rlborger(at)mac.com Guest
Posted: Sun Oct 01, 2006 4:15 pm Post subject: Copper Washers |
Europaphiles:
Does anyone have a source for the copper washers for the banjo fittings on the fuel pressure regulator?
I hope to replace the hose barb banjos on my fuel pressure regulator with AN-4 sized banjos that I have acquired from a local auto racing supply house. They could supply the fittings but no copper washers.
Anyone care to comment on the plan?
Good building and great flying,
Bob Borger
Europa Kit #A221 N914XL, XS Mono, Intercooled 914, Airmaster C/S
http://www.europaowners.org/N914XL
(85%) tail kit done, wings closed, cockpit module installed, pitch system in, landing gear frame in, rudder system in, outrigger mod in, Fuselage Top on, lift/drag/flap pins in, wing incidence set, tie bar in, flap drive in, Mod 70 done. Baggage bay in. Flaps & Main Gear complete. Working in - 24 Instrument Panel, 25 Electrical, 30 Fuel System, 32 Tail, 34 Door Latches & 35 Doors, 37 Finishing. Airmaster arrived 29 Sep 05. Seat arrived from Oregon Aero. E04 interior kit has arrived. Preparing for ROTAX 914 installation.
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
n100rh(at)sbcglobal.net Guest
Posted: Mon Oct 02, 2006 7:37 am Post subject: Copper Washers |
Bob,
I sure would like to know more about the AN banjos you've found, for the
same reason as you've gone to them. Are you sure you want to use copper?
Why not the washers that are normally used with the AN fittings?
Ralph
RKHallett III
XS MG
rlborger wrote:
| Quote: | Europaphiles:
Bob Borger
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
Horizonspace(at)aol.com Guest
Posted: Fri Oct 06, 2006 3:40 pm Post subject: Copper Washers |
In a message dated 10/1/2006 7:16:42 P.M. Central Daylight Time, rlborger(at)mac.com writes:
Bob Borger
Bob,
We evaluated using AN banjos and here are our findings:
The Rotax banjo fittings are for use with M10x1x19 banjo bolts per Rotax parts manual. You can buy the 10mm banjos with AN-4 flared attachments from Summit Racing under the Aeroquip or Earl brand. The washers are 10mm "crush washers". You can get them from Lockwood or you can get aluminum ones from Summit. After all the research, we decided against this mod for the following reason. The AN-4 ID is 4.35mm while the OEM banjo ID is 5.85mm. The mod would reduce the ID by over 25%. The effects to the overall performance is unknown but we do not want to find out the hard way. Perhaps you can ask Lockwood when you attend the maintenance course and report back.
Tam
Posted: Fri Oct 06, 2006 5:38 pm Post subject: Copper Washers |
Tam:
You commented:
would
I was going to make exactly that measurement tomorrow when I get back to the Europa.
That seems significant. As I said, I wasn't going to replace the fittings until after my Rotax 9xx class in December and I had an OK from Lockwood in any case. I will report back after I have spoken with the Lockwood folks.
I still need to get up to meet you folks one of these weekends.
Thanks for the comments and information,
Bob Borger
3705 Lynchburg Dr.
Corinth, TX 76208
Home: 940-497-2123
Cel: 817-992-1117
Posted: Fri Oct 06, 2006 5:41 pm Post subject: Copper Washers |
Tam,
Thanks for the info, I too have been looking at the AN fittings. I
really don't like hose for fuel.
Ralph
Horizonspace(at)aol.com wrote:
| Quote: | In a message dated 10/1/2006 7:16:42 P.M. Central Daylight Time,
Europaphiles:
copper washers.
Bob Borger
Bob,
Tam
Posted: Tue Oct 10, 2006 1:12 pm Post subject: Copper Washers |
Bob,
If the AN-4 banjos will not work for you, I just thought of another possibility. Perhaps you can replace the banjos with straight M10 to AN-6 adapters and attach the fuel lines with 90 degrees AN-6 swivel fittings.
Just a thought,
Tam
In a message dated 10/6/2006 8:39:33 P.M. Central Daylight Time, rlborger(at)mac.com writes:
| Quote: | Tam:
You commented:
would
Bob Borger
