MikeEasley(at)aol.com Guest
Posted: Sun Oct 01, 2006 5:06 am Post subject: Glowing LED Warning Lights, Too Dark Now |
My LED voltage warning lights are now too dark to see in daylight after adding the resistors in the drawing.
Smaller resistors?
Deal with the glow?
Ideas?
Thanks in advance,
Mike Easley
Lancair Super ES, 12V
nuckollsr(at)cox.net Guest
Posted: Sun Oct 01, 2006 10:40 am Post subject: Glowing LED Warning Lights, Too Dark Now |
At 09:04 AM 10/1/2006 -0400, you wrote:
| Quote: | My LED voltage warning lights are now too dark to see in daylight after
Smaller resistors?
Deal with the glow?
What kind of LED's are you using? Individual lamps
or something buried in an assembly? Are they fitted with
any kind of built-in resistor? I.e., designed already
to run directly from 12 or 24v?
Adding the pair of 220 ohm resistors as shown in
http://www.aeroelectric.com/Pictures/Schematics/LV_Led.jpg
assumes that your LED is "barefoot", i.e. no additional
resistances other than those shown in the schematic.
If your led has any such series resistances, then eliminate
the series 220 ohm resistor entirely and run only one
220 ohm resistor in parallel with your resistor-led
combination.
< with experiment. >
< --Lawrence M. Krauss >
