sidsel.svein(at)oslo.onli Guest
Posted: Wed Sep 27, 2006 9:54 am Post subject: Coolant temp reading by GRT EIS |
Has anyone used one of the Aux. inputs to Grand Rapids EIS 4000 for reading the coolant temperature by a probe into the coolant, with output 0-5 V?
Would appreciate details with respect to type of probe/where sourced and where/how placed into the coolant.
Best regards,
Svein
LN-SKJ
josok-e(at)ukolo.fi Guest
Posted: Wed Sep 27, 2006 11:05 am Post subject: Coolant temp reading by GRT EIS |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> <!-- /* The original subSilver Theme for phpBB version 2+ Created by subBlue design http://www.subBlue.com NOTE: These CSS definitions are stored within the main page body so that you can use the phpBB2 theme administration centre. When you have finalised your style you could cut the final CSS code and place it in an external file, deleting this section to save bandwidth
jodel(at)nildram.co.uk Guest
Posted: Thu Sep 28, 2006 1:45 am Post subject: Coolant temp reading by GRT EIS |
Have a look at http://www.skydrive.co.uk/sd_sa_91.asp It might be what you need.
Simon
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of Sidsel & Svein Johnsen
Sent: 27 September 2006 18:54
To: Europa List
Subject: Coolant temp reading by GRT EIS
Best regards,
Svein
LN-SKJ
01234567890123
Posted: Thu Sep 28, 2006 8:14 am Post subject: Coolant temp reading by GRT EIS |
Simon,
Appreciate this, but Skydrive's coolant temp reading sets are based on VDO sensor and they are all resistance type while the one available input channel to GRT EIS that I have left requires a voltage variation.
Now, if I had a converter from resistance to voltage - - - ??
Best regards,
Svein
