gerf(at)gerf.com Guest
Posted: Mon Sep 25, 2006 1:43 pm Post subject: Van's steam gauges versus Dynon EFIS |
At one point this weekend the barometer at the field where I'm
building was exactly 29.92 - the Dyon EFIS read 62 feet, the
official field elevation is 66 feet. I also installed one of
Van's "steam gauge" Altimeters - supposedly a fallback
instrument if my wiring/plumbing goes belly up on the first
flight. The steam gauge reads minus 20 feet :-\
I know which gauge will be junked out of my panel at the first
opportunity ...
__g__
Gerry Filby gerf(at)gerf.com
J2j3h4(at)aol.com Guest
Posted: Mon Sep 25, 2006 3:35 pm Post subject: Van's steam gauges versus Dynon EFIS |
If you are just taking the reading from a physical barometer and setting that in the window of your steam gauge, you will almost certainly not get the correct altitude. That reading must be corrected for temperature and humidity. The reading you get from AWOS or other FAA weather source has this correction made. For an explanation see http://www.exploratorium.edu/weather/barometer.html
Jim Hasper
In a message dated 9/25/2006 4:45:42 P.M. Central Daylight Time, gerf(at)gerf.com writes:
| Quote: | --> RV-List message posted by: Gerry Filby <gerf(at)gerf.com>
opportunity ...
__g__ |
Posted: Mon Sep 25, 2006 4:01 pm Post subject: Van's steam gauges versus Dynon EFIS |
Hmm, so you're suggesting that the Dynon is making those
corrections ? It does have an OAT temperature sensor, but
obviously not a humidity sensor.
The two instruments have consistently differed by about 80 feet
g
and setting
_http://www.exploratorium.edu/weather/barometer.html_
(http://www.exploratorium.edu/weather/barometer.html)
Jim Hasper
opportunity ...
__g__
__g__
khorton01(at)rogers.com Guest
Posted: Mon Sep 25, 2006 5:53 pm Post subject: Van's steam gauges versus Dynon EFIS |
All he is saying is that there is a difference between barometric
pressure and altimeter setting. The original poster used the term
barometer. If he read a barometer, and it was at 29.92, then the
altimeter setting would almost certainly have been something other
than 29.92. For example, if the pressure was as per the standard
atmosphere, the altimeter setting would be 29.92. The barometric
pressure at sea level would be 29.92 in HG. The barometric pressure
at 66 ft would be 29.85 in HG. So, if the barometric pressure at 66
ft was actually 29.92, that implies the pressure was higher than
standard, and the altimeter setting would be greater than 29.92.
Note: the weather folks also publish barometric pressures which are
the station pressure, corrected to sea level. But even these values
are not the same as an altimeter setting. The difference between the
station pressure corrected to sea level and the altimeter setting
will depend on the air density, which also depends on the temperature
and humidity, as mentioned earlier.
I'm hoping the original poster actually used an altimeter setting,
and that it came from a credible source (e.g. a control tower). If
it came from a less credible source, then the altimeter setting may
have been in error.
Kevin Horton
On 25 Sep 2006, at 20:00, Gerry Filby wrote:
g
> and setting
> Jim Hasper
> opportunity ...
> __g__
Kevin Horton
Ottawa, Canada
ogoodwin(at)comcast.net Guest
Posted: Mon Sep 25, 2006 6:25 pm Post subject: Van's steam gauges versus Dynon EFIS |
You have to remember that there is a tolerance for altimeters...even in jet
transports with two or more altimeters, there will be a difference. With
the new glass cockpits and computerized instruments that may not be as true
as with the old baro altimeters.
Posted: Mon Sep 25, 2006 7:04 pm Post subject: Van's steam gauges versus Dynon EFIS |
The original poster was I
The pressure - 29.92 - was read off a digital weather station
located on the field at 66 feet ASL (my personal one, nothing
to do with the airfield). I was reasoning that since I was
more-or-less at sea level (66 feet ASL) and the barometer was
reading 29.92, this must be a "standard pressure" day ...
therefore the altimeters should be reading the actual altitude
of the field - 66 feet. The Dynon EFIS read 62 feet and the
steam gauge read minus 20 - thus the steam gauge is almost 90
feet out. I think ... ~( )
g
have been in error.
Kevin Horton
> g
>> and setting
>> Jim Hasper
>> opportunity ...
>> __g__
Kevin Horton
Ottawa, Canada
__g__
Posted: Mon Sep 25, 2006 9:32 pm Post subject: Van's steam gauges versus Dynon EFIS |
I believe the Dynon is determining altitude by GPS.
The following is a quote from the Dynon Forum: GPS altitudes will not necessarily compare to barometric altitudes. They will only be the same if the atmosphere is at standard temperature all the way from the ground to the test altitude, which is never the case.
While it is quite possible that your mechanical altimeter DOES have an error, you won't know that until you set it using a corrected barometer reading from an FAA weather report. Even if you were AT sea level, you still wouldn't have a standard reading unless the temperature and humidity were also at standard conditions.
Jim Hasper
In a message dated 9/25/2006 7:03:03 P.M. Central Daylight Time, gerf(at)gerf.com writes:
g
and setting
Jim Hasper
opportunity ...
__g__
__g__
---------------------------------------------------------es Day --> - NEW MATRONICS WEB FORUMS -
bsp; --> nbsp; - NEW MATRONICS LIST WIKI -
_-= ; p; - List Contribution Web Site ; =========================
Posted: Tue Sep 26, 2006 1:54 am Post subject: Van's steam gauges versus Dynon EFIS |
Ah. Sorry about the confusion.
Let's assume that your digital weather station is accurate. Does it
correct for field elevation, or does it provide a raw barometric
pressure? If it is providing a raw barometric pressure, then a
reading of 29.92 represents the pressure you would expect to see at
sea level on a standard day. If you put in an altimeter setting of
29.92, you have just told your altimeter that the pressure at the
field elevation is the same as a standard day at that altitude. So,
the altimeter is seeing a pressure of 29.92, and it should display
sea level (0 ft), as that is the altitude at which the pressure would
be 29.92, on a standard day. In this case your steam driven
altimeter is closer than the Dynon.
If your weather station corrects for field elevation, then the Dynon
is probably closer than the steam driven one.
But, both altimeters have means to adjust them to correct for small
errors. The Dynon has a setup menu item, and the steam driven
altimeter has a way to change the relationship between altitude and
altimeter setting. These small errors will be corrected when you
have your static system check done.
Kevin
On 25 Sep 2006, at 23:02, Gerry Filby wrote:
g
> have been in error.
> Kevin Horton
>> g
>>> and setting
>>> this
>>> Jim Hasper
>>> opportunity ...
>>> __g__
> Kevin Horton
> Ottawa, Canada
__g__
Kevin Horton
Ottawa, Canada
pgroell
Posted: Tue Sep 26, 2006 3:18 am Post subject: Van's steam gauges versus Dynon EFIS |
Just to add a bit more. It would have been interesting to make a reading
by having the altimeter set to the QNH.
The QNH being the pressure you have to set on the altimeter to read the
field's altitude on the altimeter. (the QNH being rarely if never equal
to the real sea level pressure due to the difference in density between
the ideal standard atmosphere between sea level and the airport and the
real atmosphere we have out there).
By being not to precise one could say that your QNH whas around 29.92 +
0.06 (for 66ft) : 29.98.
By tuning the altimeter to 29.98 your reading would have gone up around
66ft (all this is not exactly exact due to density adjustments no being
taken into account)and I concurr with Kevin the mechanical altimeter
would have been nearer to the real altitude than the Dynon.
To finish two remarks :
- on my big aircraft (Airbus A330 and A340) the tolerance is +- 25ft
between normal altimeters on the ground and +-200ft between those
altimeters and standby altimeter.
- it is quite difficult to understand how altimeters truly work, but try
to be aware that this is a very "tricky" instrument, using a standard
table for reference when the atmosphere is never standard. And we use
settings which are sometimes not fully understood (QNH shows the
airports altitude when set on the altimeter and aircraft on the ground,
in France we sometimes use QFE which shows 0 when set on the altimeter
and aircraft on ground). Those settings are correlated to measured
barometric pressure but are obtained after some calculation or reading
in a table.
For example you can try to solve the following little puzzle : two
airfields are only a few miles apart. Field A altitude is 275ft, field B
altitude is 1900ft. Temperature throughout the whole atmosphere is ISA +
20° Celsius. QNH at A is 30,47 inHg.
What would the QNH be at field B?
Same as in A, more or less?
Pascal
Kevin Horton a écrit :
the altimeter is seeing a pressure of 29.92, and it should display sea
level (0 ft), as that is the altitude at which the pressure would be
29.92, on a standard day. In this case your steam driven altimeter is
altimeter setting. These small errors will be corrected when you have
Kevin
> g
>> have been in error.
>> Kevin Horton
>>> g
>>>> and setting
>>>> Jim Hasper
>>>> opportunity ...
>>>> __g__
>> Kevin Horton
>> Ottawa, Canada
> --__g__
Kevin Horton
Ottawa, Canada
ddcuster(at)wmv-co.us Guest
Posted: Tue Sep 26, 2006 5:42 am Post subject: Van's steam gauges versus Dynon EFIS |
The barometric altimeter "computes" the altitude using the correlation between air pressure and altitude; there are lots of opportunity for error. The GPS computes altitude based on the satellite information. The GPS should be real close to the actual elevation.
Barometric altimeter error rapidly builds as it moves away (distance and time) from the corrected reporting station. That is why ATC or FS always gives you the closest reporting station altimeter reading when you contact them.
Since the difference between your barometric altimeter and the GPS if fairly constant, I would suspect that there is some kind of mechanical error in the barometric altimeter. Aircraft altimeters coming out of the shop should be within some specified error. There has to be some tolerance. It is unusual to find any science based instrument with no error. The error should be small, however. Anyone out there know the tolerance for a VFR/IFR altimeter. I know it varies with the altitude.
Doc Custer
Retired software engineer and sometime Audiologist
Building RV9-A. Fuselage
sbuc(at)hiwaay.net Guest
Posted: Tue Sep 26, 2006 6:00 am Post subject: Van's steam gauges versus Dynon EFIS |
J2j3h4(at)aol.com wrote:
The Dynon does not use GPS for any of its calculations. It has pressure
transducers for both altimeter and airspeed solutions.
Sam Buchanan
jack.lockamy(at)navy.mil Guest
Posted: Tue Sep 26, 2006 6:29 am Post subject: Van's steam gauges versus Dynon EFIS |
Gerry,
Before the first flight in my RV-7A, I had the airspeed indicator, altimeter and transponder checked for IFR tolerances. The Dynon EFIS-D10 was right-on altitude and within 2-3 KTS accuracy on airspeed from S/L up to 40KFT. The mechanic doing the certification test was extremely impressed with the accuracy of the Dynon EFIS-D10. You can also adjust the Dynon altimeter up/down in 10 foot increments to correct any errors that may be present. Mine is set at "0" and is nuts on....
The same can not be said for the Van's/UMA back-up steam gauges I installed. The airspeed indicator has a 10 KT fast error that can not be adjusted. The altimeter was over 300 FT off but CAN be adjusted. There is a small screw just left of the adjustment knob on the altimeter. If I remember correctly, I adjusted the altimeter to the known field elevation, loosen the screw, then turn the adjustment knob to the correct barometric reading (ie. 29.92, etc.) in the window. Once the field elevation and the current barometric reading are both correct.... tighten the adjustment screw and you are good to go...
Jack Lockamy
RV-7A N174JL (240 hrs)
Camarillo, CA
www.jacklockamy.com [quote][b]
dbris200(at)sbcglobal.net Guest
Posted: Tue Sep 26, 2006 6:35 am Post subject: Van's steam gauges versus Dynon EFIS |
The altitude that the air traffic system uses is based on the air pressure that is measured by the barometric altimeter, not on the true altitude that you get from GPS. When ATC tells you to fly at 8000 feet, they're talking about pressure altitude, not actual altitude. So, unless the GPS altitude is somehow corrected for pressure, you'll be at the wrong altitude when using the GPS altimeter.
Dave
EAA Technical Counselor
Doc Custer wrote: [quote] The barometric altimeter "computes" the altitude using the correlation between air pressure and altitude; there are lots of opportunity for error. The GPS computes altitude based on the satellite information. The GPS should be real close to the actual elevation.
lessdragprod(at)aol.com Guest
Posted: Tue Sep 26, 2006 7:19 am Post subject: Van's steam gauges versus Dynon EFIS |
There are three different altitudes commonly used in aviation.
1.) Below 18,000' the station pressure is used to adjust the altimeter for local variations in pressure.
2.) Above 18.000' a pressure setting of 29.92 is used. This is also called the pressure altitude.
3.) Density altitude. The pressure altitude can be adjusted for the OAT to obtain the density altitude. The Dynon with an OAT can provide the density altitude readout.
Density altitude is used for performance flight testing. (Station altitude and pressure altitude, by themselves, are useless for performance testing.)
I understand that GPS horizontal position is supposed to be accurate within 60 feet. And the vertical position is less accurate.
Our pilot training provided a common altimeter base so we would be likely to have the same altitude reference while flying.
Doing flight performance testing at a fixed density altitude can be interesting, since the station altitude can be 2,000' different.
Jim Ayers
rv9jim(at)juno.com Guest
Posted: Tue Sep 26, 2006 7:30 am Post subject: Van's steam gauges versus Dynon EFIS |
Gerry,
I use to be an instrument instructor in the Army for helicopter
pilots. Our rule was if the "K" factor was 7 or less, to note it on our
flight plan and apply that correction factor to any barrometric reading
while in flight. 29.75 +,- .07 is an example of acceptable. More
than the 7 points was reason to have the altimeter replaced. Of course
this is only my opinion and is for my use only as a disclaimer.
Jim Nelson
Posted: Tue Sep 26, 2006 7:49 am Post subject: Van's steam gauges versus Dynon EFIS |
Good to know.
Doc Custer
