gfmjr_20(at)HOTMAIL.COM Guest
Posted: Sun Oct 15, 2006 2:59 pm Post subject: First Flight |
Well folks, this list has helped to launch another Zodiac. On Saturday
morning at about 9:00AM, N221GM launched off for its first flight. Sky was
crystal clear, winds calm, and the foliage of New England outstanding. Take
off occurred after about a 450 foot run with a climbout at 85mph. I'm using
a dynon system for EFIS and forgot to set it up with VSI, so my best guess
is that the climb was about 600-700fpm. No attempt was made for a max
climb, just a relatively gently one. I climbed to 2500ft, took a deep
breath, enjoyed the secenery for a couple of minutes and gently circled the
field checking out pitch, roll and yaw. With everything in the green engine
wise the only issued appeared to be the need for continuous back pressure on
the elevator which could not be trimmed out. Speed was 95-100mph
Since the preflight plan was take off, climb to 2500, circle for control
checks and land, it was time to start the drop back to pattern altitute for
landing. I still had the need for significant back pressure on the stick.
Luckily as the speed dropped to 65-70mph the backpressure required also
dropped making the landing approach a lot less exciting than I thought at
first it might be. Knowing I had to continue to hold back stick , I extended
the downwind leg figuring it would give me more time for the final lineup.
All went well. The zodiac is a really well behaved plane, and was very
stable through the base and final. I came over the fence at 65mph and
settled right on the numbers. Full stop was in about 350feet
All suggestions for fixes to alleviate the elevator backpressure are
appreciated. Since the pressure varied with speed, I assume it is probably
a misalignment of incidence between the wing,fuse and/or stab. I'll be
checking that out on Monday.
Thanks to everyone on the list for your comments, suggestions and help
especially to list member Jeff Paris for the familiarization flight.
George May
Zodiac 601XL 912s
N221GM
Try the new Live Search today!
http://imagine-windowslive.com/minisites/searchlaunch/?locale=en-us&FORM=WLMTAG
Posted: Sun Oct 15, 2006 3:23 pm Post subject: First Flight |
George,
Congratulations on your first flight. The adventure has just begun!
Larry McFarland
george may wrote:
Saturday morning at about 9:00AM, N221GM launched off for its first
flight. Sky was crystal clear, winds calm, and the foliage of New
probably a misalignment of incidence between the wing,fuse and/or
stab. I'll be checking that out on Monday.
help especially to list member Jeff Paris for the familiarization
flight.
George May
Zodiac 601XL 912s
N221GM
nfivesl(at)yahoo.com Guest
Posted: Sun Oct 15, 2006 3:38 pm Post subject: First Flight |
George I'm happy for you! Congratulations! Thanks for the detailed description of your first flight. I felt like I was up there with you!
I've heard of a few guys adjusting their horiz. Stab for the same reason you stated below. I'd get some details from the actual guys before taking any action.
Congratulations again!
Scott Laughlin
601XL/Corvair
Engine testing
n801bh(at)netzero.com Guest
Posted: Sun Oct 15, 2006 6:12 pm Post subject: First Flight |
A big congrats to you. The smile you have will last for weeks..
Ben Haas
N801BH
www.haaspowerair.com
-- "george may" <gfmjr_20(at)HOTMAIL.COM> wrote:
--> Zenith-List message posted by: "george may" <gfmjr_20(at)hotmail.com>
George May
Zodiac 601XL 912s
N221GM
http://imagine-windowslive.com/minisites/searchlaunch/?l================================================nbsp;Use the Matronics List Features Navigator&Archive Search & Download, 7-Day Browse,&nb========================= - NEW MATRONICS WEB FORUMS -
================================================ - NEW MATRONICS LIST WIKI&nb========================= &nb Thank you for your generous supportbsp; -Matt Dralle, Li============================================
Michael Valentine
Posted: Sun Oct 15, 2006 6:23 pm Post subject: First Flight |
Great news George - congratulations. I look forward to coming for a visit.
Michael
On 10/15/06, george may < gfmjr_20(at)hotmail.com (gfmjr_20(at)hotmail.com)> wrote:[quote]--> Zenith-List message posted by: "george may" < gfmjr_20(at)hotmail.com (gfmjr_20(at)hotmail.com)>
George May
Zodiac 601XL 912s
N221GM
armyret(at)mchsi.com Guest
Posted: Mon Oct 16, 2006 4:58 am Post subject: First Flight |
Great Job George! Congrats.
Al Young
601XL being painted
clojan(at)sbcglobal.net Guest
Posted: Mon Oct 16, 2006 6:14 am Post subject: First Flight |
George: I look forward to seeing the tag line" first flight" from builders I have followed. Congrats. As far as the stick pressure I riveted a tab on the trim tab that sticks out about 1"" and bends down at a 30 deg angle. Solved the problem. Jack in los Osos Ca
[quote] On 10/15/06, george may < gfmjr_20(at)hotmail.com (gfmjr_20(at)hotmail.com)> wrote: [quote]--> Zenith-List message posted by: "george may" < gfmjr_20(at)hotmail.com (gfmjr_20(at)hotmail.com)>
especially to list member [quote][b]
Ron Lendon
Joined: 10 Jan 2006 Posts: 685 Location: Clinton Twp., MI
steerr(at)bellsouth.net Guest
Posted: Tue Oct 17, 2006 6:25 am Post subject: First Flight |
Way to go, George! Sorry I couldn't be there to witness the flight.
Quote: |
Date: 2006/10/15 Sun PM 06:58:46 EDT
Subject: First Flight
George May
Zodiac 601XL 912s
N221GM
jeffrey-j-paris(at)excite Guest
Posted: Tue Oct 17, 2006 11:58 am Post subject: First Flight |
Hi George,
Congratulations! And way to go! Thanks again for the stickers and the camlock washers, very thoughtful and greatly appreciated.
Jeff Paris
--- On Sun 10/15, george may < gfmjr_20(at)HOTMAIL.COM > wrote:
Date: Sun, 15 Oct 2006 18:58:46 -0400
2500, circle for control <br>checks and land, it was time to start the drop back to pattern altitute for <br>landing. I still had the need for significant back pressure on the stick. <br>Luckily as the speed dropped to 65-70mph the backpressure required also <br>dropped making the landing approach a lot less exciting than I thought at <br>first it might be. Knowing I had to continue to hold back stick , I extended <br>the downwind leg figuring it would give me more time for the final lineup. <br>All went well. The zodiac is a really well behaved plane, and was very <br>stable through the base and final. I came over the fence at 65mph and <br>settled right on the numbers. Full stop was in about 350feet<br><br> All suggestions for fixes to alleviate the elevator backpressure are <br>appreciated. Since the pressure varied with speed, I assume it is probably <br>a misalignment of incidence between the wing,fuse and/or stab. I'll be <br>checking that out on
_______________________________________________
Join Excite! - http://www.excite.com
The most personalized portal on the Web!
amyvega2005(at)earthlink. Guest
Posted: Wed Oct 18, 2006 12:08 pm Post subject: First Flight |
George, check the deflection on the horiz stab. you can adjust the stab higher and that should make the plane go up to offset the down deflection. Wings being off would probably cause a yaw to left or right not up or down.
I could be wrong, I usualy am.
Juan Vega
601xl, Tampa FLA
zodierocket(at)hsfx.ca Guest
Posted: Wed Oct 18, 2006 2:02 pm Post subject: First Flight |
George go for another flight and set yourself up for a level and stable
flight. Now measuere a specific spot on your stick to a specific spot on
your panel. Land and set the stick to the measured distance you did in
the air and check out the elevator. This should indicate the way you
need to move the stabilizer and sometimes you can guess how much you
need to move it also . Repeat this with process until you have a
straight and level flight in typical configuration with an even
elevator. Also before you do ANYTHING get your local advisor to ensure
your in appropriate CG don't guess re-measure and be sure.
cdngoose
Zodiac 601XL C-GOXL, CH801 C-FHUC
www.ch601.org / www.ch701.com / www.Osprey2.com
ggower_99(at)yahoo.com Guest
Posted: Wed Oct 18, 2006 3:59 pm Post subject: First Flight |
Hello George,
Probably this advise is not necesary, but worth mentioning: Try the flight(s) early in the morning, so the air is calm, will work better, sometimes late in the afternoon, but beware of the hour, sometimes we get carried away with a beautyfull sunset and gets dark... Not the best scenario for landing a new airplane...
Good luck and congratulations...
Saludos
Gary Gower.
Flying form Chapala, Mexico.
Zodie Rocket <zodierocket(at)hsfx.ca> wrote:[quote] --> Zenith-List message posted by: "Zodie Rocket"
cdngoose
