kbob(at)cox.net Guest
Posted: Thu Jan 26, 2006 5:51 am Post subject: Smooth Prime, Sam James Videos on Fiberglass & Painting |
Here's a good primer on fiberglass work:
http://rv8a.tripod.com/fiberglass.html
I also recommend the Smooth Prime pinhole filler and got a gallon from
Sacramento Sky Ranch (best price).
One gallon was enough for 2 RV's. Spray it on, the roller method is too
uneven.
I just finished painting my plane and would suggest both of the Sam James
videos. They are now for sale.
Fiberglass 101 $20 incl. shipping
Painting 101 $20 incl. shipping
Both for $35
Drop me an email off list. Kbob at cox.net
Kelly Patterson
N716K RV-6A
PHX, AZ
Final Assembly, ready to weigh
Time: 03:39:08 PM PST US
From: "Jeff Dowling" <shempdowling2(at)earthlink.net>
Subject: Need suggestion for book on fiberglass
Does anyone know of a good book on how to do the fiberglass work that we
typically do on RV's? Im tired of guessing at every step and bugging
everybody on this list.
Shemp/Jeff Dowling
RV-6A, N915JD
235 hours
Chicago/Louisville
Jim Carlton
Posted: Thu Jan 26, 2006 6:15 am Post subject: Smooth Prime, Sam James Videos on Fiberglass & Painting |
On Thursday 26 January 2006 08:50 am, Kelly Patterson wrote:
uneven.
Both for $35
Kelly Patterson
Kelly,
Still have the videos? I would be interested.
Jim
Paypal? check?
Jim Carlton
7614 Chesterfield Ave
Parma, OH 44129
n320wt(at)yahoo.com Guest
Posted: Thu Jan 26, 2006 8:00 am Post subject: Smooth Prime, Sam James Videos on Fiberglass & Painting |
I just read the fiberglass section at http://rv8a.tripod.com/fiberglass.html. This is all very good information and should be very helpfull to those just beginning to dive into the composite parts that come with your kits. The one thing I didn't see is the prep work need on the part you are working on. When applying a reinforcement or patch to any composite part that is cured, it is necessary to prepare that surface for bonding. I sand usually with 80 grit until there is nothing shiny left, then remove the dust with compressed air. I don't recommend cleaning freshly prepared surfaces with acetone as this just contaminates the surface you are preparing. After wetting out the cloth as described, apply a small amount of resin to the prepared surface using a gloved finger or squeegee. There just isn't enough resin left in the laminate to wet the surface of the part. Use a squeegee or roller to force out any trapped air. I usuall remove any excess resin from the edges of the layup
by
tamping with a folded dry paper towel. The prep work on the part is just as important as how the layup is prepared to ensure a proper bond.
BRIAN ALLEY (N320WT)
CARBON FIBER COMPOSITES
101 Caroline Circle
Hurricane, WV 25526
304-562-6800 home
304-395-4932 cell
How are you going to win by a nose if you don't stick out your neck?
rv8ch
Posted: Thu Jan 26, 2006 9:57 am Post subject: Smooth Prime, Sam James Videos on Fiberglass & Painting |
| Quote: | When applying a reinforcement or patch to any composite part that is
you are preparing.
I've always cleaned it with Acetone to try to get any last
bit of dust off, but I'll take your advice next time!
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
_________________ Mickey Coggins
http://www.rv8.ch/ |
Posted: Thu Jan 26, 2006 11:08 am Post subject: Smooth Prime, Sam James Videos on Fiberglass & Painting |
Mickey, This subject was discussed at length on the Lancair List. The Lancair manuals recommend cleaning freshly prepped surfaces with acetone. Most builders especially professional composite workers and engineers have performend test that show improved bonding especially in peel strength when acetone or other solvents are not used. If you apply fresh epoxy to the sanded area and work it into the surface any minute particles of dust will mix with the epoxy just like cotton flox or micro ballons and become a part of the structure. If you use acetone, you are just making acetone soup and contaminating the freshly prepared surface. Some amount of acetone residue will always remain in the surface and weaken the bond.
101 Caroline Circle
Hurricane, WV 25526
304-562-6800 home
304-395-4932 cell
rv8ch
Posted: Thu Jan 26, 2006 11:47 am Post subject: Smooth Prime, Sam James Videos on Fiberglass & Painting |
| Quote: | ... If you
Makes sense - I'm convinced. Thanks for the info.
Mickey Coggins
http://www.rv8.ch/
#82007 finishing
aldaniels(at)fmtc.com Guest
Posted: Thu Jan 26, 2006 12:10 pm Post subject: Smooth Prime, Sam James Videos on Fiberglass & Painting |
I seem to remember from my Lancair build that the study I recall said it
took something like 12 hours for acetone or MC to totally evaporate from
the surface. That could be speeded up with the use of a hair dryer or
other heat source. So if you have to remove contamination from a
critical bond area, don't get in a hurry.
Brian Alley wrote:
101 Caroline Circle
Hurricane, WV 25526
304-562-6800 home
304-395-4932 cell
cjensen(at)dts9000.com Guest
Posted: Thu Jan 26, 2006 12:30 pm Post subject: Smooth Prime, Sam James Videos on Fiberglass & Painting |
Daniels,
That doesn't sound right. Given the high vapor pressure of acetone, it
should flash off almost immediately unless a semi-porous structure has
been totally saturated in acetone. The earlier post about the best
cleaner being no cleaner is certainly true. Whatever residual material
is left will always contaminate the interface and slightly reduce the
peel bonding when the new layer is applied.
Chuck
