robinfly(at)sbcglobal.net Guest
Posted: Tue Oct 10, 2006 10:29 am Post subject: Main gear doors |
I have a 54 E35. For the last 4 to 5 flights, during pre-flights, I have noticed my main gear doors did not close completely sometimes. One time, they were open about 1/2 inch. But they closed completely after my last flight last weekend. What are they trying to tell me? Can I safely operate my Bonanza until next annual which is Jan 07?
| | - The Matronics Beech-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Beech-List |
thender(at)adelphia.net Guest
Posted: Tue Oct 10, 2006 10:49 am Post subject: Main gear doors |
Hi Robin-
Hopefully the more experienced folks will chime in. But let me get the ball rolling.
Sounds like you may have a tired motor.
On the ground, you should be able to turn the handle 1/8 to 1/4 turn before it hits the stop. If you can turn it more than that, it is stopping prematurely and that explains why the inner doors aren't closed all the way.
In flight, you can do the same test with the gear up. Just turn the opposite direction. The same 1/8 to 1/4 turn applies.
Verify that 1/8 to 1/4 is the proper tolerance for your airplane. I believe that applies to all the 12V airplanes (except for maybe the straight-35's) but double check.
You might also time the extension and retraction process; for the 12V airplanes I think normal is 10 sec or so. Much beyond that is also an indication of a tired motor.
I don't have any good advice about flying the plane with a tired motor, if in fact that is what it turns out to be. It would make me nervous, but I'm paranoid.
Good shops for overhauling the motor are Aircraft Systems in Rockford, ILL and Cruiseair in Ramona, CA.
Again, hopefully folks that have more experience than I will chime in.
-Tom H.
Ventura, CA
brucebell74(at)sbcglobal. Guest
Posted: Tue Oct 10, 2006 11:21 am Post subject: Main gear doors |
For some reason the landing gear motor is shutting off too soon. I would put it on jacks and get it checkout before anymore flights. Something is out of rig!
Bruce Bell
A35 Bonanza 1730 N723B
cook.thom(at)gmail.com Guest
Posted: Tue Oct 10, 2006 4:18 pm Post subject: Main gear doors |
Robin,
It may not be the motor at all . Have you checked the rods under the front seats that connect there. You can have as much as 3/4 inch of play on the closing if they are not adjusted and tightened properly.
Thom
On 10/10/06, Bruce Bell <brucebell74(at)sbcglobal.net (brucebell74(at)sbcglobal.net)> wrote:[quote] For some reason the landing gear motor is shutting off too soon. I would put it on jacks and get it checkout before anymore flights. Something is out of rig!
Bruce Bell
Gary Strong
Posted: Tue Oct 10, 2006 6:48 pm Post subject: Main gear doors |
Robin,
There is lots of info on the American Bonanza site on this issue. I had the same problem and it was a tired gear motor. There should never be a reason to adjust the linkage on a Bonanza. If the parts are worn in the linkage replace them, but I believe 99% of the time it’s a tired gear motor. I wouldn’t wait to replace it. While we can definitely lower the gear manually, its not much fun to do this in IMC!
Gary
From: owner-beech-list-server(at)matronics.com [mailto:owner-beech-list-server(at)matronics.com] On Behalf Of Robin Hou
Sent: Tuesday, October 10, 2006 1:26 PM
To: Beech Matronics
Subject: Main gear doors
I have a 54 E35. For the last 4 to 5 flights, during pre-flights, I have noticed my main gear doors did not close completely sometimes. One time, they were open about 1/2 inch. But they closed completely after my last flight last weekend. What are they trying to tell me? Can I safely operate my Bonanza until next annual which is Jan 07? | Quote: | | http://www.matronics.com/Navigator?Beech-List | 01234567890123
_________________ Gary S.
1973 B55 Baron
N761T |
bonanza(at)vodamail.co.za Guest
Posted: Tue Oct 10, 2006 9:55 pm Post subject: Main gear doors |
I had the same thing, it just got inconsistent and then the gear started taking longer to extend.Finally one
day, select gear down, and nothing. That got my attention! Uneventful manual extension, and later on the jacks
the gear worked ok, but slow. Pulled the motor and it was full of carbon dust. Rebuilt-end of problem; retract
speed much better and trouble free ops since then.
Good luck
Bob Verwey
A35 ZU-DLW
Posted: Tue Oct 10, 2006 10:04 pm Post subject: Main gear doors |
Hi Bob-
I think timing the gear extension/retraction process from time to time is a
good diagnostic tool. I try to do it before and after our annual
inspections, and again at about the midway point between annuals.
Ours has consistently been between about 9.5 seconds (12 V Debbie). I try
to check the free-play in the transmission at the same time.
Hopefully that will help identify a motor or rigging issue before it becomes
a problem. But so far, nothing has changed, which is good news!
-Tom H.
Ventura, CA
Posted: Tue Oct 10, 2006 10:55 pm Post subject: Main gear doors |
Tom,
Lets face it, these airplanes are talking to us if we would just listen!Anything to avoid the "pucker factor"
<g>
Bob Verwey
aeroads(at)comcast.net Guest
Posted: Wed Oct 11, 2006 4:35 am Post subject: Main gear doors |
The gear motor does grind up a lot of carbon dust I clean mine every year and have had to clean a few in the Out Islands of the Bahamas Its an easy job to pull the passenger's seat, disconnect the wires (mark for reinstallation), back out the three motor mounting machine screws, pull the motor toward the rear, catch the first gear. With the motor removed and on the bench, remove the black plastic brush holder, pull the brushes. Remove the long motor assembly screws allowing disassembly of the motor. Finally clean everything with a tooth brush and lacquer thinner If you go thru this ritual periodically you will have a more reliable gear and fewer motor overhauls and operating with a dirty motor is inadvisable Murray Randall
Posted: Wed Oct 11, 2006 9:22 am Post subject: Main gear doors |
Thanks. I will check free play on the ground, and put it on jacks to time retract & check free play again. Will report back what I find. Robin
Posted: Wed Oct 11, 2006 9:50 am Post subject: Main gear doors |
Robin-
Do the retract/extend timing in the air as aero loads can affect the timing.
You can check the free play in the air too. Just remember which way to turn for the up and down checks.
One issue with ground swings is that the system voltage can affect motor performance. In the air, loads are higher due to air forces but motor voltage is higher too; probably ~14V vs ~12V on the ground (battery only)
Some folks will argue that the lower voltage offsets the air loads. But the best place to verify the free play and the timing is in the air.
My $.02.
-TH
Posted: Wed Oct 11, 2006 10:19 pm Post subject: Main gear doors |
Murray I would have thought the thinner might damage certain insulating materials?
Bob Verwey
A35
