: Tue Oct 24, 2006 8:58 am Post subject: Fuselage Conduit Support |
I cannot comment on how supporting the conduit, but
Instead of drilling out the floor board, now may be the time to add an
access panel or 2 to the floor. I used the same parts that are used for
the wing stall warning access panel and installed them in the baggage
floor so I have future access to the step mounts. You can see photos
here
<http://lrosen.nerv10.com/Construct/Log/Fuselage/FloorAccessPanels/index.html>.
Michael Sausen used them in a different place in the baggage floor.
Photos are here
<http://www.mykitlog.com/users/display_log.php?user=msausen&project 2&category=613&log=15783&row=15>
I may add some additional access panels if and when they are needed.
Larry Rosen
#356
Nikolaos Napoli wrote:
Quote: | I have ran a wire conduit under the passenger and baggage flooring.
length is?
thanks
Niko
40188
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
jhasbrouck(at)woh.rr.com Guest
Posted: Tue Oct 24, 2006 10:27 am Post subject: Fuselage Conduit Support |
Niko,
I've done the same thing and supported the conduit under the baggage floor with adel clamps. #19 drill used midway along the baggage rib, #8 screw and nylok nut at each station. Works well. Also fabricated a bracket to support the conduit as is exits the rear bulkhead into the tailcone. Pics included.
John Hasbrouck
#40264
Description: |
Filesize: |
65.4 KB |
Viewed: |
437 Time(s) |
Description: |
Filesize: |
40.56 KB |
Viewed: |
439 Time(s) |
jesse(at)itecusa.org Guest
Posted: Tue Oct 24, 2006 11:10 am Post subject: Fuselage Conduit Support |
This is what we did, but we used thicker-wall (stiffer) conduit with a smooth inside. We made a bracket at the back of the baggage compartment to hold them with cushion clamps, tied them off to the step support, and used grommets in the holes going through the ribs and the rear seat floors. There’s no such thing as too much conduit IMHO, especially with a 2AWG welding wire battery cable completely filling one.
Do not archive.
Jesse Saint
I-TEC, Inc.
www.itecusa.org
W: 352-465-4545
C: 352-427-0285
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Nikolaos Napoli
Sent: Tuesday, October 24, 2006 11:36 AM
To: Matronics
Subject: Fuselage Conduit Support
thanks
Niko
40188
Description: |
Filesize: |
32.56 KB |
Viewed: |
438 Time(s) |
Posted: Tue Oct 24, 2006 3:24 pm Post subject: Fuselage Conduit Support |
Description: |
Filesize: |
65.4 KB |
Viewed: |
339 Time(s) |
Description: |
Filesize: |
40.56 KB |
Viewed: |
389 Time(s) |
ScooterF15
Posted: Tue Oct 24, 2006 5:35 pm Post subject: Fuselage Conduit Support |
I put conduit under the baggage floor and supported it with adel clamps. However, I did not like the Van's conduit. It is too flexible, making it very difficult to route wire through. I bought 3/4" PEX pipe from the local plumbing store. It is more flexible than PVC, yet much more rigid than the corrugated black conduit. It is smooth on the inside and is just under 7/8" OD so it was easy to enlarge the holes with a 7/8" unibit. I also put the conduit down the full length of each wing, with a couple holes along the length to allow wires to exit.
PEX pipe is made for plumbing, so I did a non-scientific test to compare it to Van's conduit. I used a heat gun to simulate an overheating wire. Try taking a heat gun to the corrugated conduit: it shrivels up like shrink wrap. By comparison the PEX is quite a bit more robust when it comes to heat.
Photos attached.
Jim McGrew
Flying
In a message dated 10/24/2006 7:26:28 P.M. Eastern Daylight Time, jhasbrouck(at)woh.rr.com writes:
Description: |
Filesize: |
164.71 KB |
Viewed: |
346 Time(s) |
Description: |
Filesize: |
38.29 KB |
Viewed: |
408 Time(s) |
AV8ORJWC
Posted: Tue Oct 24, 2006 5:43 pm Post subject: Fuselage Conduit Support |
Niko – to the best of my review, your question has still gone unanswered. The answer is, was and will remain - none.
Now for the explanation. Best Practices in AC 43.13 is to leave wire runs supported at 6” intervals. The benefits are to reduce droop, reduce wire runs, reduce heat, enhance long term inspection. Tim posted on his RV-10 University site a DAR PowerPoint on aging aircraft wiring. It is blamed for the non-conspiracy cause of bringing down TWA flight 800 off the East Coast.
Why is it used? Ease of wire pulling. Ease of retro modification. Why is the answer none. Cause it has been found to mask the tell tale signs of an incorrect wire size and the carry amperage of the material selected. Wire needs to keep cool. With heat, resistance goes up. Do airlines use conduit, yes in limited locations and usually light wall aluminum and for the reason of protecting wiring from chafing, adjacent heat sources such as exhaust stacks or de-ice lines. Conduit, unless transparent, masks the ability to inspect progressively. Do all certified GA aircraft avoid conduit, can’t answer that. As little as practical I would guess. It is often 3-4x ID of the conduit over the OD on the final assembled wire bundle in it. Again for heat dissipation. Aluminum is great for radiating that heat build up away from selected hot spots. Yes there are things that cause hotspots in wire runs.
In Experimental construction, we too often use automotive, lower grade components, switches and fuses, conduit and non-aviation grade products. The reasons given are often cost and convenience. Nothing is wrong with those, if the evaluation takes in all the appropriate informational input. You get to answer what is appropriate. So you can answer your own question. Ask yourself why specs are different between DC and AC rated switches. Can you functionally use the wiring tables to select the correct gage of wire for the wire run and current carry? Do you know the effects of heat on the adjacent bundle? Conduit is usually multiple run. Do you know the difference in momentary and continuous use wiring?
I will bet that not one single builder will change their decision to use it. That is what makes building Experimentals so much fun. Convenience!
Want to post this question on the aero-electric list and watch the verbal joust begin?
Ask Stein, his opinion. Dan Checkoway did a pretty good post on his site for the failure of support tabs and the need to go in after one year and re-attach his wire runs.
40600
Sent: Tuesday, October 24, 2006 8:36 AM
To: Matronics
thanks
Niko
40188
AV8ORJWC
Posted: Tue Oct 24, 2006 6:17 pm Post subject: Fuselage Conduit Support |
Jim, should we conclude that a heated wire bundle can be located quicker in Van’s black corrugated due to heat shrink. And conversely, your PEX will mask the heat increase till the wires fuse? You were right that it is about heat. Should PEX be translucent? cause overheated wire is insulated with a product so that there is a marked and visible color change with excessive heat increase. Three distinct stages just like skin burns. Tim has some good shots. I had forwarded him the same presentation in Living Color. It is all about identification of an impending issue before reality sets in during flight. Otherwise the discussion migrates to inflight backup systems / vacuum gages, fire annunciation, fire suppression and software to identify the safest and quick route to the ground with a safe departure from the aircraft.
Always use the lightest gage, the shortest run, the highest quality to meet the task and to inspect for impending potential problems. Wiring by its nature functions in a hostile environment.
Do not Archive
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of JSMcGrew(at)aol.com
Sent: Tuesday, October 24, 2006 6:35 PM
Subject: Re: Fuselage Conduit Support
Photos attached.
Jim McGrew
Flying
Quote: |
----- Original Message -----
Sent: Tuesday, October 24, 2006 2:25 PM
Niko,
John Hasbrouck
#40264
bldgrv10450(at)comcast.ne Guest
Posted: Tue Oct 24, 2006 7:20 pm Post subject: Fuselage Conduit Support |
Thanks for the post. I think of all the old military aircraft I've seen over the years with wires bundled and tied to structure. I had a rough-in electrical inspection on a building project today and the inspector commented that the electrician did the right thing separating the wires nailed down a wall line. He said that the circuit breaker must be de-rated and / or the wire size increased if the wires are excessively bundled (quoted some code stuff and lost me), also the maximum length of conduit that a shielded wire can pass through is 24".
Thanks for the input, I'm going to do a little more thinking about the wire runs.
Paul Grimstad
RV-10 40450 fuselage
Portland, OR 97219
ScooterF15
Posted: Tue Oct 24, 2006 7:21 pm Post subject: Fuselage Conduit Support |
All valid points, John.
I would like to point out that one of the challenges that I found as the
RV-10 comes together is getting the wire runs 100% done before I riveted those
floor panels down permanently and before skinning and installing the wings.
Call it convenience if you will, but I ended up doing 90% of my wire runs
through the conduit long after those areas were sealed up. I certainly didn't make
that decision lightly. I realize that I deviated from a perfect world to
make things come together.
Are you going to stay away from conduit altogether? How do you plan on
inspecting the wires under the baggage floor area?
Jim
In a message dated 10/24/2006 10:19:42 P.M. Eastern Daylight Time,
johnwcox(at)pacificnw.com writes:
Do not Archive
____________________________________
wires to exit.
Photos attached.
Jim McGrew
Flying
From: _John Hasbrouck_ (mailto:jhasbrouck(at)woh.rr.com)
To: _rv10-list(at)matronics.com_ (mailto:rv10-list(at)matronics.com)
Niko,
Tim(at)MyRV10.com Guest
Posted: Tue Oct 24, 2006 8:02 pm Post subject: Fuselage Conduit Support |
I disagree with some of this. First, conduit can also be additional
protection of the wire, from both being snagged by a moving control
service actuator, and from anything rubbing against the wire. Of
course, you also need to strive to ensure the conduit itself isn't
getting chaffed. Next, flying a plane with wires in it, conduit or not,
will require diligent wiring and a leap of faith beyond that.
How many times do you realistically think you'll actually SEE the
wires, conduit or not, under your floors or in those sidewalls.
Yep, probably once a year on the walls, and maybe never again
after install on the floors. So just run them right the first
time. Also, what exactly is going to be going on inside a
nice bundled run of wires in conduit that will chafe them?
They're tefzel coated, and the wires would have to work pretty
hard to chafe eachother. The heat factor is definitely a possible
problem, but the advice given below directly can contribute
to those problems. Imagine using the "lightest gauge" wire possible
for all runs....you have choices....wires are sized according to
gauge that will give a specific temperature rise. Stay within
the low rise specs and you shouldn't have much problem with
any of those bundles....going to the thinner wire with the higher
temp rise and you're getting closer to the limits.
Better advice, IMHO, is to absolutely properly size your
breakers and fuses, which are designed with the goal of
wire protection and limiting over-current situations in mind.
Agreed though that certain conduits are better than others
for temp ratings. It's one reason I went with plenum rated
conduit under my cabin floors. The removal from effects
of fumes and the proper selection of gauge or heavier
wire through the wings led me to have no worries in the
wings. I ran out of 14 gauge at one point, so ran a 12.
There's no problem with that if you protect it with
the same smaller fuse. Wire the whole plane with 10ga
if you wish...you're not sacrificing safety, just
gaining lots of un-useful weight.
Oh, and if the additional weight is going to be considered
a safety concern when running 18 ga instead of 20 ga wire,
there's a theory there too...
Take a peek in the mirror before going off the deep end
to save a pound in the plane, and consider where it's
probably will more likely save your life....skip the
cheeseburger.
There are positives and negatives to most every
choice you'll make....but try not to make mountains
out of molehills, or go throw out too many good
ideas because of minor concerns. Wire chafing
and overheating are scary possibilities when things
go wrong...it's one of the reasons I have only one
battery-bus type wire in my plane, but that doesn't
mean conduit is always going to be a negative.
JSMcGrew(at)aol.com wrote:
[quote] All valid points, John.
those floor panels down permanently and before skinning and installing
the wings. Call it convenience if you will, but I ended up doing 90% of
my wire runs through the conduit long after those areas were sealed
up. I certainly didn't make that decision lightly. I realize that I
deviated from a perfect world to make things come together.
Jim
Do not Archive
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of
*JSMcGrew(at)aol.com
*Sent:* Tuesday, October 24, 2006 6:35 PM
*To:* rv10-list(at)matronics.com
*Subject:* Re: Fuselage Conduit Support
Photos attached.
Jim McGrew
Flying
dlm46007(at)cox.net Guest
Posted: Tue Oct 24, 2006 8:04 pm Post subject: Fuselage Conduit Support |
The aircraft mechanics handbook supplies a lot of info regarding loads voltages ,wire sizes and conduits and bundles, you might want to pick up a copy.
Jack.Phillips(at)cardinal Guest
Posted: Wed Oct 25, 2006 6:29 am Post subject: Fuselage Conduit Support |
What is the weight comparison?
Jack Phillips
#40610
AV8ORJWC
Posted: Wed Oct 25, 2006 6:38 am Post subject: Fuselage Conduit Support |
Knowing the importance of inspecting wiring, that is a difficult task. For one, I will not be permanent riveting floor panels. I will use a 0.25” composite panel which is fastened into nut plates for ease of removal and inspection. I also see value in access to the instrument panel area. I will group bundles and separate their runs so each has the ability to shed heat independent of a specific run. There are specific circuits which tend to create the largest percentage of heat issues. Each aircraft is unique. Tim did a great job posting his loads and analyzing this issue. I will never intentionally load a wire circuit above 80% of its rated carry capacity. I will be using welding wire for the battery terminals, starter leads and heavy intermittent amperage flows.
The good news is we don’t run electrical wire through our fuel tanks intentionally. I will use only aviation rated circuit breakers. No automotive (save a nickel) corner cutting. I have already had an onboard fire on a 1978 Ford. Nuf learned.
A separate issue is grounding and twisted wire bundles to reduce avionic interference. All of this is best covered elsewhere.
Sent: Tuesday, October 24, 2006 8:21 PM
I would like to point out that one of the challenges that I found as the RV-10 comes together is getting the wire runs 100% done before I riveted those floor panels down permanently and before skinning and installing the wings. Call it convenience if you will, but I ended up doing 90% of my wire runs through the conduit long after those areas were sealed up. I certainly didn't make that decision lightly. I realize that I deviated from a perfect world to make things come together.
Are you going to stay away from conduit altogether? How do you plan on inspecting the wires under the baggage floor area?
Jim
In a message dated 10/24/2006 10:19:42 P.M. Eastern Daylight Time, johnwcox(at)pacificnw.com writes:
Do not Archive
ScooterF15
Posted: Wed Oct 25, 2006 9:12 am Post subject: Fuselage Conduit Support |
Removable floor panels would be very nice, but quite a bit of work. I'm interested in seeing how that turns out. The rear seat and baggage area panels are structural (thus the 1000's of pop rivets holding them down), make sure you engineer your .025" composite panel and fasteners to handle the loads properly!
Jim
ScooterF15
Posted: Wed Oct 25, 2006 9:18 am Post subject: Fuselage Conduit Support |
I did not even consider weight in my decision. PEX is certainly heavier. I have about 35' of it in my plane, assuming maybe 1 oz per foot thats 2 lbs. I didn't really worry about weight as I built N312JE, I built per the plans and ended up with 1570# empty (minus paint and wheel pants). Not too bad.
Jim
Posted: Thu Oct 26, 2006 6:25 am Post subject: Fuselage Conduit Support |
Hi Jim,
I actually think the access panels are a great idea and I thank everyone who responded to my initial quarry. If I use the same panels used in the wing stall horn area its shouldn't be too much work as the pieces are allready made. As far as the floor being structural I don't believe that it is. Its only supporting the weight of whatever baggage is placed in it. The major loads are on the outer skins and the longerons. Those rivets that are used on the baggage floor are very weak and typically are not considered to be structural. Once the steel stem falls out of them all you are left with is a small hallow aluminum cyclinder.
I am also thinking of removing the conduit from the baggage area now as it won't be needed there any more. I am going with a recommendation that I got from a Pilot/ Mechanic friend that the fewer pieces of plastic in the plane the better as there are fewer things that can emit fumes and smoke in case of fire.
Niko
40188
ScooterF15
Posted: Thu Oct 26, 2006 9:12 am Post subject: Fuselage Conduit Support |
Yes, I think access panels like the one used for the stall detector would be good. That's a great idea. Removable floor panels seem like a bit more effort. Removable composite floor panels even more.
I have no intent on getting into a structural design discussion, and I did not design the RV-10 so I can't say for sure: But those pop rivets are used the baggage area floor panels and attaching the canopy top to the fuselage. If those aren't providing (at least torsional structural) support through the middle part of the fuselage, I'm not certain what is holding the plane together.
Posted: Thu Oct 26, 2006 9:17 am Post subject: Fuselage Conduit Support |
snip Quote: | I am also thinking of removing the conduit from the baggage area now as it won't be needed there any more. I am going with a recommendation that I got from a Pilot/ Mechanic friend that the fewer pieces of plastic in the plane the better as there are fewer things that can emit fumes and smoke in case of fire.
Niko
40188
| Not bad advice on the surface, but if the fire has reached the baggage area .... your goose is already cooked. Sorry for the bad pun. There's already enough noxious (when it's burning) stuff in the cabin already so eliminating just a little 'something' isn't going to improve your chances of survival much. But I'm an incurable optomist and I'll never suffer an inflight fire .... or a metorite strike or ..... well, just how many in flight fires (in small planes) have there been? Well, I do know of a couple, and both of them were in aerobatic aircraft ..... abused far worse than our docile birds ever will. Just a point of view.
Linn
KiloPapa
Joined: 24 May 2006 Posts: 142 Location: Pearblossom, CA
Posted: Thu Oct 26, 2006 10:12 am Post subject: Fuselage Conduit Support |
"Is the floor pan structural or not" is a question best addressed by Van's.
Kevin
40494
tail/empennage
[quote] ... As far as the floor being structural I don't believe that it is. Its only supporting the weight of whatever baggage is placed in it. The major loads are on the outer skins and the longerons. Those rivets that are used on the baggage floor are very weak and typically are not considered to be structural. Once the steel stem falls out of them all you are left with is a small hallow aluminum cyclinder.
_________________ Kevin
40494
do not archive |
