josok-e(at)ukolo.fi Guest
Posted: Tue Sep 26, 2006 10:36 am Post subject: the ultimate ventilator |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> <!-- /* The original subSilver Theme for phpBB version 2+ Created by subBlue design http://www.subBlue.com NOTE: These CSS definitions are stored within the main page body so that you can use the phpBB2 theme administration centre. When you have finalised your style you could cut the final CSS code and place it in an external file, deleting this section to save bandwidth
jodel(at)nildram.co.uk Guest
Posted: Thu Sep 28, 2006 1:43 am Post subject: the ultimate ventilator |
Hi Jos,
I have fitted these to my Europa. I can confirm that the holes were not threaded on mine. As for the gap, mine were quite tight (less than 0.5mm) much the same as in pic 3 of 9 posted on EuropaOwners by Bob.
Mine are mounted lower down than Bob’s and are roughly where most people have the NACA vents. I mounted mine on the inside face of the outside skin (if that makes sense!) This produced a very nice flush finish on the outside.
Cheers
Simon
From: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] On Behalf Of josok
Sent: 26 September 2006 19:35
Subject: the ultimate ventilator
Decided that these would be the ventilators for me. Although i have a deep rooted distrust to anything that is called perfect or ultimate
But:
Although there are countersunk screws supplied with the unit, there is no thread in the holes. There remains also a small gap between the valve and the body of the unit. The ventilaters are unpainted, blanc aluminium. Do i have some rejects or is this normal for these ultimate articles?
Kind Regards,
Jos Okhuijsen
01234567890123
