Unfortunate Mistake
service(at)snapfish.com
PostPosted: Sat Sep 16, 2006 6:47 pm    Post subject: Unfortunate Mistake Reply with quote
you're invited to view my photos! [img]http://www1.snapfish.com/getimageforshare/p=103161158460842281/l=210749510/s=57221756/t=ISH/g=73078138/otsc=SYE/otsi=SAIS[/img]
Photos from dmaib(at)mac.com 6 photo(s)
I had an accident this afternoon when on of my RV-10 Quick Build wings slipped off the cradle. The inboard leading edge was dented and the inboard fuel tank panel was slightly deformed. I am looking for advice on how to gracefully recover from this (completely preventable) mistake.
David Maib
#40559
tailcone
[img]default/images/spacer.gif[/img] [img]default/images/spacer.gif[/img]
Snapfish and the Snapfish logo are trademarks of the Hewlett-Packard Company. All rights reserved.
Snapfish, 303 Second Street, South Tower, Suite 500 San Francisco, CA 94107. If the 'view my photos' button above does not work, copy and paste the link below into your browser http://www1.snapfish.com/share/p=412161158460842234/l=210746949/g=73078138/otsc=SYE/otsi=SAIS
armywrights(at)adelphia.n
PostPosted: Sat Sep 16, 2006 7:03 pm    Post subject: Unfortunate Mistake Reply with quote
David,
After checking out your slideshow I personally believe that you have only cosmetic problems. The leading edge tabs on my rib were literally poking through the proseal bead; I didn’t see that on yours. I think reshaping the inboard part of the airfoil will be your only necessary fix, but you may want to check for torn areas in your proseal and reseal them.
Rob
n8vim(at)arrl.net
PostPosted: Sun Sep 17, 2006 4:10 am    Post subject: Unfortunate Mistake Reply with quote
I had made the same mistake on one of my wings. The solution was to wire brush all of the proseal from the affected area, then I used a plastic hammer, wood block, fluting pliers, and the rivet gun to get it all back in shape. The hardest part was getting the rib somewhat straight. It took around 4-5 hours of repair, and applying a new coat of proseal over the area.
Here is a pic AFTER the repair, but before the proseal: (I was too pissed to take pics before the repair, but it looked EXACTLY like yours)
[img]cid:part1.00050704.03090205(at)arrl.net[/img][img]cid:part2.00000702.02090206(at)arrl.net[/img][img]cid:part3.07050806.02040602(at)arrl.net[/img]
-Jim 40384 (Glad to see I'm not the only one who had this accident! My wing stand now has foam padded "crash bars")
dmaib(at)mac.com (dmaib(at)mac.com) wrote:
 Filesize:  139.7 KB
 Viewed:  174 Time(s)
 Filesize:  192.72 KB
 Viewed:  177 Time(s)
 Filesize:  79.16 KB
 Viewed:  166 Time(s)
