LarryRosen
Posted: Mon Oct 09, 2006 6:12 am Post subject: Glueing the foam ribs into the trims tabs of the elevator |
I used RTV silicone to glue the foam ribs in place.
Larry Rosen
#356
Michael Wellenzohn wrote:
Hello,
so far I used tank sealant to glue the foam ribs into the elevator. Since I always need to order the small portion from Van's (no known vendor available in Switzerland) I wonder I anyone used a product which is also available in Europe. Would Scotch-Weld work to and if yes which product number of Scotch-Weld?
Thansk for your help.
Michael
empennage / elevator trims
http://www.wellenzohn.net
RV-10 builder
#511
http://forums.matronics.com/viewtopic.php?p=66682#66682
_________________ Larry Rosen
#40356
N205EN (reserved)
<http> |
jdalton77(at)comcast.net Guest
Posted: Mon Oct 09, 2006 6:28 am Post subject: Glueing the foam ribs into the trims tabs of the elevator |
I used a commercially available epoxy from the airplane department at Home
Depot. It was formulated for metal and plastic bonding. Worked great and
bonded in 5 minutes.
Jeff
