sshook(at)cox.net Guest
Posted: Thu Sep 21, 2006 9:53 am Post subject: Question about Tanks |
Fellow Builders,
I have a dilemma, here is the synopsis…
I am currently working on the Left Tank and I have already drilled my Z brackets (thank you Dan for the easy way of doing it). I have clecoed together the Tank and the rear baffle to the tank. When I put the tank on the spar, there is a gap between the tank skin and top main skin. The gap looks like its somewhere between 1/32 and 1/16. I will see if I can get an exact measurement tonight, I am also going to attach the bottom main skin and see how that looks before I move forward.
I can also see where the holes that will be dimpled for the screws along the top of the spar are not exactly lined up with the hole in the nutplates (probably a distance equal to that gap I am talking about). The bottom tank attach holes look like they are lined up fine.
Also, the leading edge of the tank seems to sit about the thickness of the skin higher than the leading edge (just at the forward most portion where the tank and L/E meet). Other than that, there is no gap along the seam between the tank and L/E.
Any suggestions or insight will be greatly appreciated…Thank you
Scott & Jenni
RV-7A N696JS
Working on left tank [quote][b]
| - The Matronics RV7-List Email Forum - | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?RV7-List |
dan(at)rvproject.com Guest
Brad Oliver
Posted: Thu Sep 21, 2006 10:39 am Post subject: Question about Tanks |
Scott,
Does the bottom picture on this page look familiar?
http://www.rv7factory.com/log/060110.html
I asked around too, and I discovered that this was a fairly common
issue. At the suggestion of another builder I was able to help the fit
somewhat by taking the nose of each of the tank ribs to the deburring
wheel to improve their roundness (is that a word?). In other words, by
smoothing out the noses of the ribs a little more, I was able to
slightly improve their fit into the skin.
I also used some ratcheting cargo straps to snug the tank skin to the
wing, and I was able to get the screw holes in the skin to align with
the holes in the spar without too much pressure. This really helped
with the alignment of the tank skin to LE skin correct prior to
drilling the W-423 joiner plates. You can see the straps on the wings
here... http://www.rv7factory.com/log/060114.html
Good luck!
Brad Oliver
Livermore, CA | RV-7
www.RV7Factory.com
[quote] ------
Posted: Thu Sep 21, 2006 10:40 am Post subject: Question about Tanks |
When I do that I can close the gap where the main skin meets, I am concerned thought about stressing the skin when the tanks are mounted for good. Also nothing seems to help the slight gap near the point of the leading edge.
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Dan Checkoway
Sent: Thursday, September 21, 2006 11:26
To: rv7-list(at)matronics.com
Subject: Re: Question about Tanks
Push down harder on the tank. I know that sounds too simple, but try it.
)_( Dan
RV-7 N714D
www.rvproject.com / www.weathermeister.com
Posted: Thu Sep 21, 2006 11:02 am Post subject: Question about Tanks |
Scott & Jenni
RV-7A N696JS
Did you have any trouble getting clecos through the tank skin into the
back baffle? Did all the clecos holding the skin to the ribs go in
smoothly & remain perpendicular to the skin around them? (not likely
) Have you built & installed the outboard leading edges yet? Did you see
the same problem there?
If the rib flanges are standing up even a little it can push the baffle
back a bit (will get worse when you put the proseal in there). It's been
a while, but I think I saw something similar when I built my tanks, &
leading edges, as well. I think I used ratcheting strap clamps, aligned
over some of the ribs, to put some pressure on the tank/leading edge.
Use 2/4's or something similar to protect the trailing edge of the wing
skins & rear spar.
If moderate pressure on the straps pulls everything into alignment, try
coaxing the LE rib flanges a bit, both around curved portions & the back
flange.
Charlie
Posted: Thu Sep 21, 2006 11:11 am Post subject: Question about Tanks |
Check to make sure your tank ribs are forced all the way into the nose of the tank skin. That's most likely what at least part of the problem is.
)_( Dan
smittysrv
![](images/avatars/51302129243c3bba3ea1c0.gif)
Bob Collins
![](images/avatars/13808573974613db3673d00.jpg)
Joined: 11 Mar 2006 Posts: 470 Location: St. Paul, Minnesota
Posted: Thu Sep 21, 2006 11:39 am Post subject: Question about Tanks |
I actually disco vered this little problem and provided the solution to Van's some years ago.
jack up the rear spar and you'll hear it pop right into place.
there is a thread on the RV List some time ago where someone ground down the bottom of his Z brackets. He didn't need to do that. It's the small sag in the middle that's causing your problem.
Bob
st. Paul
Sent: Thursday, September 21, 2006 1:26 PM
)_( Dan
RV-7 N714D
_________________ Bob Collins
St. Paul, Minn.
Letters from Flyover Country
http://rvnewsletter.blogspot.com/ |
Posted: Thu Sep 21, 2006 11:57 am Post subject: Question about Tanks |
Actually the sag is not there, I have a jack screw in the center of the rear spar that brought everything nicely into place before I put the main skins on the skeleton. I will however break out the fishing line again and make sure my spars have not moved since having the skins on and drilled.
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Bob Collins
Sent: Thursday, September 21, 2006 12:37
Subject: RE: Question about Tanks
Bob
st. Paul
)_( Dan
RV-7 N714D
Posted: Thu Sep 21, 2006 12:14 pm Post subject: Question about Tanks |
Thank you everyone for all the help and suggestions. I think my first order of business is to pull the tank, take it apart and re-check all my rib flanges and hole alignment (especially around the nose). I did in fact have trouble “wrestling” the tank together.
I know that before the ribs went in; the pre-punched holes were triple checked for straightness. I cleco clamped my ruler to them and they were dead nuts on.
We certainly appreciate all the advice and help everyone offers.
Scott & Jenni
RV-7A N696JS
Working on Left Tank
From: owner-rv7-list-server(at)matronics.com [mailto:owner-rv7-list-server(at)matronics.com] On Behalf Of Scott R. Shook
Sent: Thursday, September 21, 2006 10:53
Subject: Question about Tanks
Fellow Builders,
Scott & Jenni
RV-7A N696JS
Working on left tank 01234567890123
Bob Collins
Posted: Thu Sep 21, 2006 12:15 pm Post subject: Question about Tanks |
Yeah, so did I. But on the night went I couldn't get the darned thing to come down properly, I gave it half a crank and heard a "pop" as it fell into place. It's worth a try. it's worked for a lot of othr folks.
Bob
Sent: Thursday, September 21, 2006 2:57 PM
Bob
st. Paul
)_( Dan
RV-7 N714D
St. Paul, Minn.
Bob Collins
Posted: Thu Sep 21, 2006 12:17 pm Post subject: Question about Tanks |
Is your gap the same all the way around? Especially along the splice joint? Or does it widen (or lessen) along the length of the tank or leading edge?
Bob
Bob
st. Paul
)_( Dan
RV-7 N714D
St. Paul, Minn.
fstringham
Posted: Thu Sep 21, 2006 2:09 pm Post subject: Question about Tanks |
Scott
It has been a while but I do remember I had a similar problem. I was able to
get them to a 64th gap. Was still determined to get them (aft edge tank to
leading edge of top skin to meet. So I called Van's and got
Ken................. he said , rather harshly, 'You don't want them to butt
to each other". "Why" I asked. "Because the paint will crack along the seam
line unless there is enoug room for the paint to fill the gap". My plane
isn't painted or flying yet so I can only take him at his word. I have found
him always to be correct when I follow his advice. Plus I have found that
many times I will take great pains to get everything nearly fiberglass
smooth when clecoed only to have a bit of a shift during riveting. So get it
close as possible with no stress and move on. Ain't it fun.
Frank (at) SGU and SLC.....wiring RV7A
[quote]From: "Scott R. Shook" <sshook(at)cox.net>
Reply-To: rv7-list(at)matronics.com
To: <rv7-list(at)matronics.com>
Date: Thu, 21 Sep 2006 11:40:14 -0700
concerned
_____
)_( Dan
RV-7 N714D
