		hdwysong(at)gmail.com Guest
				 Posted: Tue Jan 24, 2006 2:55 pm    Post subject: Question for Rotax Drivers... |
				Hi all,
 The Rotax wiring diagram shows the Ducati regulator/rectifier with the
 "L" lead across a lamp.  The connector says "LAMP"... but when exactly
 will this lamp illuminate?
 Can someone tell me or point out the section(s) in any of the Rotax
 manual(s) that describes the function(s) this lamp serves?
 Undervoltage?  Fault?  Overvoltage?  ???
 Specifically, I'm looking for the "nominal" electrical state of the "L"
 lead (e.g. - pulled high, pulled low, open) when:
 -- the 12V bus hot and the engine is not running
 -- the 12V bus hot and the engine is running
 Thanks for your help,
 D
		europabill(at)bellsouth.n Guest
				 Posted: Tue Jan 24, 2006 3:20 pm    Post subject: Question for Rotax Drivers... |
				Check out pages 17-1 and 17-2 of the Rotax 912S Installation Manual (Mine is
 the 9/1/1998 version).  It shows the wiring of the Rotax electrical system.
 The lamp is a charge indicator lamp.  It's notated as item #11.
 Bill
 A010 Monowheel Classic
				 Posted: Tue Jan 24, 2006 3:51 pm    Post subject: Question for Rotax Drivers... |
				Thanks Bill.
 "Charge indicator"... so the lamp will be illuminated ("L" looks like a
 ground) under normal conditions?  Has anyone wired this lamp as shown to
 verify that it's on... all the time?  (how annoying would that be, eh?!)
 If not, is anyone willing to measure the voltage between "L" and ground
 the next time their prop is turning?
 D
  Bill
		daseitz(at)cfl.rr.com Guest
				 Posted: Tue Jan 24, 2006 7:39 pm    Post subject: Question for Rotax Drivers... |
				The lamp is on when the master and the alt switches are on and the alt is
 not charging the battery. It is on until the engine starts and begins
 charging then it goes off.
 Dean Seitz
 N284A
				 Posted: Tue Jan 24, 2006 8:00 pm    Post subject: Question for Rotax Drivers... |
				Thanks a bunch, Dean!
 D
  Dean Seitz
  N284A
		rholder(at)avnet.co.uk Guest
				 Posted: Wed Jan 25, 2006 7:49 am    Post subject: Question for Rotax Drivers... |
				Thanks, Richard.  That's how my schematic was treating it... before I made
 the mistake of reading the manual and seeing the "Charge Indicator" label
 for the lamp which caused a mild fit of second guessing.
 Still wondering what the underlying circuit looks like, though.  With the
 batt/alt switch ON and the engine not turning the lamp should light.  With
 "C" sitting at the batt bus voltage in this case, "L" must be pulled low to
 complete the circuit (light the lamp).  As the generator starts generating,
 I'm not clear whether "L" will gradually float up with the output of the
 regulator or if it looks like a discrete open circuit (like relay contacts
 opening).  ???
 Hopefully I'll be able to measure it myself before too long and can report
 back.
 D
 On 1/25/06, Richard Holder <rholder(at)avnet.co.uk> wrote:
  is
  The "lamp" is a "Low volts warning lamp"
  Richard
		n3eu(at)comcast.net Guest
				 Posted: Wed Jan 25, 2006 12:24 pm    Post subject: Question for Rotax Drivers... |
				D Wysong wrote:
  	  | Quote: | 	 		   Still wondering what the underlying circuit looks like,
  though.  With the batt/alt switch ON and the engine not
  turning the lamp should light.  With "C" sitting at the
 batt
  	  | Quote: | 	 		   bus voltage in this case, "L" must be pulled low to
 Yes.  The "L" terminal is either open (call it infinite
 resistance; system nominally working) or at ground -- lamp
 lit, not working.  There's a transistor switch in there to
 accomplish that, and voltage must be supplied from the
 outside.  So, voltage measurements at the "L" terminal with
 accompanying circuitry will be consistent with only "on or
 off."
 The volts at which the lamp is on or off is a grain-of-salt
 matter.  It has to be set low enough (through a dirt-simple
 reference diode inside the regulator) so that "off" does not
 necessarily mean the battery is being sufficiently charged.
 A/k/a as a "tit on a boar hog."
 Reg,
 Fred F.
