fklein(at)orcasonline.com Guest
Posted: Tue Oct 17, 2006 6:27 am Post subject: Rotax matters |
Googling "UltraFlight Radio" will bring you TODAY the following
discussion of interest:
| Quote: | Mike Stratman, California Power Systems, Inc.
Mike Stratman clears up the differences between the Rotax 912 S and
912 ULS engines. Even thought they are basically the same engine, one
is for certified and S-LSA aircraft and the other isn't. One can be
worked on by anyone and the other needs special training. Mike can
also answer your four stroke and two stroke ultralight aircraft engine
questions. Do you have questions? When the show is live, call your
questions in at (866) 613-1612 or you can IM them in on AOL or Yahoo
Instant Messenger to UFRadio. California Power Systems
Fred
A194
josok-e(at)ukolo.fi Guest
Posted: Tue Oct 17, 2006 11:29 am Post subject: Rotax matters |
Fred,
No need to google ultrafight, it spams itself to anybody on the list.
Please do not support spammers.
Kind Regards,
Jos Okhuijsen
workshopcam http://www.okhuijsen.org/plane
http:www.europaowners.org/kit600
mono xs, top on, gear in, tail wheel in, wings set, flapdrive in, tail
closed, tailwheel in, tail top in, blue stuff filled, sanded and primed,
fuel system in, doors done, windows in, sanding and filling the fuse and
wings.
Posted: Tue Oct 17, 2006 11:36 am Post subject: Rotax matters |
Hi Fred,
And fot the valuable content: The engines are part for part the same.
Certified engines can be worked on only by certified engeneers, or loose
their certification. Non certified engines can be worked on by anybody,
they won't loose the certification they don't have. The difference is only
in the paperwork, and maybe in the run-in/testing in the factory. But you
were joking weren't you?
Kind Regards,
Jos Okhuijsen
wings.
robh(at)hyperion-ef.us Guest
Posted: Tue Oct 17, 2006 12:55 pm Post subject: Rotax matters |
When I was ready to buy my 914 I asked the Rotax folks what the difference
was between the certificated and non-certificated versions. The answer was
that there are three differences - the certificated version uses expensive
spark plugs, comes with a piece of paper, and costs a lot more. That made
my decision easy. I went for the cheaper spark plugs.
Best regards,
Rob Housman
A070
Airframe complete
Irvine, CA
BEBERRY(at)aol.com Guest
Posted: Tue Oct 17, 2006 1:35 pm Post subject: Rotax matters |
Too right - good decision. Spark plugs - same manufacture and certification from a motor cycle dealers are approx one eighth cost of similar from a/c component dealers,. Who is conning whom?
I reckon we are all being taken for a ride on many a/c components with the excuse, by component dealers that they are complying with some CAA or FAA ruling. Nonsense.
Patrick
