rv8striker(at)hotmail.com Guest
Posted: Fri Oct 06, 2006 6:31 am Post subject: HEADset woes |
List,
I finally took the plunge and bought the Thirty 3G Lightspeeds. The day after they arrived I used them in the corporate jet that I fly. They worked beautifully and because the jet has Bose headsets, I was able to do a back to back comparison, which BTW, seemed to be about even on all points. Anyway, here's the problem. When I use the Lightspeeds in my RV-8, I get a squeal in the interphone when the volume is turned up past a point where I can hear the back seater. If the volume is low enough, it goes away but so does my ability to hear my passenger. I don't think it's feedback. It sounds more like it's related to the VOX threshold. Once the threshold is crossed and the volume is too high, it squeals. Turn the volume down, the VOX clips off and the squeal stops. If I put the LS's in the rear and my "cheapos" in the front, the LS's work fine. I tried the Bose in the RV and they work beautifully in the front or rear. Until now (60 hours) my two cheepos have worked fine.
I've talked to the techs a LS and they have no idea. They seem to think it's my airplane...but why does brand "B" (and my cheepos) work in my plane and theirs does not?
I also talked to the guys in the avionics shop at work. They think it could be a mismatch between the LS's (stereo) and my cheepos. (mono)
My next step is to try two stereo sets and see if that's the problem but in the meantime any ideas from you guys would be appreciated.
Steve Struyk
St. Charles MO
FLYaDIVE(at)aol.com Guest
Posted: Fri Oct 06, 2006 8:37 am Post subject: HEADset woes |
In a message dated 10/6/2006 10:33:59 AM Eastern Standard Time, rv8striker(at)hotmail.com writes:
| Quote: | I've talked to the techs a LS and they have no idea. They seem to think it's my airplane...but why does brand "B" (and my cheepos) work in my plane and theirs does not?
Steve Struyk
St. Charles MO
Hi Steve:
I think the avionics shop is on the right track but needs to refine their thought process just a bit.
It is NOT the stereo, it is the MIC. The Mic is not stereo (not that it needs to be) and it could very well be the MIC impedance between the two different headsets that is causing the problem.
Now to confuse you a bit further ... It is not the headsets, it is the intercom. Yes, there probably is a difference between the headsets impedance but it is the intercom, that is not being able to handle the difference that is causing the problem.
The way to check this out is to use the same type of headset in BOTH the front and read seats at the same time; both Bose's and then both LS.
ALSO ... It is important to check the following:
1 - Battery condition in ALL headsets.
2 - Position of the headset on the head ... Nice and secure, no air/sound leaks around the ear pieces.
3 - MIC position ... Close to the mouth, just above the upper lip ... So when opening the mouth in Awe (as you roll the plane) there is no rushing sound.
4 - Mic Muff - Make sure ALL mic's are muffed with that foam thing.
5 - NEVER leave a headset plugged in when it is not being used during flight. This is especially true of Noise Canceling headsets. Doing so will cause all sorts of noise problems.
But, I'd bet it is the intercom with one of these problems:
1 - Impedance mismatch.
2 - Intercom has only ONE Squelch control; better to have a squelch and volume control for pilot & copilot. Note: 4 seat intercoms do not have a squelch for the passengers.
Hope this helps.
Barry
"Chop'd Liver"
rv8a2001(at)yahoo.com Guest
Posted: Fri Oct 06, 2006 10:00 am Post subject: HEADset woes |
Try to duplicate the problem on the ground with out the engine running..........I am not sure what exactly this will indicate, but somebody here with more knowelegeable than me might be able to make a connection to the problem. I would think if the issue is not duplicated, there might be a mic problem as others mentioned.
Scott Bilinski
RV-8a
charlieray(at)optonline.n Guest
Posted: Fri Oct 06, 2006 2:45 pm Post subject: HEADset woes |
What kind of Intercom?
Posted: Fri Oct 06, 2006 3:06 pm Post subject: HEADset woes |
I've had several people ask about my intercom. It's a Garmin 340 audio panel.
Steve
brucebell74(at)sbcglobal. Guest
Posted: Fri Oct 06, 2006 3:37 pm Post subject: HEADset woes |
I have found in my RV-4 if the ear pieces are not seated or tight to the ear I can get some weird nose. My sun glasses can cause a leak.
Bruce Bell
Lubbock, Texas
RV-4 N23BB
