		peter.rees01(at)tiscali.c Guest
				 Posted: Tue Jan 24, 2006 3:13 pm    Post subject: Cold starting problems |
				We are still having tremendous problems getting HI started in the cold.
 We've replaced the battery but the engine still shakes violently when
 cranked and seems to run in whats been described as 'sub idle' before we
 execute a somewhat rapid shut down.
 Once it has started, it runs very nicely - never missing a beat and it
 starts very well indeed when warm - on the button every time.
 Trawling the archive gives me the very strong impression that our sprag
 clutch is due for the bin but I'd rathter get someone familiar with Rotax
 starting problems before changing such an expensive part (or getting it done
 more like!) and finding out that its one of the carbs!
 Can anyone tell me - is it possible to remove the starter without taking the
 engine out in a 912 classic?
 Conrad seems to be pretty well booked up at present - has anyone used Adrian
 Lloyd? If so (and he is any good) - does anyone have a contact number for
 him (or anyone else that can be recommended).
 Really need to get this sorted before the starter or engine frame quits.
 Thanks in anticipation
 Peter
  |  | - The Matronics Europa-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		paul.mcallister
  Joined: 09 Jan 2006 Posts: 177 Location: Waukesha, WI USA
				 Posted: Tue Jan 24, 2006 5:11 pm    Post subject: Cold starting problems |
				Peter,
 Lockwood Aviation in the US recommend having the gearbox clutch adjusted
 every 300 hours.  I sent mine in and they replaced it, I am assuming that
 there wasn't any adjustment left.  It cost me about $140.00 including
 freight to have the work done.
 Paul
		rholder(at)avnet.co.uk Guest
				 Posted: Wed Jan 25, 2006 1:27 am    Post subject: Cold starting problems |
				 	  | Quote: | 	 		   We are still having tremendous problems getting HI
  started in the cold. We've replaced the battery but the
  engine still shakes violently when cranked and seems to
  	  | Quote: | 	 		   Trawling the archive gives me the very strong
  impression that our sprag clutch is due for the bin but
  I'd rathter get someone familiar with Rotax starting
  getting it done more like!) and finding out that its
  one of the carbs!
  	  | Quote: | 	 		   Can anyone tell me - is it possible to remove the
  starter without taking the engine out in a 912 classic?
 Mine is an XS firewall forward so I am not certain, but I
 believe a starter motor out job on a classic f/f/w
 requires engine out.
  	  | Quote: | 	 		   Conrad seems to be pretty well booked up at present -
  has anyone used Adrian Lloyd? If so (and he is any
  good) - does anyone have a contact number for him (or
 Adrian changed mine for me, in situ. I recommend him !
  	  | Quote: | 	 		   Really need to get this sorted before the starter or
  engine frame quits.
 What I am nor sure of is whether the shaking is caused by
 the worn sprag clutch or whether the worn sprag clutch has
 been caused by the non-starting and kick-back.
 The kick-back is caused by the starter just not being man
 enough to do the job. (912S). Adrian put a HD starter on
 for me and the engine starts instantly now.
 If yours is a 912 then Peter Jeffers may help - he was
 having similar problems and changed his sprag clutch at
 around 1000 hours.
 I understand that the HD starter motor will not fit inside
 the classic engine mount. It is only a matter of 1/4 inch
 or so. Maybe some judicious cutting and rewelding might
 work (if approved !) or a large hammer ?
 Richard
		nigelcharles(at)tiscali.c Guest
				 Posted: Wed Jan 25, 2006 11:40 am    Post subject: Cold starting problems |
				 	  | Quote: | 	 		  >Can anyone tell me - is it possible to remove the starter without
 taking the engine out in a 912 classic?<<
 The Classic engine mount obscures the starter from removal with it in
 situ. Its close proximity to the engine also means that the more
 powerful starter cannot be fitted. Modifying the frame is not possible
 as the area that needs modification also happens to be the position of
 the head of the top starboard engine mount bolt. Any upgrade to the more
 powerful starter means changing to the XS mount which means a full
 upgrade to XS firewall forward. I have done this and the new starter
 seems to solve the kickback problem. With this in mind I would say that
 the combination of the Classic and the 912S is not good unless you like
 regular sprag clutch replacements.
  	  | Quote: | 	 		  Conrad seems to be pretty well booked up at present - has anyone used
 Adrian Lloyd? If so (and he is any good) - does anyone have a contact
 number for him (or anyone else that can be recommended).<
 Adrian replaced my sprag clutch for me. He has done quite a few now. I
 can fully recommend him. His number is 01885 482504.
 Nigel Charles
				 Posted: Wed Jan 25, 2006 12:15 pm    Post subject: Cold starting problems |
				Hi Nigel
 Thanks for the contact info - I'll give him a call.
 Ours is a 912, not the 912s. I'll give Adrian a call and ask his opinion.
 One thing I had thought of trying was to fine off the prop - its about 18
 degrees at the moment - maybe this is restricting the speed that the starter
 can turn the engine - Do you think this could be worth a try??
 Thanks once again for contact info.
 Peter
				 Posted: Thu Jan 26, 2006 2:15 pm    Post subject: Cold starting problems |
				 	  | Quote: | 	 		  One thing I had thought of trying was to fine off the prop - its about
 18
 starter
 can turn the engine - Do you think this could be worth a try??<
 I doubt whether there is a significant change in drag for various prop
 settings at such low rpm.
 Nigel
