john(at)fureychrysler.com Guest
Posted: Wed Sep 27, 2006 4:25 pm Post subject: Cleveland tail wheel |
I've been staring at nose wheels for the past 6 years so please excuse my ignorance but I just looked at two Cleveland tail wheels and noticed that what looks like a zerk grease fitting is just a hole to the center of the wheel. Looks like a sealed bearing on each side. Seems like an odd set up to me. Any insight would be appreciated.
John Furey
2 RV6A
RV7 in process
sbuc(at)hiwaay.net Guest
FLYaDIVE(at)aol.com Guest
Posted: Thu Sep 28, 2006 3:11 am Post subject: Cleveland tail wheel |
In a message dated 9/27/06 8:28:13 PM Eastern Daylight Time,
john(at)fureychrysler.com writes:
| Quote: | I've been staring at nose wheels for the past 6 years so please excuse my
to
| Quote: | me. Any insight would be appreciated.
John Furey
2 RV6A
RV7 in process
John:
Some maybe bearings, what is know as an OPEN bearing, but many are
bushings/sleeves. So a simple grease fitting is all that is required, even for the open
bearing.
Take a look at RV-6A's nose wheel. It has a simple bushing and grease
fitting.
Barry
rv9jim(at)juno.com Guest
Posted: Thu Sep 28, 2006 5:15 am Post subject: Cleveland tail wheel |
John,
I believe that the old tail wheels used taper roller bearings
which required exterior lubrication. If they are now using a sealed ball
bearing, then the zerk fitting is not required and no maintenance is
required to the bearing. Just check it occasionally to see that the
bearing is operating smoothly and not worn out. That will give you some
interesting tracking problems.
Jim Nelson
