TELEDYNMCS(at)aol.com Guest
Posted: Wed Sep 27, 2006 4:43 am Post subject: Ultimate Ventilators |
In a message dated 9/27/2006 3:44:00 AM Eastern Daylight Time, europa-list(at)matronics.com writes:
Hi Jos
| Quote: | Decided that these would be the ventilators for me. Although i have a deep rooted
distrust to anything that is called perfect or ultimate
But:
Although there are countersunk screws supplied with the unit, there is no thread
in the holes. There remains also a small gap between the valve and the body
of the unit. The ventilaters are unpainted, blanc aluminium. Do i have some rejects
or is this normal for these ultimate articles? |
I have Ultimate Ventilators installed in N245E (and also in my Citabria N9529S) ) and I love them! Aside from the price they are really great additions and provide excellent ventilation.
I installed mine on either side just below the panel, essentially where most folks install the crappy plastic NACA vents. I used the holes left by mounting the fuselage into the cradle and enlarged them to fit the UV's. This location gives a nice blast of air from your kneecaps to your face, even when idling on the ground.
Mine were also unpainted and there was a slight gap between the outer ring and the "valve". I think this gap is to allow for paint. I bonded mine in with Redux, but you could use the screws provided if you tap the body or you could do both.
I gurantee you are gonna love them!
John Lawton
Dunlap, TN
N245E - Flying 37.0 hours - Should bust my 40 TODAY!
josok-e(at)ukolo.fi Guest
Posted: Wed Sep 27, 2006 9:21 am Post subject: Ultimate Ventilators |
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"> <!-- /* The original subSilver Theme for phpBB version 2+ Created by subBlue design http://www.subBlue.com NOTE: These CSS definitions are stored within the main page body so that you can use the phpBB2 theme administration centre. When you have finalised your style you could cut the final CSS code and place it in an external file, deleting this section to save bandwidth
SPurpura(at)aol.com Guest
Posted: Wed Sep 27, 2006 4:55 pm Post subject: Ultimate Ventilators |
John,can you post a pic of your vents? [quote][b]
SteveD
Posted: Wed Sep 27, 2006 6:28 pm Post subject: Ultimate Ventilators |
Photos of the Ventilators:
http://www.europaowners.org/UVentilator
I decided to add the ventilators high like in the photos I took at flightcrafters in 2001 ... I think. The photos don't look like that builder added any reinforcement. I wasn't that brave, so I thought I'd and a layer of the Kevlar I had laying around.
I drilled the whole on the starboard side cleaned and trimmed and did the kevlar lay-up. The out side skin was thick and needed to be ground down in spots and evened out.
When I drilled the whole port side the outer skin was one ply thick tops and in spots only jell coat, a fairly large chunk of glass / jell just cracked and fell off.
I sanded off the coating on the port side and I'll lay-up a little reinforcement later.
So putting the ventilator in a slightly questionable spot was actually a good thing for me.
I noticed the recess after I cut the first whole. So I think I'm stuck with it. After I did that it looked to me that one could cut the larger whole on the out side skin. A smaller odd shaped on the inside and have the vent flush with the out side skin. ... just a thought.... But I'm sure if I apply the five day rule I be happy with what I have.
5 Day Rule. Walk away don't look at it for 5 five days. When you look at it again in 5 days if it still bothers you ... Fix it. Sometimes you're just to close to something while working on it and you see every flaw.....
Chat Later,
Steved
-------------------- m2f --------------------
Visit - www.EuropaOwners.org
http://www.europaowners.org/viewtopic.php?p=12801#12801
